Display the modules exactly on the screen? Define X and Y Coordinate in config.js file?
Hello everybody,
is there a way to display the modules exactly on the screen? For example:
The config.js file should look like this:
Module 1:
size:
Coordinate:
x:
y:Module 2:
size:
Coordinate:
x:
y:Many thanks for your help.
Should be possible through css. Haven’t tried this myself, but it should work:
.clock { position: absolute; left : 400px; top : 100px; }Add it to MagicMirror/css/custom.css
I think you can use right and bottom instead of left and top also.
@pi-user there is no built in support… the design is a bunch of different areas, and the content should NOT be screen location specific…
see the index.html for the css area layout
each area is a stack, 1st in config.js in that area at the top of that area, next under it, next under that…
@retroflex Thank you for your answer
@sdetweil Thank you very much
.clock {
position: absolute;
left : 400px;
top : 100px;
Add it to MagicMirror/css/custom.cssI think you can use right and bottom instead of left and top also.
That will fail if a parent element is set toposition: relative.
Then this element will arrange itself absolutely INSIDE the parent element/region.
