    MMM-GooglePhotos
    294 Posts 56 Posters 409.5k Views 59 Watching
    • A
      ayangu
      @Sean I logged into my google account and allowed consent. However, once I input the code back into the terminal, all I get is auth_and_test started.
      What am I doing wrong?
        A Former User @ayangu
        @ayangu
        when you did auth_and_test, token.json was created?
          A Former User
          New Updates
          [2.0.0] - 2020/03/23
          • Notice: Whole new build from scratch. new installation and configuration is needed.
          • Removed: deprecated dependency request. Instead, using Axios and https
          • Changed: More stable displaying photos
          • Changed: New looks.
          • Changed: Access album by name not by id.
          • Added: You can filter photos by condition.
          • Added: GPHOTO_NEXT, GPHOTO_PREVIOUS notifications are supported.
          • Added: GPHOTO_UPLOAD notification is supported. Now MMM-Selfieshot and MMM-TelegramBot can upload pictures with this module.
          • Removed: mode, scanInterval, opacity is removed because no more necessary.
          Screenshot
          G 1 Reply Last reply Reply Quote 1
            roccodicarlo
            I am running MM on a RP zero W and I only have the RPi command line. It is running in server mode. When I execute node generate_token.js, it does not bring up a browser window where I can authorize for a token. Do I need to do something different?
              sdetweil @roccodicarlo
              @roccodicarlo open the chromium-browser to localhost:8080 to get the UI (if this is a graphical desktop pi 0)
              when/how did u install? my automated script does the setup to run chromium if the graphical desktop exists
                roccodicarlo
                No this is not the graphical desktop, it is all CLI.
                  @roccodicarlo ok, then the token tool won’t work…
                  are u doing the cli on purpose?
                    A Former User
                    Copy url and open browser in other pc. Do the process then return to your rpi.
                      roccodicarlo
                      ok I will try. The reason I am doing cli was because with desktop gui, I found it very sluggish on the rpi zero.
                      ? 1 Reply Last reply Reply Quote 1
                        A Former User @roccodicarlo
                        @roccodicarlo
                        I’m worrying, your node version has to be ^8.3 at least.
                          roccodicarlo
                          My node version is 10.16…so it should be ok
                            philmavedzenge
                            @Sean i really like this module and have been using it for sometime now. I have noticed with the new update that there is a padding of about 10px around the screen. Is there a way of removing that? I use my screen in landscape mode only. Thanks in advance
                              philmavedzenge @philmavedzenge
                              @philmavedzenge said in MMM-GooglePhotos:
                              @Sean nevermind, i fixed it in custom.css
                              • G
                                gonzonia @Guest
                                @Sean Awesome work! Loving the update!
                                  Samwise
                                  Hey, so i’m not sure what this means, but it happens whenever I try to start it:
                                  pi@sam-raspberrypi:~/MagicMirror $ npm start
                                  magicmirror@2.7.1 start /home/pi/MagicMirror
                                  sh run-start.sh
                                  /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                                  npm ERR! file sh
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno ENOENT
                                  npm ERR! syscall spawn
                                  npm ERR! magicmirror@2.7.1 start: sh run-start.sh
                                  npm ERR! spawn ENOENT
                                  npm ERR!
                                  npm ERR! Failed at the magicmirror@2.7.1 start script.
                                  npm ERR! /home/pi/.npm/_logs/2020-04-02T05_53_17_399Z-debug.log
                                  S ? S 3 Replies Last reply Reply Quote 0
                                    Samwise @Samwise
                                    also, the auto start script doesn’t seem to work either
                                      A Former User @Samwise
                                      @Samwise said in MMM-GooglePhotos:
                                      npm ERR! file sh
                                      That seems not related to module itself. Your environment seems missing some dependency.
                                      Try to this.
                                      sudo apt-get install libgconf-2-4
                                        sdetweil @Samwise
                                        libgconf-2.so.4:
                                        try this from a terminal window
                                        magicmirror@2.7.1
                                        version 2.7.1 is pretty old…
                                        edit the package.json file and change
                                        "start","sh run-start.sh"
                                        to
                                        "start"."sh ./run-start.sh"
                                        check to see if run-start.sh is in the ~/MagicMirror folder, if not then do
                                        cule -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                                        chmod +x run-start.sh
                                        • G
                                          gonzonia
                                          The new info box is not aligning correctly for me. It’s showing mostly off the screen.
                                          Screenshot
                                            A Former User @gonzonia
                                            @gonzonia
                                            Show me your configuration of MMM-GooglePhotos.
                                            G 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
