    Works with Node Serveronly but not npm start MM
    24 Posts 4 Posters 3.7k Views 4 Watching
      JohnBachini
      So i have been running My Magicmirror as node serveronly for a while but came to change config, so started it with npm start MM and it errors on one module and then get blank screen.
      See below.
      So question is how to fix and why does it work when run serveronly.
      I tried npm rebuild in module as suggested (if indeed that what it was saying I should recompile ?)
      John
      magicmirror@2.11.0 start /home/pi/MagicMirror
      > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "MagicMirror"
      [2020-04-27 15:54:50.403] [LOG]    Starting MagicMirror: v2.11.0
      [2020-04-27 15:54:50.431] [LOG]    Loading config ...
      [2020-04-27 15:54:50.436] [LOG]    Loading module helpers ...
      [2020-04-27 15:54:50.438] [LOG]    No helper found for module: MMM-Logging.
      [2020-04-27 15:54:50.439] [LOG]    No helper found for module: alert.
      [2020-04-27 15:54:50.492] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:50.493] [LOG]    Module helper loaded: updatenotification
      [2020-04-27 15:54:50.493] [LOG]    No helper found for module: clock.
      [2020-04-27 15:54:50.494] [LOG]    No helper found for module: MMM-OpenmapWeather.
      [2020-04-27 15:54:50.495] [LOG]    No helper found for module: weatherforecast.
      [2020-04-27 15:54:50.807] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:50.808] [LOG]    Module helper loaded: MMM-Tools
      [2020-04-27 15:54:50.808] [LOG]    No helper found for module: MMM-PlexNowPlaying.
      [2020-04-27 15:54:50.810] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:50.811] [LOG]    Module helper loaded: mmm-hue-lights
      [2020-04-27 15:54:50.812] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:50.813] [LOG]    Module helper loaded: MMM-homeassistant-sensors
      [2020-04-27 15:54:51.038] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:51.039] [LOG]    Module helper loaded: MMM-Hotword
      [2020-04-27 15:54:52.180] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.181] [LOG]    Module helper loaded: MMM-AssistantMk2
      [2020-04-27 15:54:52.183] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.183] [LOG]    Module helper loaded: MMM-Assistant2Display
      [2020-04-27 15:54:52.579] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.580] [LOG]    Module helper loaded: MMM-Parcel
      [2020-04-27 15:54:52.660] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      [2020-04-27 15:54:52.661] [LOG]    Loading module helpers ...
      [2020-04-27 15:54:52.662] [LOG]    No helper found for module: MMM-Logging.
      [2020-04-27 15:54:52.662] [LOG]    No helper found for module: alert.
      [2020-04-27 15:54:52.663] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.663] [LOG]    Module helper loaded: updatenotification
      [2020-04-27 15:54:52.664] [LOG]    No helper found for module: clock.
      [2020-04-27 15:54:52.664] [LOG]    No helper found for module: MMM-OpenmapWeather.
      [2020-04-27 15:54:52.665] [LOG]    No helper found for module: weatherforecast.
      [2020-04-27 15:54:52.665] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.666] [LOG]    Module helper loaded: MMM-Tools
      [2020-04-27 15:54:52.666] [LOG]    No helper found for module: MMM-PlexNowPlaying.
      [2020-04-27 15:54:52.667] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.667] [LOG]    Module helper loaded: mmm-hue-lights
      [2020-04-27 15:54:52.668] [LOG]    Module helper loaded: MMM-homeassistant-sensors
      [2020-04-27 15:54:52.668] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.669] [LOG]    Module helper loaded: MMM-Hotword
      [2020-04-27 15:54:52.669] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.669] [LOG]    Module helper loaded: MMM-AssistantMk2
      [2020-04-27 15:54:52.670] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.670] [LOG]    Module helper loaded: MMM-Assistant2Display
      [2020-04-27 15:54:52.671] [LOG]    Initializing new module helper ...
      [2020-04-27 15:54:52.671] [LOG]    Module helper loaded: MMM-Parcel
      [2020-04-27 15:54:52.678] [ERROR]  App threw an error during load
      [2020-04-27 15:54:52.679] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
          at process.func (electron/js2c/asar.js:138:31)
          at process.func [as dlopen] (electron/js2c/asar.js:138:31)
          at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
          at Object.func (electron/js2c/asar.js:138:31)
          at Object.func [as .node] (electron/js2c/asar.js:138:31)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/lib/index.js:1:13)
      [2020-04-27 15:54:52.680] [LOG]    Whoops! There was an uncaught exception...
      [2020-04-27 15:54:52.680] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
      [2020-04-27 15:54:52.684] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-04-27 15:54:52.684] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-04-27 15:54:53.034] [LOG]    Launching application.
        sdetweil @JohnBachini
        @JohnBachini did u try the npm rebuild?
          JohnBachini @sdetweil
          yes tried npm rebuild in module directory and get this:
          pi@MagicMirror:~ $ cd MagicMirror/
          pi@MagicMirror:~/MagicMirror $ cd modules
          pi@MagicMirror:~/MagicMirror/modules $ cd MMM-synology-ds/
          pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm rebuild
          mmmagic@0.5.3 install /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
          node-gyp rebuild
          make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build’
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/apprentice.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/apptype.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/ascmagic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf_time.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/compress.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/der.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/encoding.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/fsmagic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/funcs.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/is_tar.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/magic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/print.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/readcdf.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/readelf.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/softmagic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/fmtcheck.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcat.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcpy.o
          AR(target) Release/obj.target/deps/libmagic/magic.a
          COPY Release/magic.a
          CXX(target) Release/obj.target/magic/src/binding.o
          In file included from …/src/binding.cc:3:
          …/…/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
          …/…/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
          , reinterpret_cast(AsyncExecuteComplete)
          …/src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo&)’:
          …/src/binding.cc:184:59: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
          (uv_after_work_cb)Magic::DetectAfter);
          …/src/binding.cc: In static member function ‘static void Magic::Detect(const Nan::FunctionCallbackInfo&)’:
          …/src/binding.cc:217:59: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
          In file included from …/src/binding.cc:1:
          …/src/binding.cc: At global scope:
          /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void ()(v8::Local)’ to ‘node::addon_register_func’ {aka ‘void ()(v8::Local, v8::Local, void*)’} [-Wcast-function-type]
          (node::addon_register_func) (regfunc),
          /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
          NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
          …/src/binding.cc:415:3: note: in expansion of macro ‘NODE_MODULE’
          NODE_MODULE(magic, init);
          In file included from /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:63,
          /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase::SetWeak(P*, typename v8::WeakCallbackInfo
          ::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
          ::Callback = void ()(const v8::WeakCallbackInfo&)]’:
          /home/pi/.cache/node-gyp/10.20.0/include/node/node_object_wrap.h:84:78: required from here
          /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo::Callback’ {aka ‘void ()(const v8::WeakCallbackInfo&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
          reinterpret_cast(callback), type);
          ::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
          …/…/nan/nan_object_wrap.h:65:61: required from here
          SOLINK_MODULE(target) Release/obj.target/magic.node
          COPY Release/magic.node
          make: Leaving directory ‘/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build’
          synology-api@1.0.8 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/synology-api
          http-request@0.7.0 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/http-request
          form-data@3.0.0 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/form-data
          asynckit@0.4.0 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/asynckit
          combined-stream@1.0.8 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/combined-stream
          delayed-stream@1.0.0 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/delayed-stream
          mime-types@2.1.26 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mime-types
          mime-db@1.43.0 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mime-db
          mmmagic@0.5.3 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
          nan@2.14.0 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/nan
          promise@7.3.1 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/promise
          asap@2.0.6 /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/asap
            @JohnBachini
            try this
            npm install electron-rebuild
            node_modules/.bin/electron-rebuild
            then npm start
              tried that and looks like im still getting the same errors:
              pi@MagicMirror:~/MagicMirror $ npm install electron-rebuild
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              + electron-rebuild@1.10.1
              updated 1 package and audited 3283 packages in 19.153s
              56 packages are looking for funding
                run `npm fund` for details
              found 24 vulnerabilities (22 low, 2 moderate)
                run `npm audit fix` to fix them, or `npm audit` for details
              pi@MagicMirror:~/MagicMirror $ node_modules/.bin/electron-rebuild
              ✔ Rebuild Complete
              pi@MagicMirror:~/MagicMirror $ npm start
              [2020-04-27 19:08:36.793] [LOG]    Starting MagicMirror: v2.11.0
              [2020-04-27 19:08:36.800] [LOG]    Loading config ...
              [2020-04-27 19:08:36.806] [LOG]    Loading module helpers ...
              [2020-04-27 19:08:36.807] [LOG]    No helper found for module: MMM-Logging.
              [2020-04-27 19:08:36.810] [LOG]    No helper found for module: alert.
              [2020-04-27 19:08:36.855] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:36.856] [LOG]    Module helper loaded: updatenotification
              [2020-04-27 19:08:36.857] [LOG]    No helper found for module: clock.
              [2020-04-27 19:08:36.857] [LOG]    No helper found for module: MMM-OpenmapWeather.
              [2020-04-27 19:08:36.858] [LOG]    No helper found for module: weatherforecast.
              [2020-04-27 19:08:37.208] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:37.209] [LOG]    Module helper loaded: MMM-Tools
              [2020-04-27 19:08:37.209] [LOG]    No helper found for module: MMM-PlexNowPlaying.
              [2020-04-27 19:08:37.211] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:37.211] [LOG]    Module helper loaded: mmm-hue-lights
              [2020-04-27 19:08:37.213] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:37.213] [LOG]    Module helper loaded: MMM-homeassistant-sensors
              [2020-04-27 19:08:37.389] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:37.390] [LOG]    Module helper loaded: MMM-Hotword
              [2020-04-27 19:08:38.531] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:38.532] [LOG]    Module helper loaded: MMM-AssistantMk2
              [2020-04-27 19:08:38.533] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:38.534] [LOG]    Module helper loaded: MMM-Assistant2Display
              [2020-04-27 19:08:38.920] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:38.921] [LOG]    Module helper loaded: MMM-Parcel
              [2020-04-27 19:08:38.988] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
              [2020-04-27 19:08:38.989] [LOG]    Loading module helpers ...
              [2020-04-27 19:08:38.990] [LOG]    No helper found for module: MMM-Logging.
              [2020-04-27 19:08:38.990] [LOG]    No helper found for module: alert.
              [2020-04-27 19:08:38.991] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:38.992] [LOG]    Module helper loaded: updatenotification
              [2020-04-27 19:08:38.993] [LOG]    No helper found for module: clock.
              [2020-04-27 19:08:38.993] [LOG]    No helper found for module: MMM-OpenmapWeather.
              [2020-04-27 19:08:38.994] [LOG]    No helper found for module: weatherforecast.
              [2020-04-27 19:08:38.995] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:38.995] [LOG]    Module helper loaded: MMM-Tools
              [2020-04-27 19:08:38.996] [LOG]    No helper found for module: MMM-PlexNowPlaying.
              [2020-04-27 19:08:38.997] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:38.998] [LOG]    Module helper loaded: mmm-hue-lights
              [2020-04-27 19:08:39.000] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:39.001] [LOG]    Module helper loaded: MMM-homeassistant-sensors
              [2020-04-27 19:08:39.002] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:39.002] [LOG]    Module helper loaded: MMM-Hotword
              [2020-04-27 19:08:39.003] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:39.004] [LOG]    Module helper loaded: MMM-AssistantMk2
              [2020-04-27 19:08:39.004] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:39.005] [LOG]    Module helper loaded: MMM-Assistant2Display
              [2020-04-27 19:08:39.005] [LOG]    Initializing new module helper ...
              [2020-04-27 19:08:39.006] [LOG]    Module helper loaded: MMM-Parcel
              [2020-04-27 19:08:39.012] [ERROR]  App threw an error during load
              [2020-04-27 19:08:39.013] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
              [2020-04-27 19:08:39.014] [LOG]    Whoops! There was an uncaught exception...
              [2020-04-27 19:08:39.015] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
              [2020-04-27 19:08:39.018] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2020-04-27 19:08:39.019] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [2020-04-27 19:08:39.144] [LOG]    Launching application.
                @JohnBachini said in Works with Node Serveronly but not npm start MM:
                ok, need to get forceful…
                cd /home/pi/MagicMirror/modules/MMM-synology-ds
                rm -rf node_modules
                rm package-lock.json
                npm install
                  Still no joy :-(
                  pi@MagicMirror:~ $ cd MagicMirror//modules/MMM-synology-ds/
                  pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm -rf node_modules
                  pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm package-lock.json
                  pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm install
                  > node-gyp rebuild
                  make: Entering directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
                  In file included from ../src/binding.cc:3:
                  ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                  ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>&)’:
                  ../src/binding.cc:184:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                  ../src/binding.cc: In static member function ‘static void Magic::Detect(const Nan::FunctionCallbackInfo<v8::Value>&)’:
                  ../src/binding.cc:217:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                  In file included from ../src/binding.cc:1:
                  ../src/binding.cc: At global scope:
                  /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  ../src/binding.cc:415:3: note: in expansion of macro ‘NODE_MODULE’
                  /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                  /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                  reinterpret_cast<Callback>(callback), type);
                  /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                  ../../nan/nan_object_wrap.h:65:61:   required from here
                  /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                  make: Leaving directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  added 12 packages from 23 contributors and audited 12 packages in 21.888s
                  found 0 vulnerabilities
                  pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ ^C
                  pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ cd ..
                  pi@MagicMirror:~/MagicMirror/modules $ cd ..
                  pi@MagicMirror:~/MagicMirror $ npm start mm
                  > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "mm"
                  [2020-04-27 19:59:42.738] [LOG]    Starting MagicMirror: v2.11.0
                  [2020-04-27 19:59:42.745] [LOG]    Loading config ...
                  [2020-04-27 19:59:42.751] [LOG]    Loading module helpers ...
                  [2020-04-27 19:59:42.754] [LOG]    No helper found for module: MMM-Logging.
                  [2020-04-27 19:59:42.757] [LOG]    No helper found for module: alert.
                  [2020-04-27 19:59:42.798] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:42.799] [LOG]    Module helper loaded: updatenotification
                  [2020-04-27 19:59:42.800] [LOG]    No helper found for module: clock.
                  [2020-04-27 19:59:42.800] [LOG]    No helper found for module: MMM-OpenmapWeather.
                  [2020-04-27 19:59:42.801] [LOG]    No helper found for module: weatherforecast.
                  [2020-04-27 19:59:43.153] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:43.154] [LOG]    Module helper loaded: MMM-Tools
                  [2020-04-27 19:59:43.155] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                  [2020-04-27 19:59:43.157] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:43.157] [LOG]    Module helper loaded: mmm-hue-lights
                  [2020-04-27 19:59:43.159] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:43.160] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                  [2020-04-27 19:59:43.350] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:43.350] [LOG]    Module helper loaded: MMM-Hotword
                  [2020-04-27 19:59:44.479] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.480] [LOG]    Module helper loaded: MMM-AssistantMk2
                  [2020-04-27 19:59:44.481] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.482] [LOG]    Module helper loaded: MMM-Assistant2Display
                  [2020-04-27 19:59:44.896] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.897] [LOG]    Module helper loaded: MMM-Parcel
                  [2020-04-27 19:59:44.980] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                  [2020-04-27 19:59:44.981] [LOG]    Loading module helpers ...
                  [2020-04-27 19:59:44.981] [LOG]    No helper found for module: MMM-Logging.
                  [2020-04-27 19:59:44.982] [LOG]    No helper found for module: alert.
                  [2020-04-27 19:59:44.983] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.983] [LOG]    Module helper loaded: updatenotification
                  [2020-04-27 19:59:44.983] [LOG]    No helper found for module: clock.
                  [2020-04-27 19:59:44.984] [LOG]    No helper found for module: MMM-OpenmapWeather.
                  [2020-04-27 19:59:44.985] [LOG]    No helper found for module: weatherforecast.
                  [2020-04-27 19:59:44.985] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.985] [LOG]    Module helper loaded: MMM-Tools
                  [2020-04-27 19:59:44.986] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                  [2020-04-27 19:59:44.986] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: mmm-hue-lights
                  [2020-04-27 19:59:44.987] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                  [2020-04-27 19:59:44.988] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.988] [LOG]    Module helper loaded: MMM-Hotword
                  [2020-04-27 19:59:44.989] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.989] [LOG]    Module helper loaded: MMM-AssistantMk2
                  [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Assistant2Display
                  [2020-04-27 19:59:44.990] [LOG]    Initializing new module helper ...
                  [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Parcel
                  [2020-04-27 19:59:44.997] [ERROR]  App threw an error during load
                  [2020-04-27 19:59:44.998] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                  [2020-04-27 19:59:45.000] [LOG]    Whoops! There was an uncaught exception...
                  [2020-04-27 19:59:45.000] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                  [2020-04-27 19:59:45.004] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-04-27 19:59:45.004] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2020-04-27 19:59:45.109] [LOG]    Launching application.
                    @JohnBachini yeh, looks like they have embedded a version of node in their package… don’t know how to fix that
                      oh ok, never mind, thanks for trying to help. :thumbs_up:
                      just one question for my own peace of mind and try not get too technical, why does it work in servernode, what’s the difference ?
                      Thanks again.
                        @JohnBachini servermode doesn’t load the modulename.js file, which is what drags in the rest of the stuff…
                        if u run servermode and then open a browser to the server ip, it will fail the same way
