    MMM-GooglePhotos
    294 Posts 56 Posters 373.0k Views 59 Watching
    • K Offline
      Kevinho195
      Hi @Sean,
      thanks for the great update. I want to hide the blurred background and did add
      GPHOTO_BACK {
      	display:none;
      #GPHOTO_INFO {
      	display:none;
      to my custom.css but it the blurred background is still there. For the info tab it did work and it disappeared. What am I missing?
        A Former User @Kevinho195
        @Kevinho195
        You’ve missed #
        • G Offline
          gonzonia @Guest
          @Sean Any idea what’s going on with the info box?
          • K Offline
            Kevinho195 @Guest
            @Sean sorry that was a copy/paste mistake. In my Custom CSS there is “#” in front of GPHOTO_Back. Anything else I could miss?
            • G Offline
              gonzonia @gonzonia
              Just a note. I added
              #GPHOTO_INFO {
              margin:100px;
              And the box shows now. The autoInfoPosition seems to be working now too. Don’t know what happened when I first tried it.
              Thanks.
                rinkymehra
                Awesome! Happy to see that this was created as a module.
                • E Offline
                  el_georgie
                  I have to comment out // autoInfoPosition: true,… if not it just says loading and never does, and it does not move either. Otherwise, great update! Love the changes.
                  • G Offline
                    gonzonia
                    I’m loving the Info Box addition now that it shows. I’ve hid the album cover and title because I’m not that organized.
                    I like how autoInfoPosition allows it to move around to prevent burn-in.
                    2 requests-
                    1. A way to select which corners it shows in.
                      I have other modules in top left and right that overlap with the info box. It would work better if it would just go back and forth on the bottom left and right.
                      I don’t think it would be hard to implement, (but I’m not a JS expert). I think if you changed the autoInfoPosition property to be a list (top left, top right, bottom left, bottom right) instead of a boolean and then based on the list you could populate the array with the necessary locations.
                    2. A way to control the format of the date (X years ago). I’d prefer to see the actual date of the photo.
                    Sorry if I’m out of line. This is one of the favorite modules in my house.
                    Thanks.
                      rinkymehra @el_georgie
                      @el_georgie said in MMM-GooglePhotos:
                      Yes you are right ] tubemate mobdro
                        A Former User @gonzonia
                        @gonzonia
                        You can locate it by CSS. I wrote some example on tip section. read the readme
                        It could also be controllable by configuration. Read the readme again.
                        G 2 Replies Last reply Reply Quote 0
                        • G Offline
                          gonzonia @Guest
                          @Sean thanks. Will do.
                          • G Offline
                            gonzonia @Guest
                            @Sean Totally forgot the date formatting (took me a while to see the infobox and I’d forgotten that was in the config). Thanks for pointing that out.
                            With the location of the infobox though I’d still like it to move around to prevent burn-in. If I set the position in CSS it’s static. That’s why I was looking at trying a different way. Can I use the callbackfunction to set multiple locations? I’d like it to go back and forth between bottom left and right. I tried modifying the Tip code you had so that the CSS would do that, but it doesn’t seem to be working. I can tweak JS a lot better than I can tweak CSS.
                            • Z Offline
                              zolabus @orayoflighto
                              @orayoflighto Same problem for me did you find any solution? Always Loading…after last update
                              Z 1 Reply Last reply Reply Quote 0
                              • Z Offline
                                zolabus @zolabus
                                @zolabus
                                My config is
                                  module: "MMM-GooglePhotos",
                                  position: 'middle_center',
                                    albums: ["Noi"],
                                    updateInterval: 1000 * 60,
                                    sort: "random",
                                    showWidth: "426px",
                                    showHeight: "320px"
                                  sdetweil @zolabus
                                  @zolabus please use the markup around config, or code
                                  triple backtic (on US keyboard to left of the 1 key) on a separate line before and after
                                    @gonzonia
                                    autoInfoPosition: can have callback function to adjust the position.
                                    By default, GPHOTO_INFO would have these value;
                                    #GPHOTO_INFO {
                                      position:absolute;
                                      top: var(--top);
                                      left: var(--left);
                                      bottom: var(--bottom);
                                      right: var(--right);
                                      margin:10px;
                                    so if your callback autoInfoPosition(album, photo) might return ['10px', '10px', 'none', 'none'], it will be the same with;
                                    #GPHOTO_INFO {
                                      position:absolute;
                                      top:  10px;
                                      left:  10px;
                                      bottom: none;
                                      right: none;
                                      margin:10px;
                                    You can add some randomized generated value as returns per photo, It will be a help.
                                    • Z Offline
                                      zolabus @sdetweil
                                      @sdetweil Sorry I don’t understand if is a suggestion for my problem or how to post…
                                        sdetweil @zolabus
                                        @zolabus how to post
                                        • G Offline
                                          gonzonia @Guest
                                          @Sean Thanks. I think I have it working. Here’s what I used.
                                          autoInfoPosition: (album, photo)=> {
                                          					var boolRightLeft= Math.floor(Math.random() * 2);
                                          					if (boolRightLeft == 1) {
                                          						return ['none', '0', '0', 'none'] // This will show photo info bottom-left corner.
                                          					}else{
                                          						return ['none', 'none', '0', '0'] // This will show photo info bottom-right corner.
                                            roccodicarlo
                                            This new version works great. Thanks for all your effort. Is it possible to rotate the photo (similar to rotation of sticky on MMM-Memo) so that it looks like a photo on a cork board. I would like to rotate it ± 20 degrees.
                                            Z 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
