    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 126.0k Views 27 Watching
    • cowboysdudeC
      That’s ok, that’s not a valid API key… That’s the problem.
      Let me explain… you do have an API key but what you need is an Access Token… that’s where the problem is.
      In the config it is asking for the Access token… that’s where we both made a mistake!!! :) It’s all good.
      We got it! :)
      Thanks @kapsolas
        A Former User
          A Former User
          @cowboysdude thanks a lot at 4am almost i can sleep ha ha for 2 hours :/
          Its working, note for others Access Token key is granted here… http://instagram.pixelunion.net/ (when you get to that stage and have created the developer account)0_1477601791572_Screenshot 2016-10-28 03.53.07.png . :
          layout needs tidying up mind but im sure there are some posts on that :)
          • cowboysdudeC
            JUST to clearify for anyone… the module works GREAT!!
            Create the right thing and it’ll work~
            ACCESS TOKEN is NOT your API KEY LOL
              Paninpyos
              Oh, Instagram. How to get all these followers? Sure, I can use services of zen-promo com to find people who are interested in my arts. But may be you can suggest anything?
                A Former User
                Just go with the flow, you pick them up, some have their accounts private (i did to stop prying eyes at my life) but since just opened, and tbf its mainly likes and comments, etc, it wastes time that’s all… don’t take seriously (father does with his sunset photos ha ha)…
                  A Former User
                  More importantly * at all
                  Has anyone played with the css ? how advanced is this module? What’ts it coded in ? Function and Design ?
                  CSS for sure but the rest not looked under the hood, but if anyone can answer i’ll have my in-house dev team do the following for me and share here the source
                  Generic feed (swipe left / right) through feed (20)
                  and popup-view of chosen image.
                  (/uploads/files/1477676198837-instagram-feed-general-resized.jpg)0_1477676379169_Instagram Popup.jpg
                  Simple enough to get done quickly, once i know what it’s made off, and without having to battle the module code or Magic Mirror core code.
                  Many thanks and look forward to some answers.
                  • K
                    kapsolas Module Developer
                    The module is coded in javascript. I started to use some CSS, but did not spend much time on it.
                    I focused on just pulling the image and flipping them them on a timer .This was the goal of my project and I met it.
                    If you want to enhance it, then I am sure you can. I would start by looking at the method that displays the image. This is all done using DOM.
                    ? 1 Reply Last reply
                      A Former User @kapsolas
                      @kapsolas said in MMM-Instagram - Pull and animate photos from Instagram feed:
                      Hi there @kapsolas (not faulting the module at all in the slightest, just trying to get bearing’s (love the module btw), thank’s on the head’s up, Q any particular files that should pay attention too?
                      Once again thanks.
                      • K
                        The file you will want to start to modify is:MMM-Instagram.js
                        This is where the magic happens. The other file node_helper.js is used to handle the “packaging” of the information that the module uses to render the images. It is that file that reaches out to instagram and retrieves the images.
                        In MMM-Instagram.js, you will find a method getDOM. This is where the module is rendering the image by modifying the DOM of the page. It is creating a new DIV and setting up an tag.
                        I believe, you can start from here.
                        Thanks!
                          Jeff @yo-less
                          @yo-less
                          Thanks for your work, but you had a spelling and ; mistakes on the github upload.
                          e.g.: imageWrapper.src = tempimpage.photolink;
                          I got rid of them.
                          https://github.com/jeffjoe/MMM-Instagram
                          • lucallmonL
                            lucallmon
                              BonkingElephant
                              • Y
                                Yurick
                                Hi, this is really nice module, the only problem is it doesn’t update photos from instagram. I managed to make it work properly using setInterval for grabPhotos function AND storing url in a new variable which I used in sendSocketNotification (this.url somehow works only at the first iteraction, then it overwrited by something). Since I could not find the real problem, my code looks ugly but still works. Now it takes couple minutes to display a just taken picture on a mirror.
                                  schnibel
                                  Hi all,
                                  Just a message to share what I did.
                                  I tried to find out why I wasn’t able to display my images using different MMM-Instagram modules (I tried with @kapsolas ’ initial module and yo-less’ and jeffjoe’s forks).
                                  It took me a lot of time to understand it wasn’t compatible with MMM-ProfileSwitcher module (https://github.com/tosti007/MMM-ProfileSwitcher)
                                  If ever you have the same problem, here is a workaround (done from the last JeffJoe’s fork - https://github.com/jeffjoe/MMM-Instagram, but also works with @kapsolas’ one)
                                  So, in MMM-Instagram.js, you just have to comment the line :
                                  this.info.classes = 'bright medium';
                                  //this.info.classes = 'bright medium';
                                  Indeed, it is overwriting a variable that is also used in MMM-ProfileSwitcher. (See in GitHub ProfileSwitcher description, just before the section “Current Supported Languages”. I know it’s not exactly the same thing, but the idea is the same)
                                  I’m not going to create a new fork for this, so guys, I let you manage this.
                                  BTW, yo-less’ fork is still bugged… there is a tempimpage variable instead of temp image
                                  Thanks for the module
                                  • zeularZ
                                    zeular
                                    Hi, I would like to get pictures from two APIs in same module. Is it possible?
                                    • K
                                      The current setup of the module does not allow for pulling from multiple locations (API)
                                      • zeularZ
                                        zeular
                                        Okay, but is it possible? Anything you could implement? I would like to be able to get in family photos in chronological order. :)
                                        K 1 Reply Last reply
                                        • K
                                          kapsolas Module Developer @zeular
                                          @zeular I suppose that this could be implemented. The module could be updated to make multiple requests to various sources.
                                          Given my current availability, this would not be something I can do in the near future.
                                          zeularZ 1 Reply Last reply
                                          • zeularZ
                                            zeular @kapsolas
                                            @kapsolas I understand, but if you had time over, I would be grateful.
                                            Thank’s anyway, for taking your time and reply.
                                            • 3 / 5
