    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 46.8k Views 15 Watching
      BenRoe Module Developer @DirkS
      @DirkS If i have time, i will change it that every device can be configured.
      No clue how to implement a debug function. Feel free to do Pull Request.
        DirkS
        From where did you took the icons? I’m searching under Font Awesome but i couldn’t find them you took within the example?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @DirkS
          @DirkS the weather icons are from vendor/weather-icons/css/weather-icons.css
          @BenRoe you don’t request this css file in your module, you should do that or users will have no icons if they don’t use any other weather related module
            DirkS
            so i can take every icon from here? http://erikflowers.github.io/weather-icons/
            Edit: Yeah, works :D
              disakos
              hello @BenRoe , may you please adopt this module to read Domoticz values ?
              I see that it is similar because we can read domoticz values by json https://www.domoticz.com/wiki/Domoticz_API/JSON_URL’s#Retrieve_status_of_specific_device
              For example one of retrived data from BME280 sensor
              “ActTime” : 1477914474,
              “ServerTime” : “2016-10-31 12:47:54”,
              “Sunrise” : “06:33”,
              “Sunset” : “16:21”,
              “result” : [
              “AddjMulti” : 1.0,
              “AddjMulti2” : 1.0,
              “AddjValue” : 0.0,
              “AddjValue2” : 0.0,
              “Barometer” : 984,
              “BatteryLevel” : 255,
              “CustomImage” : 0,
              “Data” : “20.6 C, 58 %, 984 hPa”,
              “Description” : “”,
              “DewPoint” : “12.05”,
              “Favorite” : 1,
              “Forecast” : 0,
              “ForecastStr” : “No Info”,
              “HardwareID” : 3,
              “HardwareName” : “Virtual”,
              “HardwareType” : “Dummy (Does nothing, use for virtual switches only)”,
              “HardwareTypeVal” : 15,
              “HaveTimeout” : false,
              “Humidity” : 58,
              “HumidityStatus” : “Normal”,
              “ID” : “14056”,
              “LastUpdate” : “2016-10-31 12:46:59”,
              “Name” : “Łazienka”,
              “Notifications” : “true”,
              “PlanID” : “0”,
              “PlanIDs” : [ 0 ],
              “Protected” : false,
              “ShowNotifications” : true,
              “SignalLevel” : “-”,
              “SubType” : “THB1 - BTHR918, BTHGN129”,
              “Temp” : 20.60,
              “Timers” : “false”,
              “Type” : “Temp + Humidity + Baro”,
              “TypeImg” : “temperature”,
              “Unit” : 1,
              “Used” : 1,
              “XOffset” : “0”,
              “YOffset” : “0”,
              “idx” : “7”
              “status” : “OK”,
              “title” : “Devices”
              Interesting thing is Name of sensor (“Name”), Temperature ( “Temp”) , Humidity or Preassure etc…
              I think that would be great extension of this module ;)
              Please ;]
                DirkS
                Did you try to use some more modules of FHEM for different device types? It does not work correctly. The fading between the information is not working as i discovered.
                  DazDavid
                  Thanks for the amazing Module. Any news about the Overwriting Issue with two different Groups?
                    Bobby
                    Hi, i have some trouble with this modul.
                    The Error is:
                    21:11:17.224 TypeError: self.defaults.deviceReadings is undefined 1 MMM-FHEM.js:97:1
                    config.js:
                    { module: 'MMM-FHEM', position: 'bottom_bar', header: 'FHEM', config: { deviceNames: [ 'BadNode' ], deviceReadings: [ { name: 'temperature3', icon: 'fa fa-lightbulb-o', suffix: '°' }, // { name: 'humidity2', icon: 'wi wi-humidity', suffix: '%' }, ], }, }
                    I hope you can help me.
                    Bobby
                      @DirkS yes you can use the weather icons from http://erikflowers.github.io/weather-icons/ and the font awesome icons http://fontawesome.io/icons/
                      @DazDavid here is the thread to this problem https://forum.magicmirror.builders/topic/697/multiple-module-instances-overwrites-itself-values/2
                      I will rewrite the module. Then every device can have different reading values.
                      @Bobby is FHEM running on the same machine as the MM2?
                        Bobby @BenRoe
                        @BenRoe Thx for the fast answer. Yes, it is on the same Raspi. In the dev console of the browser, the correct value of the reading is displayed to me in the array as well.
                          DazDavid
                          @BenRoe cannot wait for the rewrite. Any idea how long it will take approximately and if you could add https Support?
                            Bobby @BenRoe
                            @BenRoe Hi, i found the problem an it works fine now.
                            I changed following line self.defaults.deviceReadings[index] in self.config.deviceReadings[index]
                            There are no default values for deviceNames and deviceReadings. They are only in the config.js
                            This helps for me.
                            Bobby
                              I updated the Module to Version 0.2.0
                              Update instruction https://github.com/BenRoe/MMM-FHEM#update-the-module
                              Please change the module configuration in your config.js to the new structure.
                              @DazDavid now with https support
                              @Bobby fix the bug you found
                              @DirkS you can set different readings for every FHEM device
                              If you like the module please star it on github
                                Dom1n1c
                                Is it possible to access values from openhab?
                                The syntax of the rest interface in OH is:
                                IP:8080/rest/items/specificitem
                                And to get the ‘Raw’ result/value:
                                IP:8080/rest/items/specificitem/state
                                I saw that there were a few Addons (for my smartwatch) that could use both FHEM and OpenHAB
                                  BenRoe Module Developer @Dom1n1c
                                  @Dom1n1c it is possible. I don’t have the time to rewrite the module for openhab. Sorry
                                    DazDavid
                                    @BenRoe thank you for the update.
                                    Unfortunatelly the new version killed my FHEM Server somehow… Anyway I found a workarounf in the meanwhile.
                                    I build a new Tablet UI HTML File for the Mirror and used the iframe Module in MM to display the values. Works pretty good and im more Flexible.
                                      BenRoe Module Developer @DazDavid
                                      @DazDavid what killed your FHEM Server? It’s should not be possible, the plugin could kill your MagicMirror, because of a config file with syntax errors or to high update rate.
                                        DazDavid
                                        Don’t know exactly what happend but after I set it up I only managed one time to get a value from FHEM, second time Fhem freeze and was not responding anymore. Only after deleting the module from MM config and restart the Raspberry Fhem was working again.
                                        • FistandantilusF Offline
                                          Fistandantilus
                                          thx for your module. It exactly meets my requirements! One thing I´m currently struggeling is the alignment. I´m using:
                                          body {
                                          margin: 30px;
                                          height: calc(100% - 60px);
                                          width: calc(100% - 60px);
                                          in my custom. css. The FHEM module is located at top_right but it has not the same margin as other modules. I made the border vissible using border-style: solid; to make see if it is the text alignment or something else. Se the attachment to get a better picture of what I´m talking about. Does anybody have an idea how to move it left?
                                          regards,
                                          F.
                                            Fistandantilus
                                            OK, fixed it by myself. Had to remove the max-width: 300px; from fhem.css.
