    MMM-GooglePhotos
    294 Posts 56 Posters 418.1k Views 59 Watching
      sdetweil @Samwise
      @Samwise said in MMM-GooglePhotos:
      libgconf-2.so.4:
      try this from a terminal window
      sudo apt-get install libgconf-2-4
      magicmirror@2.7.1
      version 2.7.1 is pretty old…
      edit the package.json file and change
      "start","sh run-start.sh"
      to
      "start"."sh ./run-start.sh"
      check to see if run-start.sh is in the ~/MagicMirror folder, if not then do
      cule -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
      chmod +x run-start.sh
      • G
        gonzonia
        The new info box is not aligning correctly for me. It’s showing mostly off the screen.
        Screenshot
        ? 1 Reply Last reply
          A Former User @gonzonia
          @gonzonia
          Show me your configuration of MMM-GooglePhotos.
          G 2 Replies Last reply
          • O
            orayoflighto Project Sponsor
            I just updated to the latest And my photos stopped displaying. Anyone else have this issue?
            I just get Loading…
            S Z O 3 Replies Last reply
              sdetweil @orayoflighto
              @orayoflighto open the developers window ctrl-shift-i on the keyboard, select the console tab and scroll up for any errors
              did u also run npm install in the MMM-GooglePhotos folder?
              • G
                gonzonia @Guest
                @Sean I commented out autoInfoPosition because it seemed to break when I turned that on. The showWidth/showHeight match the screen resolution showing on the dekstop.
                  			module: "MMM-GooglePhotos",
                			position: "fullscreen_below",
                			albums: ["NixPlay","MM-Family2"], // Set your album name. like ["My wedding", "family share", "Travle to Paris"]
                			updateInterval: 1000 * 60, // minimum 10 seconds.
                			sort: "random", // "old", "random"
                			uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
                			condition: {
                				fromDate: null, // Or "2018-03", RFC ... format available
                				toDate: null, // Or "2019-12-25",
                				minWidth: null, // Or 400
                				maxWidth: null, // Or 8000
                				minHeight: null, // Or 400
                				maxHeight: null, // Or 8000
                				minWHRatio: null,
                				maxWHRatio: null,
                				// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   < 1 : Portraited Photo, > 1 : Landscaped Photo)
                			showWidth: 1680, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
                			showHeight: 1050,
                			timeFormat: "relative", //"YYYY/MM/DD HH:mm", // Or `relative` can be used.
                			//autoInfoPosition: true,
                • K
                  Kevinho195
                  Hi @Sean,
                  thanks for the great update. I want to hide the blurred background and did add
                  GPHOTO_BACK {
                  	display:none;
                  #GPHOTO_INFO {
                  	display:none;
                  to my custom.css but it the blurred background is still there. For the info tab it did work and it disappeared. What am I missing?
                    A Former User @Kevinho195
                    @Kevinho195
                    You’ve missed #
                    K 1 Reply Last reply
                    • G
                      gonzonia @Guest
                      @Sean Any idea what’s going on with the info box?
                      G 1 Reply Last reply
                      • K
                        Kevinho195 @Guest
                        @Sean sorry that was a copy/paste mistake. In my Custom CSS there is “#” in front of GPHOTO_Back. Anything else I could miss?
                        • G
                          gonzonia @gonzonia
                          Just a note. I added
                          #GPHOTO_INFO {
                          margin:100px;
                          And the box shows now. The autoInfoPosition seems to be working now too. Don’t know what happened when I first tried it.
                          Thanks.
                            rinkymehra
                            Awesome! Happy to see that this was created as a module.
                            • E
                              el_georgie
                              I have to comment out // autoInfoPosition: true,… if not it just says loading and never does, and it does not move either. Otherwise, great update! Love the changes.
                              R 1 Reply Last reply
                              • G
                                gonzonia
                                I’m loving the Info Box addition now that it shows. I’ve hid the album cover and title because I’m not that organized.
                                I like how autoInfoPosition allows it to move around to prevent burn-in.
                                2 requests-
                                1. A way to select which corners it shows in.
                                  I have other modules in top left and right that overlap with the info box. It would work better if it would just go back and forth on the bottom left and right.
                                  I don’t think it would be hard to implement, (but I’m not a JS expert). I think if you changed the autoInfoPosition property to be a list (top left, top right, bottom left, bottom right) instead of a boolean and then based on the list you could populate the array with the necessary locations.
                                2. A way to control the format of the date (X years ago). I’d prefer to see the actual date of the photo.
                                Sorry if I’m out of line. This is one of the favorite modules in my house.
                                Thanks.
                                  rinkymehra @el_georgie
                                  @el_georgie said in MMM-GooglePhotos:
                                  Yes you are right ] tubemate mobdro
                                    @gonzonia
                                    You can locate it by CSS. I wrote some example on tip section. read the readme
                                    It could also be controllable by configuration. Read the readme again.
                                    • G
                                      gonzonia @Guest
                                      @Sean thanks. Will do.
                                      • G
                                        gonzonia @Guest
                                        @Sean Totally forgot the date formatting (took me a while to see the infobox and I’d forgotten that was in the config). Thanks for pointing that out.
                                        With the location of the infobox though I’d still like it to move around to prevent burn-in. If I set the position in CSS it’s static. That’s why I was looking at trying a different way. Can I use the callbackfunction to set multiple locations? I’d like it to go back and forth between bottom left and right. I tried modifying the Tip code you had so that the CSS would do that, but it doesn’t seem to be working. I can tweak JS a lot better than I can tweak CSS.
                                        • Z
                                          zolabus @orayoflighto
                                          @orayoflighto Same problem for me did you find any solution? Always Loading…after last update
                                          Z 1 Reply Last reply
                                          • Z
                                            zolabus @zolabus
                                            @zolabus
                                            My config is
                                              position: 'middle_center',
                                                albums: ["Noi"],
                                                sort: "random",
                                                showWidth: "426px",
                                                showHeight: "320px"
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
