    MMM-GooglePhotos
    294 Posts 56 Posters 418.1k Views 59 Watching
      roccodicarlo
      I am running MM on a RP zero W and I only have the RPi command line. It is running in server mode. When I execute node generate_token.js, it does not bring up a browser window where I can authorize for a token. Do I need to do something different?
        sdetweil @roccodicarlo
        @roccodicarlo open the chromium-browser to localhost:8080 to get the UI (if this is a graphical desktop pi 0)
        when/how did u install? my automated script does the setup to run chromium if the graphical desktop exists
          roccodicarlo
          No this is not the graphical desktop, it is all CLI.
            @roccodicarlo ok, then the token tool won’t work…
            are u doing the cli on purpose?
              A Former User
              Copy url and open browser in other pc. Do the process then return to your rpi.
                roccodicarlo
                ok I will try. The reason I am doing cli was because with desktop gui, I found it very sluggish on the rpi zero.
                ? 1 Reply Last reply
                  A Former User @roccodicarlo
                  @roccodicarlo
                  I’m worrying, your node version has to be ^8.3 at least.
                    roccodicarlo
                    My node version is 10.16…so it should be ok
                      philmavedzenge
                      @Sean i really like this module and have been using it for sometime now. I have noticed with the new update that there is a padding of about 10px around the screen. Is there a way of removing that? I use my screen in landscape mode only. Thanks in advance
                      P 1 Reply Last reply
                        philmavedzenge @philmavedzenge
                        @philmavedzenge said in MMM-GooglePhotos:
                        @Sean nevermind, i fixed it in custom.css
                        • G
                          gonzonia @Guest
                          @Sean Awesome work! Loving the update!
                            Samwise
                            Hey, so i’m not sure what this means, but it happens whenever I try to start it:
                            pi@sam-raspberrypi:~/MagicMirror $ npm start
                            magicmirror@2.7.1 start /home/pi/MagicMirror
                            sh run-start.sh
                            /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                            npm ERR! file sh
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno ENOENT
                            npm ERR! syscall spawn
                            npm ERR! magicmirror@2.7.1 start: sh run-start.sh
                            npm ERR! spawn ENOENT
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.7.1 start script.
                            npm ERR! /home/pi/.npm/_logs/2020-04-02T05_53_17_399Z-debug.log
                            S ? S 3 Replies Last reply
                              Samwise @Samwise
                              also, the auto start script doesn’t seem to work either
                                A Former User @Samwise
                                @Samwise said in MMM-GooglePhotos:
                                npm ERR! file sh
                                That seems not related to module itself. Your environment seems missing some dependency.
                                Try to this.
                                sudo apt-get install libgconf-2-4
                                  sdetweil @Samwise
                                  libgconf-2.so.4:
                                  try this from a terminal window
                                  magicmirror@2.7.1
                                  version 2.7.1 is pretty old…
                                  edit the package.json file and change
                                  "start","sh run-start.sh"
                                  to
                                  "start"."sh ./run-start.sh"
                                  check to see if run-start.sh is in the ~/MagicMirror folder, if not then do
                                  cule -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                                  chmod +x run-start.sh
                                  • G
                                    gonzonia
                                    The new info box is not aligning correctly for me. It’s showing mostly off the screen.
                                    Screenshot
                                      A Former User @gonzonia
                                      @gonzonia
                                      Show me your configuration of MMM-GooglePhotos.
                                      G 2 Replies Last reply
                                      • O
                                        orayoflighto Project Sponsor
                                        I just updated to the latest And my photos stopped displaying. Anyone else have this issue?
                                        I just get Loading…
                                        S Z O 3 Replies Last reply
                                          sdetweil @orayoflighto
                                          @orayoflighto open the developers window ctrl-shift-i on the keyboard, select the console tab and scroll up for any errors
                                          did u also run npm install in the MMM-GooglePhotos folder?
                                          • G
                                            gonzonia @Guest
                                            @Sean I commented out autoInfoPosition because it seemed to break when I turned that on. The showWidth/showHeight match the screen resolution showing on the dekstop.
                                              			module: "MMM-GooglePhotos",
                                            			position: "fullscreen_below",
                                            			albums: ["NixPlay","MM-Family2"], // Set your album name. like ["My wedding", "family share", "Travle to Paris"]
                                            			updateInterval: 1000 * 60, // minimum 10 seconds.
                                            			sort: "random", // "old", "random"
                                            			uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
                                            			condition: {
                                            				fromDate: null, // Or "2018-03", RFC ... format available
                                            				toDate: null, // Or "2019-12-25",
                                            				minWidth: null, // Or 400
                                            				maxWidth: null, // Or 8000
                                            				minHeight: null, // Or 400
                                            				maxHeight: null, // Or 8000
                                            				minWHRatio: null,
                                            				maxWHRatio: null,
                                            				// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   < 1 : Portraited Photo, > 1 : Landscaped Photo)
                                            			showWidth: 1680, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
                                            			showHeight: 1050,
                                            			timeFormat: "relative", //"YYYY/MM/DD HH:mm", // Or `relative` can be used.
                                            			//autoInfoPosition: true,
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
