    MagicMirror project for sister
    32 Posts 11 Posters 17.7k Views 12 Watching
    • FoziF Offline
      Fozi Project Sponsor
      You‘re sister will love you forever! Absolutely gorgeous job! I‘d be interested in the script for presence detection. Any GitHub link you can provide?
        blaukon
        sure, might not be great, but it works well for me: https://gist.github.com/blaukon/1e6c4c9ad6ae98ad62545e1659555ecd
        Might not work with every smartphone, for example, it works well with my Samsung Galaxy S8, but not without turning deepsleep off at my parents S7. Also did not work properly on my Sisters Huawei P20. Tried every setting but Android does turn Wifi off although “keep wifi alive even in standby” setting is active.
        Just added my sisters Laptop IP and so far, it’s working fine at her place.
        Added a picture of the mounted mirror: https://drive.google.com/open?id=1Qg0bFbfYzMh_SpuGu-rBGkeVRfeSMuOe
        FoziF 1 Reply Last reply Reply Quote 1
        • FoziF Offline
          Fozi Project Sponsor @blaukon
          @blaukon thanks! Will check it out.
          • H Offline
            hayman
            @blaukon said in MagicMirror project for sister:
            nice work,never got the Google to work ,will try it again later
              banbutcher
              awesome stuff… if you wouldnt mind showing some config files… my assistant doesnt work aswell as yours, also with the googlemapstraffic do you need to buy an api from them of is there a free version? also the ring my phone feature is really cool, how did you achieve this?
              thanks
                blaukon
                sure :-)
                Uploaded my config.js and custum.css files (https://drive.google.com/open?id=16hNIqnGdpdmm9KeE-jcLGc0-fB80OpML)
                You have to add your credit card to use googlemapstraffic, but you’ll have a free contingent per month which I never exceeded.
                The ring my phone thingy is already implemented in the original google-assistant - as long as you use the same google account, you might have to grant the rights to use this function.
                  banbutcher @blaukon
                  @blaukon
                  Thanks alot :)
                    banbutcher
                    hi again,
                    loking at your video and i was wondering how you got hotword or assistant to show the speech to txt? with mine i say the hotword followed by command which brings up the assistant rather than automatically onsceen like yours. i hope this makes sense to you!
                    Richie
                      blaukon @banbutcher
                      @banbutcher hey, I’m using Version 2 from https://github.com/eouia/MMM-AssistantMk2 and the newest version of https://github.com/eouia/MMM-Hotword. Removed the presence on the mirror of both when nothing is decected and I belive that’s all I’ve changed :)
                        bachoo786 @blaukon
                        @blaukon hey well done man. Amazing job.
                        Please help me understand the following:
                        1. how did you attach the monitor and the mirror together?
                        2. How did you hold the monitor to the frame?
                        3. Is the frame strong enough to hold the mirror and the monitor?
                          Thanks.
                        • 1 / 4
