    MMM-GooglePhotos
    294 Posts 56 Posters 370.5k Views 59 Watching
    • G Offline
      gonzonia @Guest
      @Sean thanks. Will do.
      • G Offline
        gonzonia @Guest
        @Sean Totally forgot the date formatting (took me a while to see the infobox and I’d forgotten that was in the config). Thanks for pointing that out.
        With the location of the infobox though I’d still like it to move around to prevent burn-in. If I set the position in CSS it’s static. That’s why I was looking at trying a different way. Can I use the callbackfunction to set multiple locations? I’d like it to go back and forth between bottom left and right. I tried modifying the Tip code you had so that the CSS would do that, but it doesn’t seem to be working. I can tweak JS a lot better than I can tweak CSS.
        • Z Offline
          zolabus @orayoflighto
          @orayoflighto Same problem for me did you find any solution? Always Loading…after last update
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            zolabus @zolabus
            @zolabus
            My config is
              module: "MMM-GooglePhotos",
              position: 'middle_center',
                albums: ["Noi"],
                updateInterval: 1000 * 60,
                sort: "random",
                showWidth: "426px",
                showHeight: "320px"
              sdetweil @zolabus
              @zolabus please use the markup around config, or code
              triple backtic (on US keyboard to left of the 1 key) on a separate line before and after
                A Former User @gonzonia
                @gonzonia
                autoInfoPosition: can have callback function to adjust the position.
                By default, GPHOTO_INFO would have these value;
                #GPHOTO_INFO {
                  position:absolute;
                  top: var(--top);
                  left: var(--left);
                  bottom: var(--bottom);
                  right: var(--right);
                  margin:10px;
                so if your callback autoInfoPosition(album, photo) might return ['10px', '10px', 'none', 'none'], it will be the same with;
                #GPHOTO_INFO {
                  position:absolute;
                  top:  10px;
                  left:  10px;
                  bottom: none;
                  right: none;
                  margin:10px;
                You can add some randomized generated value as returns per photo, It will be a help.
                • Z Offline
                  zolabus @sdetweil
                  @sdetweil Sorry I don’t understand if is a suggestion for my problem or how to post…
                    sdetweil @zolabus
                    @zolabus how to post
                    • G Offline
                      gonzonia @Guest
                      @Sean Thanks. I think I have it working. Here’s what I used.
                      autoInfoPosition: (album, photo)=> {
                      					var boolRightLeft= Math.floor(Math.random() * 2);
                      					if (boolRightLeft == 1) {
                      						return ['none', '0', '0', 'none'] // This will show photo info bottom-left corner.
                      					}else{
                      						return ['none', 'none', '0', '0'] // This will show photo info bottom-right corner.
                        roccodicarlo
                        This new version works great. Thanks for all your effort. Is it possible to rotate the photo (similar to rotation of sticky on MMM-Memo) so that it looks like a photo on a cork board. I would like to rotate it ± 20 degrees.
                        Z 2 Replies Last reply Reply Quote 0
                        • Z Offline
                          zolabus @roccodicarlo
                          • Z Offline
                            @roccodicarlo did you reinstall everything? Because I have loading…forever…
                              roccodicarlo
                              Yes I reinstalled everything
                                roccodicarlo
                                @Sean How would it be possible to run multiple instances so that I can have two picture frames displayed?
                                  A Former User @roccodicarlo
                                  @roccodicarlo
                                  Sorry, impossible. Not designed for that.
                                  • Z Offline
                                    @roccodicarlo ok thanks included all the steps for the google autenthication?
                                    • Z Offline
                                      zolabus
                                      @Sean I reinstall everything and done again google authentication but I still have Loading…and nothing loads…
                                      Some suggestions?
                                        A Former User @zolabus
                                        @zolabus
                                        • Show me your configuration
                                        • What log says?
                                        • How much albums and photos in your account?
                                        • Z Offline
                                          zolabus @Guest
                                          @Sean
                                          module: “MMM-GooglePhotos”,
                                          position: “middle_center”,
                                          albums: [“Noi”, “2019 New York”],
                                          sort: “random”,
                                          showWidth: “426px”,
                                          showHeight: “320px”
                                          Only 2 albums, I don’t know how to read the logs…
                                          • Z Offline
                                            zolabus @zolabus
                                            @Sean Any news for me? Still not working
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
