Monitor saying 'No Signal'
6 Posts 3 Posters 3.2k Views 3 Watching
  • O Offline
    Officeglen
    Ok gents a bit of a ramble here.
    The other night I finished everything I wanted module wise so i was going to start on hardware (i.e taking monitor out of frame etc) After I took the monitor out of the frame and plugged it in to my Pi I noticed the screen was saying ‘no signal.’ I started to panic as the control for the monitor popped out of the socket so I was worried I just pissed a $150 monitor down the drain. I decide to try my PC monitor and lo and behold I get the same thing… I plug in my future MagicMirror Monitor to my PC and guess what… It works like a charm.
    This obviously means something else is wrong…I am literally not at all a computer guy. I took my SD card out and plugged into my computer and I see all the files so that means that is not corrupted/dead right? So it must be the R Pi3 itself? The Pi lights up when I put power to it and everyhting…I tried using both the DVI and HDMI port on the R Pi3
    Help would be greatly appreciated.
      Cato Module Developer
      You’ve probably already checked it, but be sure the SD card really is inserted in the Pi. It happened to me a couple of times…
        bhepler Module Developer
        When the Pi is plugged in, can you SSH to it?
        O 1 Reply Last reply Oct 29, 2016, 5:07 PM Reply Quote 0
        • O Offline
          Officeglen @bhepler
          @bhepler I dont think i set that up when i installed everything because I didnt think I would ever use that…
            Maybe I remember wrong, but I think SSH is turned on as default when you set up the RPi (Jessey)…?
            O 1 Reply Last reply Oct 29, 2016, 6:26 PM Reply Quote 0
            • O Offline
              Officeglen @Cato
              @Cato
              I will look into this thanks
