    MMM-OralB / Bluetooth equipped toothbrush integration
    68 Posts 13 Posters 42.0k Views 20 Watching
    • T Offline
      timodejong95
      Hey guys,
      I have tracked this topic for a while and I have created an own module for bluetooth devices based on (https://github.com/Hypfer/Cybele). Currently only Oral B toothbrush is supported: https://github.com/timodejong95/MMM-BluetoothDevices
      I am still testing it but it seems to work stable’ish. Although I cannot test it with an actual mirror because that is still work in progress. If you want to check it out and test be my guest. If you have any improvements or tips let me know!
      Hope this helps out.
      lavolp3L 1 Reply Last reply Reply Quote 1
      • lavolp3L Offline
        lavolp3 Module Developer @timodejong95
        @timodejong95 GREAT!!
        I’ll try it out now.
        One comment to the readme.
        You have given the config entry in JSON style (with hyphens around the keys).
        Config entries are in JS style.
        I guess devices should also be an array of JS objects?
        Then it should be like this:
              module: "MMM-BluetoothDevices",
              position: "bottom_bar",
                devices: [
                  { type: "OralBToothbrush", name: "OralB", mac: "" }
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L Offline
          lavolp3 Module Developer @lavolp3
          @lavolp3 Also mentioning in the Readme that npm install is necessary would be helpful
          • lavolp3L Offline
            OK I have a first error message
            [15:04:46.174] [ERROR]  15:04:46 <error> (node:1454) UnhandledPromiseRejectionWarning: Error: No such interface found
                at /home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/dbus-native/lib/introspect.js:31:23
                at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/xml2js/lib/parser.js:304:18)
                at Parser.emit (events.js:182:13)
                at SAXParser.onclosetag (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/xml2js/lib/parser.js:262:26)
                at emit (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/sax/lib/sax.js:624:35)
                at emitNode (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/sax/lib/sax.js:629:5)
                at closeTag (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/sax/lib/sax.js:889:7)
                at SAXParser.write (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/sax/lib/sax.js:1436:13)
                at Parser.exports.Parser.Parser.parseString (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/xml2js/lib/parser.js:323:31)
                at Parser.parseString (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/xml2js/lib/parser.js:5:59) (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
            no Toothbrush activated yet. Only started the mirror with npm start dev.
            Running on a RasPi 3b w/ on-board bluetooth
            • T Offline
              timodejong95
              Ooh good one, I have some time tonight, will update the docs.
              Hmm you running on raspberry pi do you got bluetooth enabled? Can you find the toothbrush if you use the GUI bluetooth?
              If you got the time could we skype or call, it’s faster to tackle issueus, PM me about that.
              lavolp3L 2 Replies Last reply Reply Quote 0
              • lavolp3L Offline
                @timodejong95 that’s rather difficult for me juggling with family, (home) office and several other things I have to say. Will think about this and let you know.
                I have worked successfully with bluetoothctl and noble (npm).
                Both were able to connect to the brush.
                With bluetoothctl I got a constant stream of the manufacturer data that contains some info. (see above)
                I used that straight from the console.
                • lavolp3L Offline
                  @timodejong95 OK I have identified the source of the error.
                  It originated from the connectDevice function on Dongle.js
                  I had a wrong mac address for the brush which leads to an unresolved promise.
                  Good luck finding the promise :smiling_face_with_open_mouth_smiling_eyes:
                  (I love/hate promises…)
                  Correcting the mac address I get new unresolved rejection errors.
                  [11:54:35.940] [LOG]    11:54:35 <log> Retrying Dirks OralB 2/3 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Device.js:42 Promise)
                  [11:54:35.964] [ERROR]  11:54:35 <error> (node:23373) UnhandledPromiseRejectionWarning: Software caused connection abort (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:54:35.970] [ERROR]  11:54:35 <error> (node:23373) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1) (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:54:35.975] [ERROR]  11:54:35 <error> (node:23373) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:55:16.260] [LOG]    11:55:16 <log> Retrying Dirks OralB 3/3 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Device.js:42 Promise)
                  [11:55:16.275] [ERROR]  11:55:16 <error> (node:23373) UnhandledPromiseRejectionWarning: Software caused connection abort (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:55:16.279] [ERROR]  11:55:16 <error> (node:23373) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2) (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:55:56.582] [ERROR]  11:55:56 <error> (node:23373) UnhandledPromiseRejectionWarning: Error: Couldn't connect to Dirks OralB after 4 tries.
                      at Promise (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Device.js:46:16)
                      at new Promise (<anonymous>)
                      at tryConnect (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Device.js:40:14)
                      at Object.iFace.Connect (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Device.js:56:13)
                      at EventEmitter.<anonymous> (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/dbus-native/lib/bus.js:140:19)
                      at EventEmitter.emit (events.js:187:15)
                      at /home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/dbus-native/index.js:106:14
                      at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_modules/dbus-native/lib/message.js:55:9)
                      at Socket.emit (events.js:182:13)
                      at emitReadable_ (_stream_readable.js:540:12) (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:55:56.588] [ERROR]  11:55:56 <error> (node:23373) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:55:56.593] [ERROR]  11:55:56 <error> (node:23373) UnhandledPromiseRejectionWarning: Software caused connection abort (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  [11:55:56.599] [ERROR]  11:55:56 <error> (node:23373) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  So… Software caused connection abort. Don’t know what that means unfortunately. Guess I need to learn a bit more about the connection process. But I get the feeling that this module is a bit too complex for just using with my toothbrush.
                  Let me know if you know my problem.
                  • T Offline
                    timodejong95 @lavolp3
                    @lavolp3 Check, I will update the docs, with more info soon.
                    Yeah promises could be really nice if implemented correctly, now debugging is a pain because the error logs are not as useful. I will make this better in the coming week.
                    When you hit the web interfase the node_helper is triggered, do you then have your brush on? Because when you start up the first time, alle the devices should be on and ready to connect.
                    • T Offline
                      timodejong95
                      I have tweaked the code a bit towards better exception handling, this might be helpful for you
                        djerik
                        Works great with my Oral B 9000!
                        Notes:
                        • I had to change the git clone to https instead of git clone git@github.com:timodejong95/MMM-BluetoothDevices.git
                        • Copying the file MMM.conf requires administrative rights
                        • I used bluetoothctl to find the MAC of the toothbrush
                        • T Offline
                          timodejong95 @djerik
                          @djerik Nice! Good to hear, and thanks for the feedback I will update the readme where needed!
                          lavolp3L D 2 Replies Last reply Reply Quote 0
                          • lavolp3L Offline
                            @timodejong95 Hi Timo, it works for me now as well. Very good!
                            So now let’s go for the holy grail! The battery status.
                            It is there and I managed to get it out using noble. Don’t ask me how. Lol.
                            Find the code below where I meddled with Advertisements and Characteristics:
                            noble.on('discover', function(peripheral) {
                              var ad = peripheral.advertisement || "";
                              if (ad.localName == "Oral-B Toothbrush") {
                                //console.log('Found device with local name: ' + ad.localName);
                                //console.log('advertising the following service uuid\'s: ' + ad.serviceUuids);
                                //console.log("ID: "+peripheral.id);
                                //console.log("Advertisement: "+ad);
                                if (ad.manufacturerData) {
                                    console.log('Found OralB Toothbrush with ID: ' + peripheral.id);
                                    console.log('ManufacturerData: '+ad.manufacturerData.toString('hex'));
                                    //noble.stopScanning();
                                    peripheral.connect(function(error) {
                                      if (error) {
                                        console.log("Error connecting to peripheral: " +error);
                                      } else {
                                        console.log('Connected to peripheral: ' + peripheral.uuid);
                                        peripheral.discoverServices([], function(error, services) {
                                          console.log("Discovering services...");
                                          if (error) {
                                              console.log("ERROR while discovering peripherals: " + error);
                                          } else {
                                              console.log('discovered the following services:');
                                              for (var i in services) {
                                                  //console.log('  ' + i + ' uuid: ' + services[i].uuid);
                                              discoverChars(services[3]);
                                              /*setTimeout(() => {
                                                noble.startScanning([], true);
                                              }, 1000);*/
                                          //peripheral.disconnect();
                                    peripheral.on('disconnect', function() {
                                      process.exit(0);
                                      console.log("Peripheral disconnected. Scanning again!");
                                      noble.startScanning();
                            function discoverChars(service) {
                              service.discoverCharacteristics(null, function(error, characteristics) {
                                //console.log("Characteristics: "+characteristics);
                                for (let i in characteristics) {
                                  var charUUID = characteristics[i].uuid;
                                  console.log('  ' + i + ' uuid: ' + charUUID);
                                  if (characteristics[i].uuid == "a0f0ff0550474d5382084f72616c2d42") {
                                    let j = i;
                                    characteristics[j].on('data', function(data, isNotification) {
                                        console.log("Data: "+data);
                                        var valueInt = data.readInt8(0);
                                        console.log("Battery: "+valueInt+"%");
                                    /*characteristics[j].read(function(error, data) {
                                        if (data) {
                                    characteristics[j].subscribe(function(error) {
                                        if (error !== null) { console.log("error", error); }
                            I guess you can find the same using bluez?
                            If I find the time, I’ll also try out which way works better (for me).
                            Noble or your blues dbus way. I had several issues using noble but it had its charme (like the battery status :-) and only sending data when I activate or deactivate the brush)
                              dfuerst @timodejong95
                              @timodejong95 nice that there was someone realizing this project at the end.
                              tried your app and getting a blank WHITE SCREEN.
                              so maybe u can help me troubleshooting
                              1 cloned via https
                              2 did npm install
                              3 sudo cp MMM.conf
                              4 added conf including MAC (sidenote, white screen with wrong MAC address aswell)
                              5 paired the toothbrush via bluetooth
                              tried to start mirror -> white screen, and whoops message in the log
                              any idea what could cause this? or where to start troubleshooting?
                              • T Offline
                                @lavolp3 Thanks for the code share and great to hear it works. This weekend I will spend some to see if I can fix it, I let you know.
                                @dfuerst Hmm oké, thats weird normally you would see a black screen. Doest the mirror work if you disable the plugin, if so what does the logs say?
                                FYI: I had some issues with my git commits so I deleted and recreated the repo, no worries it’s still under the same url and won’t go away.
                                • lavolp3L Offline
                                  since I really want to have the battery status I am currently trying to use the front end code with noble as backend in node_helper. Your backend code and all the GATT bluez stuff is much too complicated for me.
                                  Also, I have done some tweaks on the frontend:
                                  • Hide timer after some time
                                  • convert time to m:ss
                                  • also count on beyond 2 minutes (circle is filled after 2 Minutes)
                                  • make timer bright and circle blue when the brush is running and dim it back again if it is not running.
                                  Like it very much. Very simple tweaks in the main.js. Let me know if you want to see any of it.
                                  Also, two brushes work perfectly! :ok_hand:
                                  Impressive work man!
                                  • T Offline
                                    timodejong95
                                    Thanks I really appreciate that! Yeah sure I am willing to refactor it a bit, if needed, and make it a configurable option.
                                    Again sorry for deleting the repo, I pushed wit the wrong git user (work one). I saw that you starred/forked it.
                                    Can you show me the changes or make a PR?
                                    The GATT is a bit bugged I am not sure why but the services are not resolving. I am trying to fix that and I think that after that the battery status should be that hard anymore.
                                    • T Offline
                                      timodejong95
                                      • lavolp3L Offline
                                        I can’t PR to your new repo, so here’s the code from MMM-BluetoothDevices.js:
                                        /*jshint esversion: 6 */
                                        //'use strict';
                                        Module.register('MMM-BluetoothDevices', {
                                          // Default module config.
                                          defaults: {
                                            mode: 'le',
                                            hci: 'hci0',
                                            interfaceName: 'org.bluez.Adapter1',
                                            services: [
                                              { type: 'CurrentTimeService' },
                                            devices: [],
                                            layout: {
                                              title: {
                                                position: 'bottom',
                                                key: 'name',
                                              data: {
                                                position: 'bottom',
                                                fields: [
                                                  { key: 'mode', text: 'mode' },
                                            hideAfter: 10 * 60,
                                          getStyles() {
                                            return ['MMM-BluetoothDevices.css'];
                                          // Override dom generator.
                                          getDom() {
                                            const wrapper = document.createElement('div');
                                            wrapper.classList.add('toothbrushes');
                                            if (this.loading) {
                                              wrapper.innerHTML = 'Loading...';
                                              wrapper.className = 'light small';
                                              return wrapper;
                                            const table = document.createElement('table');
                                            const row = document.createElement('tr');
                                            for (const deviceKey in this.devices) {
                                              const deviceType = this.devices[deviceKey].device.type;
                                              if (deviceType === 'OralBToothbrush') {
                                                row.appendChild(this.renderToothbrush(deviceKey));
                                              } else {
                                                throw new Error(`Unknown device type: ${deviceType}`);
                                            table.appendChild(row);
                                            wrapper.appendChild(table);
                                            return wrapper;
                                          renderToothbrush(deviceKey) {
                                            const device = this.devices[deviceKey];
                                            const deviceTd = document.createElement('td');
                                            deviceTd.classList.add('toothbrush');
                                            deviceTd.style.textAlign = "center";
                                            const deviceCircle = document.createElement('div');
                                            deviceCircle.classList.add('toothbrush-circle-container');
                                            deviceCircle.classList.add(`toothbrush-circle-${device.data.state}`);
                                            const deviceCircleText = document.createElement('div');
                                            deviceCircleText.classList.add('toothbrush-circle-text');
                                            const deviceCircleSvg = document.createElementNS('http://www.w3.org/2000/svg', 'svg');
                                            deviceCircleSvg.classList.add('toothbrush-circle-ring');
                                            const deviceCircleSvgCircle = document.createElementNS('http://www.w3.org/2000/svg', 'circle');
                                            deviceCircleSvgCircle.classList.add('toothbrush-circle');
                                            deviceCircleSvgCircle.setAttribute('stroke-width', 15);
                                            deviceCircleSvgCircle.setAttribute('fill', 'transparent');
                                            deviceCircleSvgCircle.setAttribute('r', 52);
                                            deviceCircleSvgCircle.setAttribute('cx', 60);
                                            deviceCircleSvgCircle.setAttribute('cy', 60);
                                            deviceCircleSvg.append(deviceCircleSvgCircle);
                                            deviceCircle.append(deviceCircleSvg);
                                            deviceCircle.append(deviceCircleText);
                                            //const time = device.data.time > 120 ? 120 : device.data.time;
                                            const time = device.data.time;
                                            // initial start
                                            this.updateCircle(deviceCircleSvgCircle, deviceCircleText, time);
                                            if (device.data.state === 'running') {
                                              deviceTd.style.display = 'block';
                                              deviceCircleText.classList.add('bright');
                                              deviceCircleSvgCircle.setAttribute('stroke', '#0080fe');
                                              this.counters[deviceKey] = {
                                                time,
                                                interval: setInterval(() => {
                                                  this.counters[deviceKey].time += 1;
                                                  this.updateCircle(
                                                    deviceCircleText,
                                                }, 1000),
                                            } else {
                                              deviceCircleText.classList.remove("bright");
                                              deviceCircleSvgCircle.setAttribute('stroke', '#aaa');
                                              setInterval(() => {
                                                deviceTd.style.display = "none";
                                              }, this.config.hideAfter * 1000);
                                            const deviceLabel = document.createElement('div');
                                            deviceLabel.classList.add('title');
                                            deviceLabel.classList.add('small');
                                            deviceLabel.innerText = device.device[this.config.layout.title.key];
                                            const dataContainer = document.createElement('div');
                                            dataContainer.classList.add('small');
                                            dataContainer.classList.add('light');
                                            for (const key in this.config.layout.data.fields) {
                                              const data = this.config.layout.data.fields[key];
                                              const field = document.createElement('div');
                                              field.innerText = `${data.key}: ${device.data[data.key]}`;
                                              dataContainer.appendChild(field);
                                            if (this.config.layout.title.position === 'top') {
                                              deviceTd.appendChild(deviceLabel);
                                            if (this.config.layout.data.position === 'top') {
                                              deviceTd.appendChild(dataContainer);
                                            deviceTd.appendChild(deviceCircle);
                                            if (this.config.layout.title.position === 'bottom') {
                                            if (this.config.layout.data.position === 'bottom') {
                                            return deviceTd;
                                          updateCircle(deviceCircleSvgCircle, deviceCircleText, time) {
                                            var secs = time % 60;
                                            deviceCircleText.innerText = Math.floor(time / 60) + ":" + (secs < 10 ? "0" + secs : secs);
                                            const radius = parseInt(deviceCircleSvgCircle.getAttribute('r'));
                                            const circumference = radius * 2 * Math.PI;
                                            if (time > 120) { time = 120; }
                                            const percent = (100 / 120) * time;
                                            const offset = circumference - percent / 100 * circumference;
                                            deviceCircleSvgCircle.style.strokeDasharray = `${circumference} ${circumference}`;
                                            deviceCircleSvgCircle.style.strokeDashoffset = offset;
                                          start() {
                                            Log.info(`Starting module: ${this.name}`);
                                            this.devices = {};
                                            this.counters = {};
                                            this.loading = true;
                                            this.sendSocketNotification('FETCH_TOOTHBRUSHES', this.config);
                                          socketNotificationReceived(notification, payload) {
                                            if (notification === 'FETCH_TOOTHBRUSHES_RESULTS') {
                                              Log.info('MMM-Toothbrush: Got toothbrush results');
                                              this.devices = payload;
                                              for (const counterKey in this.counters) {
                                                const counter = this.counters[counterKey];
                                                clearInterval(counter.interval);
                                              if (this.loading) {
                                                this.loading = false;
                                                this.updateDom(1000);
                                              } else {
                                                this.updateDom(0);
                                        it’s also in the develop branch of my module
                                        • T Offline
                                          timodejong95
                                          @lavolp3 Thanks, I will have a look at that this weekend.
                                          Also managed to connect to the services and characteristics. But how did you know the one you needed?
                                          Because you only connecting to the 3th key in the services array and a hardcoded uuid for the characteristics. I am curious how you find the one you needed.
                                          • lavolp3L Offline
                                            @timodejong95 I used this gitlab snippet. Don’t remember how I got there. I guess from the homeassistant forum which is also working on that.
                                            For more follow-up see my post in this thread
                                            When I use bluetoothctl on my RasPi I am getting lots of output form the brush recently. I’m not sure why exactly, maybe because my Pi is coupled with the brush.
                                            Primary Service
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050
                                                    a0f0ff20-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070
                                                    a0f0ff2b-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070/desc0072
                                                    00002901-0000-1000-8000-00805f9b34fb
                                                    Characteristic User Description
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d
                                                    a0f0ff2a-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d/desc006f
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a
                                                    a0f0ff29-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a/desc006c
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067
                                                    a0f0ff28-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067/desc0069
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064
                                                    a0f0ff27-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064/desc0066
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061
                                                    a0f0ff26-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061/desc0063
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e
                                                    a0f0ff25-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e/desc0060
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b
                                                    a0f0ff24-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b/desc005d
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058
                                                    a0f0ff23-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058/desc005a
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055
                                                    a0f0ff22-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055/desc0057
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051
                                                    a0f0ff21-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0054
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0053
                                                    00002902-0000-1000-8000-00805f9b34fb
                                                    Client Characteristic Configuration
                                            Primary Service
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e
                                                    a0f0ff00-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c
                                                    a0f0ff0d-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004f
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004e
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048
                                                    a0f0ff0c-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004b
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004a
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044
                                                    a0f0ff0b-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0047
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0046
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040
                                                    a0f0ff0a-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0043
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0042
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c
                                                    a0f0ff09-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003f
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003e
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038
                                                    a0f0ff08-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003b
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003a
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034
                                                    a0f0ff07-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0037
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0036
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030
                                                    a0f0ff06-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0033
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0032
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c
                                                    a0f0ff05-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002f
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002e
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028
                                                    a0f0ff04-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002b
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002a
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025
                                                    a0f0ff03-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025/desc0027
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022
                                                    a0f0ff02-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022/desc0024
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f
                                                    a0f0ff01-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f/desc0021
                                            Primary Service
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010
                                                    a0f0fff0-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b
                                                    a0f0fff4-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b/desc001d
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018
                                                    a0f0fff3-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018/desc001a
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015
                                                    a0f0fff2-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015/desc0017
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011
                                                    a0f0fff1-5047-4d53-8208-4f72616c2d42
                                                    Vendor specific
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0014
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0013
                                            Primary Service
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c
                                                    00001801-0000-1000-8000-00805f9b34fb
                                                    Generic Attribute Profile
                                            Characteristic
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d
                                                    00002a05-0000-1000-8000-00805f9b34fb
                                                    Service Changed
                                            Descriptor
                                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d/desc000f
                                            Do we have to look into one of these characteristics/desricptors for the value?
                                            • 2 / 4
