    Adding jQuery
    11 Posts 5 Posters 8.8k Views 5 Watching
      snimax
      Im trying to develop a module and it would be helpfull to have jQuery but im not sure how to include it. when im using the
      getScripts: function() {
      return [“jQuery.js”];
      everything just turns black and nothing loads. Any idea of what to do?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @snimax
        @snimax you probably getting an error in the console that it can’t find the script jquery make sure you add it to your module folder
          snimax
          Ah so if i want to use it for multiple modules, do i have to add the file to every modules folder or is there a “universal” place for them?
            @snimax yes otherwise a user who will use only one of your modules is not able to use it correctly https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#getscripts
              snimax
              Okey thank you very much!
              • E Offline
                E3V3A
                @strawberry-3-141
                It seem that getscripts doesn’t work anymore, at least not as I expected. This seem to be because even though MM finds the script, we get hit by the security error:
                The resource from “http://192.168.1.2:8080/node_modules/jquery-ui-dist/jquery-ui.css” was blocked due to MIME type mismatch (X-Content-Type-Options: nosniff).
                Any idea how to get past this?
                "Everything I do (here) is for free – altruism is the way!"
                • N Offline
                  ninjabreadman @E3V3A
                  @E3V3A When I look up the error, I find this thread which says:
                  Check if the file path is correct and the file exists - in my case that was the issue - as I fixed it, the error disappeared.
                  I suspect that jQuery is installed in your module’s node_modules folder, and not at the root of your MagicMirror (I may however be wrong).
                  In which case I would expect jQuery to be installed at “http://192.168.1.2:8080/modules/MMM-Tabulator/node_modules/jquery-ui-dist/jquery-ui.css”. This is why in your thread here you needed to use this.file() so that it created a relative path.
                  • E Offline
                    E3V3A @ninjabreadman
                    @ninjabreadman Oh man, Excellent! I wish I’d had seen that a week ago…
                    Anyway, I’ve solved it since, but got another issue with getting the Tabulator code to actually do something. No errors shown, unfortunately.
                    PS. Is there a way to close a thread or mark it as solved??
                    • yawnsY Offline
                      yawns Moderator @E3V3A
                      @E3V3A
                      Yes, at the end of the thread there is a button with a gear symbol. Tap/click it and select Mark as question, then tap/click a second time and select Mark as resolved
                      • E Offline
                        E3V3A @yawns
                        @yawns I must be blind!?
