    MMM-GooglePhotos
    294 Posts 56 Posters 418.1k Views 59 Watching
      A Former User @Samwise
      @Samwise
      Don’t know what happens without details. What does the log say?
        Samwise @Guest
        @Sean where do i find the log?
        Also, this popped up: pi@raspberrypi:~/MagicMirror $ npm start
        magicmirror@2.7.1 start /home/pi/MagicMirror
        sh run-start.sh
        /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
        npm ERR! file sh
        npm ERR! code ELIFECYCLE
        npm ERR! errno ENOENT
        npm ERR! syscall spawn
        npm ERR! magicmirror@2.7.1 start: sh run-start.sh
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.7.1 start script.
        npm ERR! /home/pi/.npm/_logs/2020-02-29T10_46_17_131Z-debug.log
        • L
          lucBtrl @Guest
          @Sean
          Thanks a lot Sean !
          It appears indeed that the credentials generated was not the right type (I may have not selected the right option in google api console). Worked better the second time !
          Marvelous results of the module
          • A
            ayangu
            @Sean I logged into my google account and allowed consent. However, once I input the code back into the terminal, all I get is auth_and_test started.
            What am I doing wrong?
            ? 1 Reply Last reply
              A Former User @ayangu
              @ayangu
              when you did auth_and_test, token.json was created?
                A Former User
                New Updates
                [2.0.0] - 2020/03/23
                • Notice: Whole new build from scratch. new installation and configuration is needed.
                • Removed: deprecated dependency request. Instead, using Axios and https
                • Changed: More stable displaying photos
                • Changed: New looks.
                • Changed: Access album by name not by id.
                • Added: You can filter photos by condition.
                • Added: GPHOTO_NEXT, GPHOTO_PREVIOUS notifications are supported.
                • Added: GPHOTO_UPLOAD notification is supported. Now MMM-Selfieshot and MMM-TelegramBot can upload pictures with this module.
                • Removed: mode, scanInterval, opacity is removed because no more necessary.
                Screenshot
                G 1 Reply Last reply
                  roccodicarlo
                  I am running MM on a RP zero W and I only have the RPi command line. It is running in server mode. When I execute node generate_token.js, it does not bring up a browser window where I can authorize for a token. Do I need to do something different?
                    sdetweil @roccodicarlo
                    @roccodicarlo open the chromium-browser to localhost:8080 to get the UI (if this is a graphical desktop pi 0)
                    when/how did u install? my automated script does the setup to run chromium if the graphical desktop exists
                      roccodicarlo
                      No this is not the graphical desktop, it is all CLI.
                        @roccodicarlo ok, then the token tool won’t work…
                        are u doing the cli on purpose?
                          A Former User
                          Copy url and open browser in other pc. Do the process then return to your rpi.
                            roccodicarlo
                            ok I will try. The reason I am doing cli was because with desktop gui, I found it very sluggish on the rpi zero.
                              A Former User @roccodicarlo
                              @roccodicarlo
                              I’m worrying, your node version has to be ^8.3 at least.
                                roccodicarlo
                                My node version is 10.16…so it should be ok
                                  philmavedzenge
                                  @Sean i really like this module and have been using it for sometime now. I have noticed with the new update that there is a padding of about 10px around the screen. Is there a way of removing that? I use my screen in landscape mode only. Thanks in advance
                                  P 1 Reply Last reply
                                    philmavedzenge @philmavedzenge
                                    @philmavedzenge said in MMM-GooglePhotos:
                                    @Sean nevermind, i fixed it in custom.css
                                    • G
                                      gonzonia @Guest
                                      @Sean Awesome work! Loving the update!
                                        Samwise
                                        Hey, so i’m not sure what this means, but it happens whenever I try to start it:
                                        pi@sam-raspberrypi:~/MagicMirror $ npm start
                                        sh run-start.sh
                                        npm ERR! file sh
                                        npm ERR!
                                        npm ERR! /home/pi/.npm/_logs/2020-04-02T05_53_17_399Z-debug.log
                                        S ? S 3 Replies Last reply
                                          Samwise @Samwise
                                          also, the auto start script doesn’t seem to work either
                                            @Samwise said in MMM-GooglePhotos:
                                            npm ERR! file sh
                                            That seems not related to module itself. Your environment seems missing some dependency.
                                            Try to this.
                                            sudo apt-get install libgconf-2-4
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
