    MMM-MyCommute
    286 Posts 80 Posters 732.7k Views 77 Watching
      banbutcher @sdetweil
      thats what i thought, i have the right ones enabled and using the same key! :/
        banbutcher
        turns out i didnt have the address formatted correctly! took them directly from google maps and it worked great!
        thanks,
        Richie
          banbutcher
          is there any way of knowing if calendar events are being passed? Ive added this code to mine and nothing gets added to my commute:
                maxCalendarEvents: 2,
                maxCalendarTime: 24 * 60 * 60 * 1000,
                calendarOptions: [
                        mode: 'driving'
          am i missing something?
          • T
            testdruif
            Created issue for calendar events regarding arrival time & transit option.
            Also worth noting that calendar events are only first added when the module refreshes traffic (after 10 minutes from startup)
            https://github.com/qistoph/MMM-MyCommute/issues/12
            S T 2 Replies Last reply Reply Quote 0
              sdetweil @testdruif
              @testdruif is this module getting cal events as broadcast by the calendar module? How often does the cal module refresh/broadcast?
              • T
                testdruif @testdruif
                @testdruif said in MMM-MyCommute:
                When the calendar events are added the code crashes further down the line.
                Code doesn’t add the calendar collor variable.
                • T
                  testdruif @sdetweil
                  @sdetweil Yes, the module gets events from calendar module broadcast.
                  Another issue: when you have multiple calendar modules configured the array gets wiped at unexpected times.
                  So you can only use it correctly with 1 calendar module.
                  because the commute module loads before all calendar entries are processed they are processed on the next “commute update” which is 10m by default config.
                    sdetweil @testdruif
                    @testdruif hm… I have a module that uses calendar events broadcast, and gets it right away…
                      SoleLo
                      Is there a way to remove the arrival time ?
                        bhepler Module Developer @SoleLo
                        @SoleLo - You could probably modify the custom.css file to hide the value of the arrival time.
                          SoleLo @bhepler
                          @bhepler would something like this work?
                          .MMM-MYCommute.arrival-time-only .time {
                          display: none;
                          UPDATE: I actually tried
                          .MMM-MYCommute. transit-arrival-time.time
                          display: none;
                          Still doesn’t work.
                            sun34529
                            @SoleLo and @bhepler , I’m trying to figure this out as well. Any luck?
                            • lavolp3L
                              lavolp3 Module Developer
                              I see that the most recent active fork of this module has changed to @qistoph ?
                              I am wondering if the module still works with one origin or if there’s already a possibility for several routes with different origins and destinations?
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                                sdetweil @sun34529
                                @sun34529 use a browser on your pc, chrome or firefox, and open the MM page, (make sure the mm config allows outside access with
                                address:"0.0.0.0",
                                ipWhitelist:[],
                                in config.js)
                                then do ctrl-shift-i on your keyboard to open the developers window,
                                and select the elements tab, and navigate to the module content to the piece u are interested in
                                once there, click on it in the elements tree (so it becomes selected) and u will see the css tree for that element on the right side.
                                the top most is the info AT the element, u can click to add display:none and the element should not be shown…
                                on the bottom of the screen shows the class name tree
                                this will give u the info to get the file update right… Screenshot at 2020-05-25 17-11-54.png
                                  RedNax Module Developer
                                  Hi everyone,
                                  Just to remind you that this still works…
                                  https://github.com/RedNax67/MMM-TrafficCal
                                  https://forum.magicmirror.builders/topic/831/mmm-trafficcal-dynamically-display-commutes-based-on-calendar-entries?_=1590694194999
                                    Srcodesalittle
                                    Hi there. Thanks for making this module.
                                    I was running this flawlessly till a few days ago when it randomly just disappeared from my mirror. The API is still active, I haven’t crossed my billing threshold or anything and the startup logs do show that Mycommute has started. Do you by any chance have any suggestions on what could be happening?
                                    Thanks in advance!
                                      Srcodesalittle @RedNax
                                      @RedNax Thanks for the heads up. So, I don’t actually run a calendar module so I’m a little lost on how to specify the destination (I go to the same destination everyday).
                                      Could you possibly please give me a more broken down instruction on what I need to do to set a destination?
                                      Thanks in advance!
                                      • L
                                        leem2000
                                        Hi, I’m new to Pi and MM. I’ve installed few modules and got them working. MMM-MyCommute looks to be a very useful module but can’t get it to work. I installed it following the instructions on its git page. It’s failing to load. I get “Loading…”.
                                        I’m running with unmodified config from the git module page with my apiKey and hideDays set to []. The API key works as I have tested it with another module and also with https://maps.googleapis.com/maps/api/directions/json?origin=Disneyland&destination=Universal+Studios+Hollywood&key=. No errors in pm2 logs either. Peeking into the main .js file, there are log statements. I can’t locate a log file. Not familiar with Node or MM. Would appreciate pointers on what to try and where to look next.
                                        Thanks in advance.
                                          sdetweil @leem2000
                                          @leem2000 for the MMM-MyCommute.js, open the developers window (ctrl-shift-i on the mirror keyboard), select the console tab… u can filter too, enter comm in the filter field to see messages out from only a module with ‘comm’ in its name
                                          • L
                                            leem2000 @sdetweil
                                            Thanks @sdetweil. There are some errors logged to the console.
                                            The module it’s trying to access is
                                            http://localhost:8080/modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js.
                                            When I put that into the browser I get
                                            Cannot GET /modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js
                                            Then for each destination, I get
                                            Clearly, moment.duration format function is missing. I installed node by following manual install instructions in MM install page.
                                            I have the following in node_modules/moment. This is as installed and not modified.
                                            pi@raspberrypi:~/MagicMirror/node_modules/moment $ pwd
                                            /home/pi/MagicMirror/node_modules/moment
                                            pi@raspberrypi:~/MagicMirror/node_modules/moment $ ls
                                            CHANGELOG.md  ender.js  locale  moment.d.ts  package.js    README.md  ts3.1-typings
                                            dist          LICENSE   min     moment.js    package.json  src
                                            Any ideas on how to fix this?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
