    Works with Node Serveronly but not npm start MM
    24 Posts 4 Posters 4.8k Views 4 Watching
      JohnBachini @sdetweil
      tried that and looks like im still getting the same errors:
      pi@MagicMirror:~ $ cd MagicMirror/
      pi@MagicMirror:~/MagicMirror $ npm install electron-rebuild
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + electron-rebuild@1.10.1
      updated 1 package and audited 3283 packages in 19.153s
      56 packages are looking for funding
        run `npm fund` for details
      found 24 vulnerabilities (22 low, 2 moderate)
        run `npm audit fix` to fix them, or `npm audit` for details
      pi@MagicMirror:~/MagicMirror $ node_modules/.bin/electron-rebuild
      ✔ Rebuild Complete
      pi@MagicMirror:~/MagicMirror $ npm start
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      [2020-04-27 19:08:36.793] [LOG]    Starting MagicMirror: v2.11.0
      [2020-04-27 19:08:36.800] [LOG]    Loading config ...
      [2020-04-27 19:08:36.806] [LOG]    Loading module helpers ...
      [2020-04-27 19:08:36.807] [LOG]    No helper found for module: MMM-Logging.
      [2020-04-27 19:08:36.810] [LOG]    No helper found for module: alert.
      [2020-04-27 19:08:36.855] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:36.856] [LOG]    Module helper loaded: updatenotification
      [2020-04-27 19:08:36.857] [LOG]    No helper found for module: clock.
      [2020-04-27 19:08:36.857] [LOG]    No helper found for module: MMM-OpenmapWeather.
      [2020-04-27 19:08:36.858] [LOG]    No helper found for module: weatherforecast.
      [2020-04-27 19:08:37.208] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:37.209] [LOG]    Module helper loaded: MMM-Tools
      [2020-04-27 19:08:37.209] [LOG]    No helper found for module: MMM-PlexNowPlaying.
      [2020-04-27 19:08:37.211] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:37.211] [LOG]    Module helper loaded: mmm-hue-lights
      [2020-04-27 19:08:37.213] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:37.213] [LOG]    Module helper loaded: MMM-homeassistant-sensors
      [2020-04-27 19:08:37.389] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:37.390] [LOG]    Module helper loaded: MMM-Hotword
      [2020-04-27 19:08:38.531] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:38.532] [LOG]    Module helper loaded: MMM-AssistantMk2
      [2020-04-27 19:08:38.533] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:38.534] [LOG]    Module helper loaded: MMM-Assistant2Display
      [2020-04-27 19:08:38.920] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:38.921] [LOG]    Module helper loaded: MMM-Parcel
      [2020-04-27 19:08:38.988] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      [2020-04-27 19:08:38.989] [LOG]    Loading module helpers ...
      [2020-04-27 19:08:38.990] [LOG]    No helper found for module: MMM-Logging.
      [2020-04-27 19:08:38.990] [LOG]    No helper found for module: alert.
      [2020-04-27 19:08:38.991] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:38.992] [LOG]    Module helper loaded: updatenotification
      [2020-04-27 19:08:38.993] [LOG]    No helper found for module: clock.
      [2020-04-27 19:08:38.993] [LOG]    No helper found for module: MMM-OpenmapWeather.
      [2020-04-27 19:08:38.994] [LOG]    No helper found for module: weatherforecast.
      [2020-04-27 19:08:38.995] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:38.995] [LOG]    Module helper loaded: MMM-Tools
      [2020-04-27 19:08:38.996] [LOG]    No helper found for module: MMM-PlexNowPlaying.
      [2020-04-27 19:08:38.997] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:38.998] [LOG]    Module helper loaded: mmm-hue-lights
      [2020-04-27 19:08:39.000] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:39.001] [LOG]    Module helper loaded: MMM-homeassistant-sensors
      [2020-04-27 19:08:39.002] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:39.002] [LOG]    Module helper loaded: MMM-Hotword
      [2020-04-27 19:08:39.003] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:39.004] [LOG]    Module helper loaded: MMM-AssistantMk2
      [2020-04-27 19:08:39.004] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:39.005] [LOG]    Module helper loaded: MMM-Assistant2Display
      [2020-04-27 19:08:39.005] [LOG]    Initializing new module helper ...
      [2020-04-27 19:08:39.006] [LOG]    Module helper loaded: MMM-Parcel
      [2020-04-27 19:08:39.012] [ERROR]  App threw an error during load
      [2020-04-27 19:08:39.013] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
          at process.func (electron/js2c/asar.js:138:31)
          at process.func [as dlopen] (electron/js2c/asar.js:138:31)
          at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
          at Object.func (electron/js2c/asar.js:138:31)
          at Object.func [as .node] (electron/js2c/asar.js:138:31)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/lib/index.js:1:13)
      [2020-04-27 19:08:39.014] [LOG]    Whoops! There was an uncaught exception...
      [2020-04-27 19:08:39.015] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
      [2020-04-27 19:08:39.018] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-04-27 19:08:39.019] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-04-27 19:08:39.144] [LOG]    Launching application.
        sdetweil @JohnBachini
        @JohnBachini said in Works with Node Serveronly but not npm start MM:
        ok, need to get forceful…
        cd /home/pi/MagicMirror/modules/MMM-synology-ds
        rm -rf node_modules
        rm package-lock.json
        npm install
          Still no joy :-(
          pi@MagicMirror:~ $ cd MagicMirror//modules/MMM-synology-ds/
          pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm -rf node_modules
          pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm package-lock.json
          pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm install
          > mmmagic@0.5.3 install /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
          > node-gyp rebuild
          make: Entering directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/apprentice.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/apptype.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/ascmagic.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf_time.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/compress.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/der.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/encoding.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/fsmagic.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/funcs.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/is_tar.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/magic.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/print.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/readcdf.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/readelf.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/softmagic.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/fmtcheck.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcat.o
            CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcpy.o
            AR(target) Release/obj.target/deps/libmagic/magic.a
            COPY Release/magic.a
            CXX(target) Release/obj.target/magic/src/binding.o
          In file included from ../src/binding.cc:3:
          ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
          ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
          ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>&)’:
          ../src/binding.cc:184:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            (uv_after_work_cb)Magic::DetectAfter);
          ../src/binding.cc: In static member function ‘static void Magic::Detect(const Nan::FunctionCallbackInfo<v8::Value>&)’:
          ../src/binding.cc:217:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          In file included from ../src/binding.cc:1:
          ../src/binding.cc: At global scope:
          /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                 (node::addon_register_func) (regfunc),                          \
          /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
             NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          ../src/binding.cc:415:3: note: in expansion of macro ‘NODE_MODULE’
             NODE_MODULE(magic, init);
          In file included from /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:63,
          /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
          /home/pi/.cache/node-gyp/10.20.0/include/node/node_object_wrap.h:84:78:   required from here
          /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                          reinterpret_cast<Callback>(callback), type);
          /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
          ../../nan/nan_object_wrap.h:65:61:   required from here
          /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
            SOLINK_MODULE(target) Release/obj.target/magic.node
            COPY Release/magic.node
          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
          npm notice created a lockfile as package-lock.json. You should commit this file.
          added 12 packages from 23 contributors and audited 12 packages in 21.888s
          found 0 vulnerabilities
          pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ ^C
          pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ cd ..
          pi@MagicMirror:~/MagicMirror/modules $ cd ..
          pi@MagicMirror:~/MagicMirror $ npm start mm
          > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "mm"
          [2020-04-27 19:59:42.738] [LOG]    Starting MagicMirror: v2.11.0
          [2020-04-27 19:59:42.745] [LOG]    Loading config ...
          [2020-04-27 19:59:42.751] [LOG]    Loading module helpers ...
          [2020-04-27 19:59:42.754] [LOG]    No helper found for module: MMM-Logging.
          [2020-04-27 19:59:42.757] [LOG]    No helper found for module: alert.
          [2020-04-27 19:59:42.798] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:42.799] [LOG]    Module helper loaded: updatenotification
          [2020-04-27 19:59:42.800] [LOG]    No helper found for module: clock.
          [2020-04-27 19:59:42.800] [LOG]    No helper found for module: MMM-OpenmapWeather.
          [2020-04-27 19:59:42.801] [LOG]    No helper found for module: weatherforecast.
          [2020-04-27 19:59:43.153] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:43.154] [LOG]    Module helper loaded: MMM-Tools
          [2020-04-27 19:59:43.155] [LOG]    No helper found for module: MMM-PlexNowPlaying.
          [2020-04-27 19:59:43.157] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:43.157] [LOG]    Module helper loaded: mmm-hue-lights
          [2020-04-27 19:59:43.159] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:43.160] [LOG]    Module helper loaded: MMM-homeassistant-sensors
          [2020-04-27 19:59:43.350] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:43.350] [LOG]    Module helper loaded: MMM-Hotword
          [2020-04-27 19:59:44.479] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.480] [LOG]    Module helper loaded: MMM-AssistantMk2
          [2020-04-27 19:59:44.481] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.482] [LOG]    Module helper loaded: MMM-Assistant2Display
          [2020-04-27 19:59:44.896] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.897] [LOG]    Module helper loaded: MMM-Parcel
          [2020-04-27 19:59:44.980] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
          [2020-04-27 19:59:44.981] [LOG]    Loading module helpers ...
          [2020-04-27 19:59:44.981] [LOG]    No helper found for module: MMM-Logging.
          [2020-04-27 19:59:44.982] [LOG]    No helper found for module: alert.
          [2020-04-27 19:59:44.983] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.983] [LOG]    Module helper loaded: updatenotification
          [2020-04-27 19:59:44.983] [LOG]    No helper found for module: clock.
          [2020-04-27 19:59:44.984] [LOG]    No helper found for module: MMM-OpenmapWeather.
          [2020-04-27 19:59:44.985] [LOG]    No helper found for module: weatherforecast.
          [2020-04-27 19:59:44.985] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.985] [LOG]    Module helper loaded: MMM-Tools
          [2020-04-27 19:59:44.986] [LOG]    No helper found for module: MMM-PlexNowPlaying.
          [2020-04-27 19:59:44.986] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: mmm-hue-lights
          [2020-04-27 19:59:44.987] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: MMM-homeassistant-sensors
          [2020-04-27 19:59:44.988] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.988] [LOG]    Module helper loaded: MMM-Hotword
          [2020-04-27 19:59:44.989] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.989] [LOG]    Module helper loaded: MMM-AssistantMk2
          [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Assistant2Display
          [2020-04-27 19:59:44.990] [LOG]    Initializing new module helper ...
          [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Parcel
          [2020-04-27 19:59:44.997] [ERROR]  App threw an error during load
          [2020-04-27 19:59:44.998] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
          [2020-04-27 19:59:45.000] [LOG]    Whoops! There was an uncaught exception...
          [2020-04-27 19:59:45.000] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
          [2020-04-27 19:59:45.004] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-04-27 19:59:45.004] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [2020-04-27 19:59:45.109] [LOG]    Launching application.
            @JohnBachini yeh, looks like they have embedded a version of node in their package… don’t know how to fix that
              oh ok, never mind, thanks for trying to help. :thumbs_up:
              just one question for my own peace of mind and try not get too technical, why does it work in servernode, what’s the difference ?
              Thanks again.
                @JohnBachini servermode doesn’t load the modulename.js file, which is what drags in the rest of the stuff…
                if u run servermode and then open a browser to the server ip, it will fail the same way
                  But it doesnt ,it works fine if i servermode and then connect via browser, no errors console at all and the module works as it connect to synology and reports as expected.
                  Very strange.
                    @JohnBachini is the browser ON the same system?
                    how about opening chromium-browser on the same server to the server
                    electron is all javascript…
                      Just tried it and it works in chromium on server !?
                        @JohnBachini different version of javascript inside chromium…
