    MMM-COVID19-SPARKLINE
    Scheduled Pinned Locked Moved Health
    29 Posts 16 Posters 14.7k Views 14 Watching
      skelliam @bhepler
      @bhepler Thanks, that is exactly correct! Any country can be specified so long as it is in the Johns Hopkins data.
        cyberphox
        Getting this error when I try to run npm install
        npm ERR! code Z_DATA_ERROR
        npm ERR! errno -3
        npm ERR! zlib: invalid distance too far back
        Actually getting that error when trying to install MMM-Screencast as well.
        Running my MM in serveronly in a docker on my Synology NAS
          skelliam @cyberphox
          @cyberphox It seems you need to update the system zlib. See here: https://github.com/nodejs/node/issues/22839
            cyberphox @skelliam
            @skelliam Turns out installing a Synology package also installed Nodejs v12 which npm doesn’t like much…uninstalled both and error has disappeared…Thanks!
              MisterT
              Hi everybody,
              just a question about countries.
              It is possible to add France ? or is too complicated ?
              take care of yourself :winking_face:
              rafaelcotaR 1 Reply Last reply Reply Quote 1
              • StoffbeuteluweS Offline
                Stoffbeuteluwe Project Sponsor
                No Problem add “France” to your country’s in the config that’s it.
                • rafaelcotaR Offline
                  rafaelcota @MisterT
                  @MisterT Just add France to the list of countries in config
                  alt text
                    skelliam @cyberphox
                    Glad you got it worked out @cyberphox!
                      Sparkie579 @bhepler
                      @bhepler Thank you for your help. It works now.
                        Beh
                        Awesome module! Thank you so much! I was just browsing around on this forum and immediately installed it. Good work.
                          darbos @skelliam
                          @skelliam is there a way to do it by state?
                          • X Offline
                            x5nder
                            On a wider display, there is a small layout issue. The two sparkline graphs are left-aligned while all other content and titles are right-aligned. Is there an easy way to fix this?
                              skelliam @x5nder
                              @x5nder Can you post a screenshot?
                              X 1 Reply Last reply Reply Quote 0
                                skelliam @darbos
                                @darbos if I remember correctly, Johns Hopkins has a different table for US states, so at the moment I’m only loading the country-based table.
                                • X Offline
                                  x5nder @skelliam
                                  @skelliam I took a quick photo of the screen. The SPARKLINE tracker is the middle column of MagicMirror (top-center).
                                    cyberphox
                                      requiemmg
                                      HI,
                                      have been using this for a while now, nice work.
                                      I used this on my starting page on my Mirror (i use multiple pages).
                                      And I wondered, why another module (MMM-AVStock) did not draw its graphs.
                                      Just learned that if you use 2 modules which use highline, one will not work, unfortunately.
                                      Just FYI if someone else runs into this experience.
                                      (https://github.com/lavolp3/MMM-AVStock/issues/40)
                                      All credits for finding this to lavlop3!
                                        badpac
                                        how can i change the language?
                                        how can i delete delta vs daily and delta plot?
                                        thanks and take care
                                          badpac @badpac
                                          • JerryPJ Offline
                                            JerryP @skelliam
                                            @skelliam
                                            I have one issue.
                                            DevTools failed to parse SourceMap: http://localhost:8080/modules/MMM-COVID19-SPARKLINE/lib/highcharts.js.map
                                            Is showing up on the DevTools. log
