    MMM-KeyBindings: Control your mirror with Amazon Fire Stick Remote and Generic Keyboard Inputs
    keyboardremote controlfire stick remotebluetooth
    34 Posts 13 Posters 21.9k Views 12 Watching
    • G Offline
      gregp
      @shbatm Fantastic! Thanks again!
        mrdenmark
        on my miirror i have set up 3 pages with mmm-pages,i’ve installed mmm-keybindings as i want to use the arrow keys to cycle through the pages but so far i’m having no luck,could anyone suggest a config sample to set this up?
        • Cr4z33C Offline
          Cr4z33
          @shbatm how comes I never noticed this topic before? 😅
          Can this module be adapted virtually for anything available in MagicMirror?
          What about your other module MMM-RTSPStream?
          Can I switch ie. streams by using the Fire Stick remote?
          • L Offline
            l0b5ter @mrdenmark
            @mrdenmark Did you get a response regarding this matter?
            im having a hard time doing the same as you :(
            • L Offline
              l0b5ter
              Didnt get this really to work, tried the same but it wont change between the pages. Mind take a look? (https://forum.magicmirror.builders/topic/12332/mmm-keybindings-mmm-pages-mmm-page-indicator), Me really stuck :(
                Mr.Gysy
                Hey,
                Great Tool and I got it worked with my Keyboard but not with my remote.
                Remote I bought: Remote
                its a remote with a USB reciver.
                Thats what I insert into my config file. Is something wrong?
                alt text
                Please help me guys. THX
                • Cr4z33C Offline
                  Cr4z33
                  @shbatm and everybody here I am trying to setup a Fire Stick, but I am stuck at step #3 of the module’s instructions because I don’t know WHERE in the file 99-btremote.rules I’ve got to insert the remote name (in my case it’s mice)? :confused_face:
                    banbutcher
                    Hi @shbatm ,
                    ive been using MMM-Keybindings for a while with MMM-pages and up untill a month or so ago i noticed a problem that if ive used google assistant or click on screen, keybindings seems to loose focus and pressing the keys will not work until you click in the top bar where alerts come then i can use again untill problem repeats itself. i also have had the same problems with it when using your MMM-Carousel module as i taught it might be pages fault.
                    thank you
                      matze86 @Mr.Gysy
                      @mr-gysy
                      I‘ve got a similar issue with a similar remote
                      Did you solve your problem?
                      In my case the keys (KEY_PAGEUP & DOWN & BACKSPACE) don‘t work.
                      I changed the evdev path. I added them to „handleKeys“. I added them to „keyMap“.
                      I can see them in „evtest“ working- KeyCode 104 & 109 & 14
                      But in „viewnotifications“ they are not displayed
                      The other keys are working with keybindings & carousel.
                      But i need two more keys xD
                      • 3 / 4
