    Unable to click a toggle button
    22 Posts 4 Posters 18.2k Views 3 Watching
      shre28491193
      Got it. Will try this in a few minutes. I am in a meeting at work now.
        shre28491193
        @strawberry-3-141 No errors in the console. :-(
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @shre28491193
          @shre28491193 so you can see the button, but after a click nothing happens?
            shre28491193
            Button shows up on the mirror , but still click event doesnt work.
              shre28491193 @strawberry 3.141
              @strawberry-3.141 Button shows up on the mirror , but still click event doesnt work
                shre28491193
                I removed all unused elements to see if that was hiding anchor tag. Still no luck.
                  @shre28491193 I checked out your repository again and remade the changes I posted and it’s working for me, is your problem that you can’t see the button after clicked or does the click don’t work at all?
                    shre28491193
                    @strawberry-3-141 It is strange that it works for you. I wonder what i am doing different.
                    I am able to see the button on my screen but it does not do anything when clicked on it nor changes the cursor to a pointer.
                    • K Offline
                      KirAsh4 Moderator
                      Hey @strawberry-3-141, have you considered the CSS layers? Could it be possible that something else is overlaid on top of of where the button might be and that’s why @shre28491193 is unable to click on it? I haven’t checked out any of the code nor tried anything, too many things going on at the same time and just too busy, but at the moment, that’s the one thing that came to mind … Set a z-index on the button layer and see what happens.
                        shre28491193
                        @KirAsh4 I did give that a try, still no luck. From my understanding z-index is only valid when you are trying to put your element over all other siblings. I am running that button by just itself.
                        • K Offline
                          KirAsh4 Moderator
                          z-index applies to everything in the DOM element. Just because your button is on a layer all by itself, does not mean there might not be another layer on top of it that you are unaware of. However if you say you tried it (set it to 999?) and no difference, then something else is going on. At the moment I’m just too overloaded with other projects.
                            shre28491193
                            I set it to 999 and still the same issue.
                            No worries , thanks for helping.
                            • cowboysdudeC Offline
                              I did find out that if you load this in a module position that currently has a running module in it then it will not work. If you move it to a module position that has NO other module running in it… it works.
                                shre28491193
                                Atlast it did work. I moved it to a different position and it worked.
                                  shre28491193
                                  Thank you everyone for helping.
                                    Yes it’s the lower_third position it will NOT work in… something is conflicting with it.
