    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 40.6k Views 15 Watching
      DirkS
      I noticed it doesn’t update the values. Once it takes the data but stays with it. Is there something i miss?
        BenRoe Module Developer @DirkS
        @DirkS The Module use the FHEM name of the device or you can set a alias for the device in FHEM like this in the fhem.cfg file attr LaCr.Thermo01 alias Bad
        One module config is for a group of devices with the same value type. One group for temperature and humidity and another for lights …
            module: 'MMM-FHEM',
            position: 'bottom_bar',
              deviceNames: [
                            'FhemDeviceName1',
                            'FhemDeviceName2',
                            'FhemDeviceName3',
              deviceReadings: [
                                { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
            module: 'MMM-FHEM',
              deviceNames: [
                            'FhemDeviceLight1',
                            'FhemDeviceLight2',
              deviceReadings: [
                                { name: 'state', icon: 'fa fa-lightbulb-o', suffix: '' },
        Ich kann das vielleicht auch umschreiben, sodas man für jedes FhemDevice die Readings/Werte angeben kann.
          DirkS
          Ja nice! Now i have a usecase for the alias attr. ;) Before i had no clue for what i could need it.
          Readings for every single device would be good. I gives you more flexibility.
          What about a debug function? I would like to see the timing when it does fetch the last status and if the connection get interrupted etc.
            @DirkS If i have time, i will change it that every device can be configured.
            No clue how to implement a debug function. Feel free to do Pull Request.
              DirkS
              From where did you took the icons? I’m searching under Font Awesome but i couldn’t find them you took within the example?
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @DirkS
                @DirkS the weather icons are from vendor/weather-icons/css/weather-icons.css
                @BenRoe you don’t request this css file in your module, you should do that or users will have no icons if they don’t use any other weather related module
                  DirkS
                  so i can take every icon from here? http://erikflowers.github.io/weather-icons/
                  Edit: Yeah, works :D
                    disakos
                    hello @BenRoe , may you please adopt this module to read Domoticz values ?
                    I see that it is similar because we can read domoticz values by json https://www.domoticz.com/wiki/Domoticz_API/JSON_URL’s#Retrieve_status_of_specific_device
                    For example one of retrived data from BME280 sensor
                    “ActTime” : 1477914474,
                    “ServerTime” : “2016-10-31 12:47:54”,
                    “Sunrise” : “06:33”,
                    “Sunset” : “16:21”,
                    “result” : [
                    “AddjMulti” : 1.0,
                    “AddjMulti2” : 1.0,
                    “AddjValue” : 0.0,
                    “AddjValue2” : 0.0,
                    “Barometer” : 984,
                    “BatteryLevel” : 255,
                    “CustomImage” : 0,
                    “Data” : “20.6 C, 58 %, 984 hPa”,
                    “Description” : “”,
                    “DewPoint” : “12.05”,
                    “Favorite” : 1,
                    “Forecast” : 0,
                    “ForecastStr” : “No Info”,
                    “HardwareID” : 3,
                    “HardwareName” : “Virtual”,
                    “HardwareType” : “Dummy (Does nothing, use for virtual switches only)”,
                    “HardwareTypeVal” : 15,
                    “HaveTimeout” : false,
                    “Humidity” : 58,
                    “HumidityStatus” : “Normal”,
                    “ID” : “14056”,
                    “LastUpdate” : “2016-10-31 12:46:59”,
                    “Name” : “Łazienka”,
                    “Notifications” : “true”,
                    “PlanID” : “0”,
                    “PlanIDs” : [ 0 ],
                    “Protected” : false,
                    “ShowNotifications” : true,
                    “SignalLevel” : “-”,
                    “SubType” : “THB1 - BTHR918, BTHGN129”,
                    “Temp” : 20.60,
                    “Timers” : “false”,
                    “Type” : “Temp + Humidity + Baro”,
                    “TypeImg” : “temperature”,
                    “Unit” : 1,
                    “Used” : 1,
                    “XOffset” : “0”,
                    “YOffset” : “0”,
                    “idx” : “7”
                    “status” : “OK”,
                    “title” : “Devices”
                    Interesting thing is Name of sensor (“Name”), Temperature ( “Temp”) , Humidity or Preassure etc…
                    I think that would be great extension of this module ;)
                    Please ;]
                      DirkS
                      Did you try to use some more modules of FHEM for different device types? It does not work correctly. The fading between the information is not working as i discovered.
                        DazDavid
                        Thanks for the amazing Module. Any news about the Overwriting Issue with two different Groups?
                        • 1 / 4
