    Trividar's MagicMirror
    25 Posts 12 Posters 62.1k Views 13 Watching
    • T Offline
      trividar @Patrick
      @Patrick just ask on their website Glas-Trösch for the price. Where are you from?
        Patrick @trividar
          bhepler Module Developer
          That has to be the cleanest, most organized back of a magic mirror here. Looks great.
            PaulB
            @trividar Fantastic work. :) I am very interested in your multiswitch for powering the monitor and pi. Where did you get it from? Ive searched a little bit in the web, but could not find an accurate product.
            I use the same Euro power cable.
            Greetings from Germany.
              Sillec123
              What is the name of the Ikea frame?
              • T Offline
                trividar @PaulB
                @PaulB Thank you!
                I bought this one: Max Hauri Klappstecker Clip-Clap 3 ×.
                @Sillec123 Hi…IKEA HOVET mirror
                Greetings from Switzerland.
                  PaulB
                  @trividar thanks for answering :) Just bought it :D
                    done @PaulB
                    @PaulB
                    Are you sure that the Switzerland version is the right to use?
                    You should go for “Euro Stecker flach” like this:
                    http://picclick.de/GAO-Euro-Steckdosenleiste-4-fach-flach-15-m-Kabel-181929247191.html
                    At least, if you are using german connectors.
                      PaulB
                      @trividar Maybe this is a dumb question but you are using an EURO to C13 to power your acer-screen. Do you have also 230 V in Switzerland?
                      I can’t find this setup to power my acer screen here in Germany (web/conrad electronics/amazon/ebay …), so I would as you if its possible to buy just a swiss version of the powercable?
                      I am just concered of the overpowering which could turn into a fire in my flat :D
                        PaulB
                        @done oh boy, I could kiss you for that :D thanks!
                          Sillec123
                          Thanks, have you cut the frame with a water cut? Or how have you make it so perfect?
                          • T Offline
                            trividar @Sillec123
                            @Sillec123 no, just with a normal circular table saw.
                              Johans @trividar
                              @trividar
                              can you tell me how I can start a fan running when pi cpu is > 70°C and off when lower.
                              What program did you use, was this a separate module for the MM?
                              • Y Offline
                                yawns Moderator @Johans
                                @Johans
                                You could use this: https://www.npmjs.com/package/rpi-fan-controller
                                Or this: https://hackernoon.com/raspberry-pi-temperature-controlled-fan-2aa0de72a564
                                And I am pretty sure, there are more tutorials/scripts out there :)
                                • DæmonEyesD Offline
                                  DæmonEyes @gshimself
                                  @gshimself It has always confused me to no end, that ‘one-way mirror’ is also called the ‘two-way mirror’. What were they thinking??
                                    bhepler Module Developer @DæmonEyes
                                    @dæmoneyes - It’s probably another genius idea from the same guys who made “flammable” and “inflammable” mean the same thing.
