    MMM-OralB / Bluetooth equipped toothbrush integration
    68 Posts 13 Posters 43.3k Views 20 Watching
    • T
      timodejong95
      I have tweaked the code a bit towards better exception handling, this might be helpful for you
        djerik
        Works great with my Oral B 9000!
        Notes:
        • I had to change the git clone to https instead of git clone git@github.com:timodejong95/MMM-BluetoothDevices.git
        • Copying the file MMM.conf requires administrative rights
        • I used bluetoothctl to find the MAC of the toothbrush
        • T
          timodejong95 @djerik
          @djerik Nice! Good to hear, and thanks for the feedback I will update the readme where needed!
          lavolp3L D 2 Replies Last reply Reply Quote 0
          • lavolp3L
            lavolp3 Module Developer @timodejong95
            @timodejong95 Hi Timo, it works for me now as well. Very good!
            So now let’s go for the holy grail! The battery status.
            It is there and I managed to get it out using noble. Don’t ask me how. Lol.
            Find the code below where I meddled with Advertisements and Characteristics:
            noble.on('discover', function(peripheral) {
              var ad = peripheral.advertisement || "";
              if (ad.localName == "Oral-B Toothbrush") {
                //console.log('Found device with local name: ' + ad.localName);
                //console.log('advertising the following service uuid\'s: ' + ad.serviceUuids);
                //console.log("ID: "+peripheral.id);
                //console.log("Advertisement: "+ad);
                if (ad.manufacturerData) {
                    console.log('Found OralB Toothbrush with ID: ' + peripheral.id);
                    console.log('ManufacturerData: '+ad.manufacturerData.toString('hex'));
                    //noble.stopScanning();
                    peripheral.connect(function(error) {
                      if (error) {
                        console.log("Error connecting to peripheral: " +error);
                      } else {
                        console.log('Connected to peripheral: ' + peripheral.uuid);
                        peripheral.discoverServices([], function(error, services) {
                          console.log("Discovering services...");
                          if (error) {
                              console.log("ERROR while discovering peripherals: " + error);
                          } else {
                              console.log('discovered the following services:');
                              for (var i in services) {
                                  //console.log('  ' + i + ' uuid: ' + services[i].uuid);
                              discoverChars(services[3]);
                              /*setTimeout(() => {
                                noble.startScanning([], true);
                              }, 1000);*/
                          //peripheral.disconnect();
                    peripheral.on('disconnect', function() {
                      process.exit(0);
                      console.log("Peripheral disconnected. Scanning again!");
                      noble.startScanning();
            function discoverChars(service) {
              service.discoverCharacteristics(null, function(error, characteristics) {
                //console.log("Characteristics: "+characteristics);
                for (let i in characteristics) {
                  var charUUID = characteristics[i].uuid;
                  console.log('  ' + i + ' uuid: ' + charUUID);
                  if (characteristics[i].uuid == "a0f0ff0550474d5382084f72616c2d42") {
                    let j = i;
                    characteristics[j].on('data', function(data, isNotification) {
                        console.log("Data: "+data);
                        var valueInt = data.readInt8(0);
                        console.log("Battery: "+valueInt+"%");
                    /*characteristics[j].read(function(error, data) {
                        if (data) {
                    characteristics[j].subscribe(function(error) {
                        if (error !== null) { console.log("error", error); }
            I guess you can find the same using bluez?
            If I find the time, I’ll also try out which way works better (for me).
            Noble or your blues dbus way. I had several issues using noble but it had its charme (like the battery status :-) and only sending data when I activate or deactivate the brush)
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              dfuerst @timodejong95
              @timodejong95 nice that there was someone realizing this project at the end.
              tried your app and getting a blank WHITE SCREEN.
              so maybe u can help me troubleshooting
              1 cloned via https
              2 did npm install
              3 sudo cp MMM.conf
              4 added conf including MAC (sidenote, white screen with wrong MAC address aswell)
              5 paired the toothbrush via bluetooth
              tried to start mirror -> white screen, and whoops message in the log
              any idea what could cause this? or where to start troubleshooting?
              • T
                timodejong95 @lavolp3
                @lavolp3 Thanks for the code share and great to hear it works. This weekend I will spend some to see if I can fix it, I let you know.
                @dfuerst Hmm oké, thats weird normally you would see a black screen. Doest the mirror work if you disable the plugin, if so what does the logs say?
                FYI: I had some issues with my git commits so I deleted and recreated the repo, no worries it’s still under the same url and won’t go away.
                • lavolp3L
                  since I really want to have the battery status I am currently trying to use the front end code with noble as backend in node_helper. Your backend code and all the GATT bluez stuff is much too complicated for me.
                  Also, I have done some tweaks on the frontend:
                  • Hide timer after some time
                  • convert time to m:ss
                  • also count on beyond 2 minutes (circle is filled after 2 Minutes)
                  • make timer bright and circle blue when the brush is running and dim it back again if it is not running.
                  Like it very much. Very simple tweaks in the main.js. Let me know if you want to see any of it.
                  Also, two brushes work perfectly! :ok_hand:
                  Impressive work man!
                  • T
                    timodejong95
                    Thanks I really appreciate that! Yeah sure I am willing to refactor it a bit, if needed, and make it a configurable option.
                    Again sorry for deleting the repo, I pushed wit the wrong git user (work one). I saw that you starred/forked it.
                    Can you show me the changes or make a PR?
                    The GATT is a bit bugged I am not sure why but the services are not resolving. I am trying to fix that and I think that after that the battery status should be that hard anymore.
                    • T
                      timodejong95
                      • lavolp3L
                        I can’t PR to your new repo, so here’s the code from MMM-BluetoothDevices.js:
                        /*jshint esversion: 6 */
                        //'use strict';
                        Module.register('MMM-BluetoothDevices', {
                          // Default module config.
                          defaults: {
                            mode: 'le',
                            hci: 'hci0',
                            interfaceName: 'org.bluez.Adapter1',
                            services: [
                              { type: 'CurrentTimeService' },
                            devices: [],
                            layout: {
                              title: {
                                position: 'bottom',
                                key: 'name',
                              data: {
                                position: 'bottom',
                                fields: [
                                  { key: 'mode', text: 'mode' },
                            hideAfter: 10 * 60,
                          getStyles() {
                            return ['MMM-BluetoothDevices.css'];
                          // Override dom generator.
                          getDom() {
                            const wrapper = document.createElement('div');
                            wrapper.classList.add('toothbrushes');
                            if (this.loading) {
                              wrapper.innerHTML = 'Loading...';
                              wrapper.className = 'light small';
                              return wrapper;
                            const table = document.createElement('table');
                            const row = document.createElement('tr');
                            for (const deviceKey in this.devices) {
                              const deviceType = this.devices[deviceKey].device.type;
                              if (deviceType === 'OralBToothbrush') {
                                row.appendChild(this.renderToothbrush(deviceKey));
                              } else {
                                throw new Error(`Unknown device type: ${deviceType}`);
                            table.appendChild(row);
                            wrapper.appendChild(table);
                            return wrapper;
                          renderToothbrush(deviceKey) {
                            const device = this.devices[deviceKey];
                            const deviceTd = document.createElement('td');
                            deviceTd.classList.add('toothbrush');
                            deviceTd.style.textAlign = "center";
                            const deviceCircle = document.createElement('div');
                            deviceCircle.classList.add('toothbrush-circle-container');
                            deviceCircle.classList.add(`toothbrush-circle-${device.data.state}`);
                            const deviceCircleText = document.createElement('div');
                            deviceCircleText.classList.add('toothbrush-circle-text');
                            const deviceCircleSvg = document.createElementNS('http://www.w3.org/2000/svg', 'svg');
                            deviceCircleSvg.classList.add('toothbrush-circle-ring');
                            const deviceCircleSvgCircle = document.createElementNS('http://www.w3.org/2000/svg', 'circle');
                            deviceCircleSvgCircle.classList.add('toothbrush-circle');
                            deviceCircleSvgCircle.setAttribute('stroke-width', 15);
                            deviceCircleSvgCircle.setAttribute('fill', 'transparent');
                            deviceCircleSvgCircle.setAttribute('r', 52);
                            deviceCircleSvgCircle.setAttribute('cx', 60);
                            deviceCircleSvgCircle.setAttribute('cy', 60);
                            deviceCircleSvg.append(deviceCircleSvgCircle);
                            deviceCircle.append(deviceCircleSvg);
                            deviceCircle.append(deviceCircleText);
                            //const time = device.data.time > 120 ? 120 : device.data.time;
                            const time = device.data.time;
                            // initial start
                            this.updateCircle(deviceCircleSvgCircle, deviceCircleText, time);
                            if (device.data.state === 'running') {
                              deviceTd.style.display = 'block';
                              deviceCircleText.classList.add('bright');
                              deviceCircleSvgCircle.setAttribute('stroke', '#0080fe');
                              this.counters[deviceKey] = {
                                time,
                                interval: setInterval(() => {
                                  this.counters[deviceKey].time += 1;
                                  this.updateCircle(
                                    deviceCircleText,
                                }, 1000),
                            } else {
                              deviceCircleText.classList.remove("bright");
                              deviceCircleSvgCircle.setAttribute('stroke', '#aaa');
                              setInterval(() => {
                                deviceTd.style.display = "none";
                              }, this.config.hideAfter * 1000);
                            const deviceLabel = document.createElement('div');
                            deviceLabel.classList.add('title');
                            deviceLabel.classList.add('small');
                            deviceLabel.innerText = device.device[this.config.layout.title.key];
                            const dataContainer = document.createElement('div');
                            dataContainer.classList.add('small');
                            dataContainer.classList.add('light');
                            for (const key in this.config.layout.data.fields) {
                              const data = this.config.layout.data.fields[key];
                              const field = document.createElement('div');
                              field.innerText = `${data.key}: ${device.data[data.key]}`;
                              dataContainer.appendChild(field);
                            if (this.config.layout.title.position === 'top') {
                              deviceTd.appendChild(deviceLabel);
                            if (this.config.layout.data.position === 'top') {
                              deviceTd.appendChild(dataContainer);
                            deviceTd.appendChild(deviceCircle);
                            if (this.config.layout.title.position === 'bottom') {
                            if (this.config.layout.data.position === 'bottom') {
                            return deviceTd;
                          updateCircle(deviceCircleSvgCircle, deviceCircleText, time) {
                            var secs = time % 60;
                            deviceCircleText.innerText = Math.floor(time / 60) + ":" + (secs < 10 ? "0" + secs : secs);
                            const radius = parseInt(deviceCircleSvgCircle.getAttribute('r'));
                            const circumference = radius * 2 * Math.PI;
                            if (time > 120) { time = 120; }
                            const percent = (100 / 120) * time;
                            const offset = circumference - percent / 100 * circumference;
                            deviceCircleSvgCircle.style.strokeDasharray = `${circumference} ${circumference}`;
                            deviceCircleSvgCircle.style.strokeDashoffset = offset;
                          start() {
                            Log.info(`Starting module: ${this.name}`);
                            this.devices = {};
                            this.counters = {};
                            this.loading = true;
                            this.sendSocketNotification('FETCH_TOOTHBRUSHES', this.config);
                          socketNotificationReceived(notification, payload) {
                            if (notification === 'FETCH_TOOTHBRUSHES_RESULTS') {
                              Log.info('MMM-Toothbrush: Got toothbrush results');
                              this.devices = payload;
                              for (const counterKey in this.counters) {
                                const counter = this.counters[counterKey];
                                clearInterval(counter.interval);
                              if (this.loading) {
                                this.loading = false;
                                this.updateDom(1000);
                              } else {
                                this.updateDom(0);
                        it’s also in the develop branch of my module
                        • T
                          timodejong95
                          @lavolp3 Thanks, I will have a look at that this weekend.
                          Also managed to connect to the services and characteristics. But how did you know the one you needed?
                          Because you only connecting to the 3th key in the services array and a hardcoded uuid for the characteristics. I am curious how you find the one you needed.
                          • lavolp3L
                            @timodejong95 I used this gitlab snippet. Don’t remember how I got there. I guess from the homeassistant forum which is also working on that.
                            For more follow-up see my post in this thread
                            When I use bluetoothctl on my RasPi I am getting lots of output form the brush recently. I’m not sure why exactly, maybe because my Pi is coupled with the brush.
                            Primary Service
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050
                                    a0f0ff20-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070
                                    a0f0ff2b-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070/desc0072
                                    00002901-0000-1000-8000-00805f9b34fb
                                    Characteristic User Description
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d
                                    a0f0ff2a-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d/desc006f
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a
                                    a0f0ff29-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a/desc006c
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067
                                    a0f0ff28-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067/desc0069
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064
                                    a0f0ff27-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064/desc0066
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061
                                    a0f0ff26-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061/desc0063
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e
                                    a0f0ff25-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e/desc0060
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b
                                    a0f0ff24-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b/desc005d
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058
                                    a0f0ff23-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058/desc005a
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055
                                    a0f0ff22-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055/desc0057
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051
                                    a0f0ff21-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0054
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0053
                                    00002902-0000-1000-8000-00805f9b34fb
                                    Client Characteristic Configuration
                            Primary Service
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e
                                    a0f0ff00-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c
                                    a0f0ff0d-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004f
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004e
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048
                                    a0f0ff0c-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004b
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004a
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044
                                    a0f0ff0b-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0047
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0046
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040
                                    a0f0ff0a-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0043
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0042
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c
                                    a0f0ff09-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003f
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003e
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038
                                    a0f0ff08-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003b
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003a
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034
                                    a0f0ff07-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0037
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0036
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030
                                    a0f0ff06-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0033
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0032
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c
                                    a0f0ff05-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002f
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002e
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028
                                    a0f0ff04-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002b
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002a
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025
                                    a0f0ff03-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025/desc0027
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022
                                    a0f0ff02-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022/desc0024
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f
                                    a0f0ff01-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f/desc0021
                            Primary Service
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010
                                    a0f0fff0-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b
                                    a0f0fff4-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b/desc001d
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018
                                    a0f0fff3-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018/desc001a
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015
                                    a0f0fff2-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015/desc0017
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011
                                    a0f0fff1-5047-4d53-8208-4f72616c2d42
                                    Vendor specific
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0014
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0013
                            Primary Service
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c
                                    00001801-0000-1000-8000-00805f9b34fb
                                    Generic Attribute Profile
                            Characteristic
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d
                                    00002a05-0000-1000-8000-00805f9b34fb
                                    Service Changed
                            Descriptor
                                    /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d/desc000f
                            Do we have to look into one of these characteristics/desricptors for the value?
                            • lavolp3L
                              lavolp3 Module Developer @lavolp3
                              @lavolp3 Well according to the gitlab code we’re looking for this:
                              Characteristic
                                      Vendor specific
                              Descriptor
                              Descriptor
                              The characteristic is the one the referenced noble code is filtering for.
                              Now GO Timo!
                              Make brushing great again!
                              • T
                                @lavolp3
                                Haha thanks man.
                                I have made some big changes, improved connecting devices, GATT service, characteristics and some more. I have also managed to get the battery value, but I have an issue: after around 15-30 seconds after connection successfully to the device the connection drops:
                                {"ServicesResolved":false,"Connected":false}
                                I haven’t figured out why this happens, all the normal data is still received. Only the battery status not, it needs to be connected. I haven’t push anything to the repo yet. First I want to look if I can get it working (fully).
                                Are you experiencing the same with noble or can you get the battery status after 30 seconds or 1 minute plus?
                                I keep you updated.
                                • T
                                  timodejong95
                                  I have been debugging it and it seems that the devices is ‘just’ being disconnected:
                                  HCI Event: Disconn Complete (0x05) plen 4
                                      status 0x00 handle 64 reason 0x13
                                      Reason: Remote User Terminated Connection
                                  I do not know why :/
                                  • T
                                    timodejong95
                                    @lavolp3 Oke I have pushed some changes, see: https://github.com/timodejong95/MMM-BluetoothDevices. Don’t forget npm install.
                                    I updated the configuration see docs. You need to add a track key to the device config with the value ‘battery’:
                                    example:
                                    devices: [
                                      { type: 'OralBToothbrush', name: 'oralb', mac: 'xxx', tracks: ['battery'], format: 'formatted' },
                                    It’s still a bit buggy let me know what your experience is!
                                    lavolp3L 1 Reply Last reply Reply Quote 1
                                    • lavolp3L
                                      @timodejong95 No luck yet.
                                      No Battery status to be seen and this error in the logs
                                      0|mm       | [2020-04-20 01:21:08.432] [ERROR]  01:21:08 <error> (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                                      0|mm       |     --> starting at object with constructor 'DBusObject'
                                      0|mm       |     |     property 'proxy' -> object with constructor 'Object'
                                      0|mm       |     |     property 'org.freedesktop.DBus.Introspectable' -> object with constructor 'DBusInterface'
                                      0|mm       |     --- property '$parent' closes the circle
                                      0|mm       |     at JSON.stringify (<anonymous>)
                                      0|mm       |     at /home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/index.js:24:25
                                      0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:89:5) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                      0|mm       | [2020-04-20 01:21:08.435] [ERROR]  01:21:08 <error> (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                                      • T
                                        @lavolp3 Damm ashame, could you post the logs above the error? If correct there should be 2 more error logs, and just to be sure it still works when you remove the battery track, right?
                                        D lavolp3L 2 Replies Last reply Reply Quote 0
                                          djerik @timodejong95
                                          @timodejong95
                                          I have removed the module, installed again and added the extra piece of configuration. The updated UI is working fine, but there is no battery indicator. Is this the log you are looking for?
                                          [2020-04-22 19:40:43.278] [LOG] MMM-BluetoothDevices received device update for OralB
                                          [2020-04-22 19:40:43.389] [LOG] MMM-BluetoothDevices trying to connect to: OralB 1/2
                                          [2020-04-22 19:40:53.451] [LOG] MMM-BluetoothDevices received device update for OralB
                                          [2020-04-22 19:40:53.673] [LOG] MMM-BluetoothDevices trying to connect to: OralB 2/2
                                          [2020-04-22 19:40:59.444] [LOG] MMM-BluetoothDevices received device update for OralB
                                          [2020-04-22 19:41:10.482] [LOG] MMM-BluetoothDevices received device update for OralB
                                          [2020-04-22 19:41:13.767] [ERROR] MMM-BluetoothDevices unhandled exception:
                                          [2020-04-22 19:41:13.771] [ERROR] MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded
                                          [2020-04-22 19:41:13.774] [ERROR] MMM-BluetoothDevices {“troubleshooting”:“devices#resolve-services”,“extra”:{}}
                                          [2020-04-22 19:41:21.451] [LOG] MMM-BluetoothDevices received device update for OralB
                                          [2020-04-22 19:41:32.477] [LOG] MMM-BluetoothDevices received device update for OralB
                                          [2020-04-22 19:41:43.546] [LOG] MMM-BluetoothDevices received device update for OralB
                                          [2020-04-22 19:41:54.482] [LOG] MMM-BluetoothDevices received device update for OralB
                                          • lavolp3L
                                            @timodejong95 there are no logs above that.
                                            I get this error before I started the brush
                                            [2020-04-23 00:19:17.258] [ERROR]  00:19:17 <error> MMM-BluetoothDevices unhandled exception: (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                                            [2020-04-23 00:19:17.263] [ERROR]  00:19:17 <error> MMM-BluetoothDevices Error: Error: Couldn't connect to BABSIS OralB after 2 tries. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
                                            [2020-04-23 00:19:17.277] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                                            [2020-04-23 00:19:17.284] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
                                            [2020-04-23 00:19:17.289] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:19:17.293] [ERROR]  00:19:17 <error> (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:19:17.296] [ERROR]  00:19:17 <error> (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:19:17.299] [ERROR]  00:19:17 <error> (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:23:44.731] [LOG]    00:23:44 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:23:47.096] [LOG]    00:23:47 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:23:57.944] [LOG]    00:23:57 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:24:08.935] [LOG]    00:24:08 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:24:19.917] [LOG]    00:24:19 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:24:30.925] [LOG]    00:24:30 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:24:41.961] [LOG]    00:24:41 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:24:52.927] [LOG]    00:24:52 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:25:03.965] [LOG]    00:25:03 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:25:14.860] [LOG]    00:25:14 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:25:25.926] [LOG]    00:25:25 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:25:36.875] [LOG]    00:25:36 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:25:47.877] [LOG]    00:25:47 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            [2020-04-23 00:25:58.907] [LOG]    00:25:58 <log> MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
                                            This error vanishes when I deactivate the JSON.stringify function.
                                            I have the feeling that everything is working, but the battery is not showing up at all.
                                            Also, when closing the mirror (ctrl+c when I started it with npm start dev ) I get these errors:
                                            [2020-04-23 00:38:03.482] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
                                                at Dongle.disconnectDevices (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:223:28)
                                                at Dongle.destroy (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:58:17)
                                                at Class.stop (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_helper.js:46:23)
                                                at App.stop (/home/pi/MagicMirror/js/app.js:252:16)
                                                at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:108:7)
                                                at App.emit (events.js:200:13) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:38:03.486] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
                                            [2020-04-23 00:38:03.489] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:38:03.495] [ERROR]  00:38:03 <error> (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:38:03.503] [ERROR]  00:38:03 <error> (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            [2020-04-23 00:38:03.509] [ERROR]  00:38:03 <error> (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
                                            • 3 / 4
