    MagicMirror project for sister
    32 Posts 11 Posters 21.4k Views 12 Watching
    • FoziF Offline
      Fozi Project Sponsor
      You‘re sister will love you forever! Absolutely gorgeous job! I‘d be interested in the script for presence detection. Any GitHub link you can provide?
        blaukon
        sure, might not be great, but it works well for me: https://gist.github.com/blaukon/1e6c4c9ad6ae98ad62545e1659555ecd
        Might not work with every smartphone, for example, it works well with my Samsung Galaxy S8, but not without turning deepsleep off at my parents S7. Also did not work properly on my Sisters Huawei P20. Tried every setting but Android does turn Wifi off although “keep wifi alive even in standby” setting is active.
        Just added my sisters Laptop IP and so far, it’s working fine at her place.
        Added a picture of the mounted mirror: https://drive.google.com/open?id=1Qg0bFbfYzMh_SpuGu-rBGkeVRfeSMuOe
        FoziF 1 Reply Last reply Reply Quote 1
        • FoziF Offline
          Fozi Project Sponsor @blaukon
          @blaukon thanks! Will check it out.
          • H Offline
            hayman
            @blaukon said in MagicMirror project for sister:
            nice work,never got the Google to work ,will try it again later
              banbutcher
              awesome stuff… if you wouldnt mind showing some config files… my assistant doesnt work aswell as yours, also with the googlemapstraffic do you need to buy an api from them of is there a free version? also the ring my phone feature is really cool, how did you achieve this?
              thanks
                blaukon
                sure :-)
                Uploaded my config.js and custum.css files (https://drive.google.com/open?id=16hNIqnGdpdmm9KeE-jcLGc0-fB80OpML)
                You have to add your credit card to use googlemapstraffic, but you’ll have a free contingent per month which I never exceeded.
                The ring my phone thingy is already implemented in the original google-assistant - as long as you use the same google account, you might have to grant the rights to use this function.
                  banbutcher @blaukon
                  @blaukon
                  Thanks alot :)
                    banbutcher
                    hi again,
                    loking at your video and i was wondering how you got hotword or assistant to show the speech to txt? with mine i say the hotword followed by command which brings up the assistant rather than automatically onsceen like yours. i hope this makes sense to you!
                    Richie
                      blaukon @banbutcher
                      @banbutcher hey, I’m using Version 2 from https://github.com/eouia/MMM-AssistantMk2 and the newest version of https://github.com/eouia/MMM-Hotword. Removed the presence on the mirror of both when nothing is decected and I belive that’s all I’ve changed :)
                        bachoo786 @blaukon
                        @blaukon hey well done man. Amazing job.
                        Please help me understand the following:
                        1. how did you attach the monitor and the mirror together?
                        2. How did you hold the monitor to the frame?
                        3. Is the frame strong enough to hold the mirror and the monitor?
                          Thanks.
                          blaukon @bachoo786
                          @bachoo786
                          sadly, I do not have more pictures or access to the mirror at the moment - alt text
                          But I made 3d modell in tinkercad to show you the necessary construction:
                          front:
                          alt text
                          -> orange: mirrorglass (bigger than the hole)
                          alt text
                          -> monitor right onto the glass
                          alt text
                          backside:
                          alt text
                          the frame is massiv, about 2-2.5cm wood, I have absolutly no worries that this frame would brake by itself :)
                          and that’s basically how it’s mounted:
                          alt text
                          • T Offline
                            thoeng
                            Hi, I have seen the video and its great work.
                            I have similar setup with yours i.e.: AssistantMK2 and Kinobo USB mic (not Akiro but that mini USB one) and it is nowhere as sensitive as yours. I have to speak almost next to the microphone for the hotword to activate AssistantMK2. This reduce the mirror usability considerably.
                            Can you please let me know what you have done to increase the sensitivity? so far, I have increased mic to max sensitivity with ALSA mixer but still nowhere near yours.
                            Regards,
                              blaukon
                              hi, all I did is to set a higher but not too high sensitivity via alsa mixer or on desktop - right click on audio - audio input - input device settings and adjust the sesitivity:
                              alt text
                              did you test your mic? arecord test.wav -> aplay test.wav?
                              • T Offline
                                thoeng
                                Thanks @blaukon
                                Yes, i tried to raise the sensitivity via UI and Terminal. Volume from arecord is still very low.
                                If I replace the mic, is it direct replacement or any configuration required?
                                  blaukon
                                  if your recoding is still quiet, even when you’ve raised the sensitivity, it’s mostlikly your microphone :/
                                  I’ve bought this one https://www.amazon.de/Kinobo-Mini-Akiro-Mikrofon-Windows/dp/B00NSOWWIS
                                  and also one that looked like 99% the same, was cheaper, but wayyy worse in comparison.
                                    amsuvarna27 @blaukon
                                    @blaukon I’m doing also same project.
                                    Sir can you please share the Back up file of this project.
                                    I’m trying from last 3 months but unable to complete.
                                    Please share with me.
                                    • T Offline
                                      thoeng @blaukon
                                      @blaukon yep its definetely the mic. I will change and reply back.
                                      Thanks!
                                        bachoo786 @blaukon
                                        @blaukon hey so are you saying your mirror glass is bigger than your monitor?
                                        I have the issue if the mirror glass is bigger than the monitor then the edge which is not covered by the monitor it needs to be painted black or covered with a black material. This causes reflection issues on the mirror from the front I.e. you can see distorted images on the edge I.e. the image looks stretched…
                                          blaukon @bachoo786
                                          @bachoo786
                                          hey, as far as I can remember, the glass is slightly bigger than the monitor and the frame is also slightly bigger than the glass, no tape was used, since you only see the monitor in the frame and not the “frame” of the 27" monitor.
                                          tried to show it graphically with my old expanded notebookdisplay:
                                          alt text
                                            Blauenfeldt
                                            @blaukon I saw your pictures, and I see the text is easy to see in daylight, but in the video, it’s kinda hard to see in low light. But how is it with your own eyes in brought daylight and with low light/night?
