    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 40.6k Views 15 Watching
      BenRoe Module Developer @DirkS
      @DirkS If i have time, i will change it that every device can be configured.
      No clue how to implement a debug function. Feel free to do Pull Request.
        DirkS
        From where did you took the icons? I’m searching under Font Awesome but i couldn’t find them you took within the example?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @DirkS
          @DirkS the weather icons are from vendor/weather-icons/css/weather-icons.css
          @BenRoe you don’t request this css file in your module, you should do that or users will have no icons if they don’t use any other weather related module
            DirkS
            so i can take every icon from here? http://erikflowers.github.io/weather-icons/
            Edit: Yeah, works :D
              disakos
              hello @BenRoe , may you please adopt this module to read Domoticz values ?
              I see that it is similar because we can read domoticz values by json https://www.domoticz.com/wiki/Domoticz_API/JSON_URL’s#Retrieve_status_of_specific_device
              For example one of retrived data from BME280 sensor
              “ActTime” : 1477914474,
              “ServerTime” : “2016-10-31 12:47:54”,
              “Sunrise” : “06:33”,
              “Sunset” : “16:21”,
              “result” : [
              “AddjMulti” : 1.0,
              “AddjMulti2” : 1.0,
              “AddjValue” : 0.0,
              “AddjValue2” : 0.0,
              “Barometer” : 984,
              “BatteryLevel” : 255,
              “CustomImage” : 0,
              “Data” : “20.6 C, 58 %, 984 hPa”,
              “Description” : “”,
              “DewPoint” : “12.05”,
              “Favorite” : 1,
              “Forecast” : 0,
              “ForecastStr” : “No Info”,
              “HardwareID” : 3,
              “HardwareName” : “Virtual”,
              “HardwareType” : “Dummy (Does nothing, use for virtual switches only)”,
              “HardwareTypeVal” : 15,
              “HaveTimeout” : false,
              “Humidity” : 58,
              “HumidityStatus” : “Normal”,
              “ID” : “14056”,
              “LastUpdate” : “2016-10-31 12:46:59”,
              “Name” : “Łazienka”,
              “Notifications” : “true”,
              “PlanID” : “0”,
              “PlanIDs” : [ 0 ],
              “Protected” : false,
              “ShowNotifications” : true,
              “SignalLevel” : “-”,
              “SubType” : “THB1 - BTHR918, BTHGN129”,
              “Temp” : 20.60,
              “Timers” : “false”,
              “Type” : “Temp + Humidity + Baro”,
              “TypeImg” : “temperature”,
              “Unit” : 1,
              “Used” : 1,
              “XOffset” : “0”,
              “YOffset” : “0”,
              “idx” : “7”
              “status” : “OK”,
              “title” : “Devices”
              Interesting thing is Name of sensor (“Name”), Temperature ( “Temp”) , Humidity or Preassure etc…
              I think that would be great extension of this module ;)
              Please ;]
                DirkS
                Did you try to use some more modules of FHEM for different device types? It does not work correctly. The fading between the information is not working as i discovered.
                  DazDavid
                  Thanks for the amazing Module. Any news about the Overwriting Issue with two different Groups?
                    Bobby
                    Hi, i have some trouble with this modul.
                    The Error is:
                    21:11:17.224 TypeError: self.defaults.deviceReadings is undefined 1 MMM-FHEM.js:97:1
                    config.js:
                    { module: 'MMM-FHEM', position: 'bottom_bar', header: 'FHEM', config: { deviceNames: [ 'BadNode' ], deviceReadings: [ { name: 'temperature3', icon: 'fa fa-lightbulb-o', suffix: '°' }, // { name: 'humidity2', icon: 'wi wi-humidity', suffix: '%' }, ], }, }
                    I hope you can help me.
                    Bobby
                      @DirkS yes you can use the weather icons from http://erikflowers.github.io/weather-icons/ and the font awesome icons http://fontawesome.io/icons/
                      @DazDavid here is the thread to this problem https://forum.magicmirror.builders/topic/697/multiple-module-instances-overwrites-itself-values/2
                      I will rewrite the module. Then every device can have different reading values.
                      @Bobby is FHEM running on the same machine as the MM2?
                        Bobby @BenRoe
                        @BenRoe Thx for the fast answer. Yes, it is on the same Raspi. In the dev console of the browser, the correct value of the reading is displayed to me in the array as well.
                        • 1 / 4
