    Display the modules exactly on the screen? Define X and Y Coordinate in config.js file?
    6 Posts 4 Posters 1.3k Views 4 Watching
      pi-user
      Hello everybody,
      is there a way to display the modules exactly on the screen? For example:
      The config.js file should look like this:
      Module 1:
      size:
      Coordinate:
               x:
               y:
      Module 2:
      size:
      Coordinate:
               x:
               y:
      Many thanks for your help.
        retroflex Project Sponsor Module Developer
        Should be possible through css. Haven’t tried this myself, but it should work:
        .clock {
          position: absolute;
          left : 400px;
          top : 100px;
        Add it to MagicMirror/css/custom.css
        I think you can use right and bottom instead of left and top also.
        P lavolp3L 2 Replies Last reply Reply Quote 0
          sdetweil @pi-user
          @pi-user there is no built in support… the design is a bunch of different areas, and the content should NOT be screen location specific…
          see the index.html for the css area layout
          each area is a stack, 1st in config.js in that area at the top of that area, next under it, next under that…
            pi-user @retroflex
            @retroflex Thank you for your answer
              pi-user @sdetweil
              @sdetweil Thank you very much
              • lavolp3L Offline
                lavolp3 Module Developer @retroflex
                @retroflex @pi-user
                .clock {
                position: absolute;
                left : 400px;
                top : 100px;
                That will fail if a parent element is set to position: relative.
                Then this element will arrange itself absolutely INSIDE the parent element/region.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
