    Works with Node Serveronly but not npm start MM
    24 Posts 4 Posters 5.5k Views 4 Watching
      sdetweil @JohnBachini
      @JohnBachini
      try this
      npm install electron-rebuild
      node_modules/.bin/electron-rebuild
      then npm start
        JohnBachini @sdetweil
        tried that and looks like im still getting the same errors:
        pi@MagicMirror:~ $ cd MagicMirror/
        pi@MagicMirror:~/MagicMirror $ npm install electron-rebuild
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + electron-rebuild@1.10.1
        updated 1 package and audited 3283 packages in 19.153s
        56 packages are looking for funding
          run `npm fund` for details
        found 24 vulnerabilities (22 low, 2 moderate)
          run `npm audit fix` to fix them, or `npm audit` for details
        pi@MagicMirror:~/MagicMirror $ node_modules/.bin/electron-rebuild
        ✔ Rebuild Complete
        pi@MagicMirror:~/MagicMirror $ npm start
        > magicmirror@2.11.0 start /home/pi/MagicMirror
        [2020-04-27 19:08:36.793] [LOG]    Starting MagicMirror: v2.11.0
        [2020-04-27 19:08:36.800] [LOG]    Loading config ...
        [2020-04-27 19:08:36.806] [LOG]    Loading module helpers ...
        [2020-04-27 19:08:36.807] [LOG]    No helper found for module: MMM-Logging.
        [2020-04-27 19:08:36.810] [LOG]    No helper found for module: alert.
        [2020-04-27 19:08:36.855] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:36.856] [LOG]    Module helper loaded: updatenotification
        [2020-04-27 19:08:36.857] [LOG]    No helper found for module: clock.
        [2020-04-27 19:08:36.857] [LOG]    No helper found for module: MMM-OpenmapWeather.
        [2020-04-27 19:08:36.858] [LOG]    No helper found for module: weatherforecast.
        [2020-04-27 19:08:37.208] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:37.209] [LOG]    Module helper loaded: MMM-Tools
        [2020-04-27 19:08:37.209] [LOG]    No helper found for module: MMM-PlexNowPlaying.
        [2020-04-27 19:08:37.211] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:37.211] [LOG]    Module helper loaded: mmm-hue-lights
        [2020-04-27 19:08:37.213] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:37.213] [LOG]    Module helper loaded: MMM-homeassistant-sensors
        [2020-04-27 19:08:37.389] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:37.390] [LOG]    Module helper loaded: MMM-Hotword
        [2020-04-27 19:08:38.531] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:38.532] [LOG]    Module helper loaded: MMM-AssistantMk2
        [2020-04-27 19:08:38.533] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:38.534] [LOG]    Module helper loaded: MMM-Assistant2Display
        [2020-04-27 19:08:38.920] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:38.921] [LOG]    Module helper loaded: MMM-Parcel
        [2020-04-27 19:08:38.988] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
        was compiled against a different Node.js version using
        NODE_MODULE_VERSION 64. This version of Node.js requires
        NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
        the module (for instance, using `npm rebuild` or `npm install`).
        [2020-04-27 19:08:38.989] [LOG]    Loading module helpers ...
        [2020-04-27 19:08:38.990] [LOG]    No helper found for module: MMM-Logging.
        [2020-04-27 19:08:38.990] [LOG]    No helper found for module: alert.
        [2020-04-27 19:08:38.991] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:38.992] [LOG]    Module helper loaded: updatenotification
        [2020-04-27 19:08:38.993] [LOG]    No helper found for module: clock.
        [2020-04-27 19:08:38.993] [LOG]    No helper found for module: MMM-OpenmapWeather.
        [2020-04-27 19:08:38.994] [LOG]    No helper found for module: weatherforecast.
        [2020-04-27 19:08:38.995] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:38.995] [LOG]    Module helper loaded: MMM-Tools
        [2020-04-27 19:08:38.996] [LOG]    No helper found for module: MMM-PlexNowPlaying.
        [2020-04-27 19:08:38.997] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:38.998] [LOG]    Module helper loaded: mmm-hue-lights
        [2020-04-27 19:08:39.000] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:39.001] [LOG]    Module helper loaded: MMM-homeassistant-sensors
        [2020-04-27 19:08:39.002] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:39.002] [LOG]    Module helper loaded: MMM-Hotword
        [2020-04-27 19:08:39.003] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:39.004] [LOG]    Module helper loaded: MMM-AssistantMk2
        [2020-04-27 19:08:39.004] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:39.005] [LOG]    Module helper loaded: MMM-Assistant2Display
        [2020-04-27 19:08:39.005] [LOG]    Initializing new module helper ...
        [2020-04-27 19:08:39.006] [LOG]    Module helper loaded: MMM-Parcel
        [2020-04-27 19:08:39.012] [ERROR]  App threw an error during load
        [2020-04-27 19:08:39.013] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
            at process.func (electron/js2c/asar.js:138:31)
            at process.func [as dlopen] (electron/js2c/asar.js:138:31)
            at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
            at Object.func (electron/js2c/asar.js:138:31)
            at Object.func [as .node] (electron/js2c/asar.js:138:31)
            at Module.load (internal/modules/cjs/loader.js:645:32)
            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/lib/index.js:1:13)
        [2020-04-27 19:08:39.014] [LOG]    Whoops! There was an uncaught exception...
        [2020-04-27 19:08:39.015] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
        [2020-04-27 19:08:39.018] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-04-27 19:08:39.019] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-04-27 19:08:39.144] [LOG]    Launching application.
          @JohnBachini said in Works with Node Serveronly but not npm start MM:
          ok, need to get forceful…
          cd /home/pi/MagicMirror/modules/MMM-synology-ds
          rm -rf node_modules
          rm package-lock.json
          npm install
            Still no joy :-(
            pi@MagicMirror:~ $ cd MagicMirror//modules/MMM-synology-ds/
            pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm -rf node_modules
            pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm package-lock.json
            pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm install
            > mmmagic@0.5.3 install /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
            > node-gyp rebuild
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/apprentice.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/apptype.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/ascmagic.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf_time.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/compress.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/der.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/encoding.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/fsmagic.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/funcs.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/is_tar.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/magic.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/print.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/readcdf.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/readelf.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/softmagic.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/fmtcheck.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcat.o
              CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcpy.o
              AR(target) Release/obj.target/deps/libmagic/magic.a
              COPY Release/magic.a
              CXX(target) Release/obj.target/magic/src/binding.o
            In file included from ../src/binding.cc:3:
            ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
            ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                 , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
            ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>&)’:
            ../src/binding.cc:184:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                              (uv_after_work_cb)Magic::DetectAfter);
            ../src/binding.cc: In static member function ‘static void Magic::Detect(const Nan::FunctionCallbackInfo<v8::Value>&)’:
            ../src/binding.cc:217:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            In file included from ../src/binding.cc:1:
            ../src/binding.cc: At global scope:
            /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                   (node::addon_register_func) (regfunc),                          \
            /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
               NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/binding.cc:415:3: note: in expansion of macro ‘NODE_MODULE’
               NODE_MODULE(magic, init);
            In file included from /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:63,
            /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
            /home/pi/.cache/node-gyp/10.20.0/include/node/node_object_wrap.h:84:78:   required from here
            /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                            reinterpret_cast<Callback>(callback), type);
            /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
            ../../nan/nan_object_wrap.h:65:61:   required from here
            /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
              SOLINK_MODULE(target) Release/obj.target/magic.node
              COPY Release/magic.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
            npm notice created a lockfile as package-lock.json. You should commit this file.
            added 12 packages from 23 contributors and audited 12 packages in 21.888s
            found 0 vulnerabilities
            pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ ^C
            pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ cd ..
            pi@MagicMirror:~/MagicMirror/modules $ cd ..
            pi@MagicMirror:~/MagicMirror $ npm start mm
            > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "mm"
            [2020-04-27 19:59:42.738] [LOG]    Starting MagicMirror: v2.11.0
            [2020-04-27 19:59:42.745] [LOG]    Loading config ...
            [2020-04-27 19:59:42.751] [LOG]    Loading module helpers ...
            [2020-04-27 19:59:42.754] [LOG]    No helper found for module: MMM-Logging.
            [2020-04-27 19:59:42.757] [LOG]    No helper found for module: alert.
            [2020-04-27 19:59:42.798] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:42.799] [LOG]    Module helper loaded: updatenotification
            [2020-04-27 19:59:42.800] [LOG]    No helper found for module: clock.
            [2020-04-27 19:59:42.800] [LOG]    No helper found for module: MMM-OpenmapWeather.
            [2020-04-27 19:59:42.801] [LOG]    No helper found for module: weatherforecast.
            [2020-04-27 19:59:43.153] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:43.154] [LOG]    Module helper loaded: MMM-Tools
            [2020-04-27 19:59:43.155] [LOG]    No helper found for module: MMM-PlexNowPlaying.
            [2020-04-27 19:59:43.157] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:43.157] [LOG]    Module helper loaded: mmm-hue-lights
            [2020-04-27 19:59:43.159] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:43.160] [LOG]    Module helper loaded: MMM-homeassistant-sensors
            [2020-04-27 19:59:43.350] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:43.350] [LOG]    Module helper loaded: MMM-Hotword
            [2020-04-27 19:59:44.479] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.480] [LOG]    Module helper loaded: MMM-AssistantMk2
            [2020-04-27 19:59:44.481] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.482] [LOG]    Module helper loaded: MMM-Assistant2Display
            [2020-04-27 19:59:44.896] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.897] [LOG]    Module helper loaded: MMM-Parcel
            [2020-04-27 19:59:44.980] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
            [2020-04-27 19:59:44.981] [LOG]    Loading module helpers ...
            [2020-04-27 19:59:44.981] [LOG]    No helper found for module: MMM-Logging.
            [2020-04-27 19:59:44.982] [LOG]    No helper found for module: alert.
            [2020-04-27 19:59:44.983] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.983] [LOG]    Module helper loaded: updatenotification
            [2020-04-27 19:59:44.983] [LOG]    No helper found for module: clock.
            [2020-04-27 19:59:44.984] [LOG]    No helper found for module: MMM-OpenmapWeather.
            [2020-04-27 19:59:44.985] [LOG]    No helper found for module: weatherforecast.
            [2020-04-27 19:59:44.985] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.985] [LOG]    Module helper loaded: MMM-Tools
            [2020-04-27 19:59:44.986] [LOG]    No helper found for module: MMM-PlexNowPlaying.
            [2020-04-27 19:59:44.986] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: mmm-hue-lights
            [2020-04-27 19:59:44.987] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: MMM-homeassistant-sensors
            [2020-04-27 19:59:44.988] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.988] [LOG]    Module helper loaded: MMM-Hotword
            [2020-04-27 19:59:44.989] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.989] [LOG]    Module helper loaded: MMM-AssistantMk2
            [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Assistant2Display
            [2020-04-27 19:59:44.990] [LOG]    Initializing new module helper ...
            [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Parcel
            [2020-04-27 19:59:44.997] [ERROR]  App threw an error during load
            [2020-04-27 19:59:44.998] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
            [2020-04-27 19:59:45.000] [LOG]    Whoops! There was an uncaught exception...
            [2020-04-27 19:59:45.000] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
            [2020-04-27 19:59:45.004] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2020-04-27 19:59:45.004] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [2020-04-27 19:59:45.109] [LOG]    Launching application.
              @JohnBachini yeh, looks like they have embedded a version of node in their package… don’t know how to fix that
                oh ok, never mind, thanks for trying to help. :thumbs_up:
                just one question for my own peace of mind and try not get too technical, why does it work in servernode, what’s the difference ?
                Thanks again.
                  @JohnBachini servermode doesn’t load the modulename.js file, which is what drags in the rest of the stuff…
                  if u run servermode and then open a browser to the server ip, it will fail the same way
                    But it doesnt ,it works fine if i servermode and then connect via browser, no errors console at all and the module works as it connect to synology and reports as expected.
                    Very strange.
                      @JohnBachini is the browser ON the same system?
                      how about opening chromium-browser on the same server to the server
                      electron is all javascript…
                        Just tried it and it works in chromium on server !?
                          @JohnBachini different version of javascript inside chromium…
                            oh i see… Thanks again.
                              bhepler Module Developer
                              Please use the markdown features of the forum when posting code and/or error messages.
                              • lavolp3L Offline
                                lavolp3 Module Developer @bhepler
                                @bhepler Added code tags for better readability
                                How to troubleshoot modules
                                MMM-soccer v2, MMM-AVStock
                                  try this
                                  cd ~/MagicMirror/modules/MMM-synology-ds
                                  npm install mmmagic
                                    Tried , unfortunately doesn’t seem to have made any difference.
                                    pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm install mmmagic
                                    > node-gyp rebuild
                                    ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>& ’:
                                    /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callbac ’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                    + mmmagic@0.5.3
                                    updated 1 package and audited 14 packages in 18.498s
                                    pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ cd …
                                    pi@MagicMirror:~/MagicMirror/modules $ cd …
                                    [2020-04-28 14:26:28.842] [LOG]    Starting MagicMirror: v2.11.0
                                    [2020-04-28 14:26:28.849] [LOG]    Loading config ...
                                    [2020-04-28 14:26:28.855] [LOG]    Loading module helpers ...
                                    [2020-04-28 14:26:28.857] [LOG]    No helper found for module: MMM-Logging.
                                    [2020-04-28 14:26:28.860] [LOG]    No helper found for module: alert.
                                    [2020-04-28 14:26:28.895] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:28.896] [LOG]    Module helper loaded: updatenotification
                                    [2020-04-28 14:26:28.896] [LOG]    No helper found for module: clock.
                                    [2020-04-28 14:26:28.897] [LOG]    No helper found for module: MMM-OpenmapWeather.
                                    [2020-04-28 14:26:28.898] [LOG]    No helper found for module: weatherforecast.
                                    [2020-04-28 14:26:29.198] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:29.199] [LOG]    Module helper loaded: MMM-Tools
                                    [2020-04-28 14:26:29.200] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                                    [2020-04-28 14:26:29.202] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:29.202] [LOG]    Module helper loaded: mmm-hue-lights
                                    [2020-04-28 14:26:29.204] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:29.205] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                    [2020-04-28 14:26:29.360] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:29.361] [LOG]    Module helper loaded: MMM-Hotword
                                    [2020-04-28 14:26:30.447] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.447] [LOG]    Module helper loaded: MMM-AssistantMk2
                                    [2020-04-28 14:26:30.449] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.449] [LOG]    Module helper loaded: MMM-Assistant2Display
                                    [2020-04-28 14:26:30.836] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.836] [LOG]    Module helper loaded: MMM-Parcel
                                    [2020-04-28 14:26:30.909] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                    [2020-04-28 14:26:30.910] [LOG]    Loading module helpers ...
                                    [2020-04-28 14:26:30.911] [LOG]    No helper found for module: MMM-Logging.
                                    [2020-04-28 14:26:30.911] [LOG]    No helper found for module: alert.
                                    [2020-04-28 14:26:30.912] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.912] [LOG]    Module helper loaded: updatenotification
                                    [2020-04-28 14:26:30.912] [LOG]    No helper found for module: clock.
                                    [2020-04-28 14:26:30.913] [LOG]    No helper found for module: MMM-OpenmapWeather.
                                    [2020-04-28 14:26:30.913] [LOG]    No helper found for module: weatherforecast.
                                    [2020-04-28 14:26:30.914] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.914] [LOG]    Module helper loaded: MMM-Tools
                                    [2020-04-28 14:26:30.915] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                                    [2020-04-28 14:26:30.915] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.915] [LOG]    Module helper loaded: mmm-hue-lights
                                    [2020-04-28 14:26:30.916] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.916] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                    [2020-04-28 14:26:30.916] [LOG]    Module helper loaded: MMM-Hotword
                                    [2020-04-28 14:26:30.917] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.917] [LOG]    Module helper loaded: MMM-AssistantMk2
                                    [2020-04-28 14:26:30.918] [LOG]    Initializing new module helper ...
                                    [2020-04-28 14:26:30.918] [LOG]    Module helper loaded: MMM-Assistant2Display
                                    [2020-04-28 14:26:30.918] [LOG]    Module helper loaded: MMM-Parcel
                                    [2020-04-28 14:26:30.924] [ERROR]  App threw an error during load
                                    [2020-04-28 14:26:30.925] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                    [2020-04-28 14:26:30.926] [LOG]    Whoops! There was an uncaught exception...
                                    [2020-04-28 14:26:30.926] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                    [2020-04-28 14:26:30.930] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2020-04-28 14:26:30.930] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [2020-04-28 14:26:31.008] [LOG]    Launching application.
                                    ^C[2020-04-28 14:26:54.721] [LOG]    Shutting down server...
                                    [2020-04-28 14:26:54.725] [LOG]    Stopping module helper: updatenotification
                                    [2020-04-28 14:26:54.726] [LOG]    Stopping module helper: MMM-Tools
                                    [2020-04-28 14:26:54.726] [LOG]    Stopping module helper: mmm-hue-lights
                                    [2020-04-28 14:26:54.727] [LOG]    Stopping module helper: MMM-homeassistant-sensors
                                    [2020-04-28 14:26:54.728] [LOG]    Stopping module helper: MMM-Hotword
                                    [2020-04-28 14:26:54.728] [LOG]    Stopping module helper: MMM-AssistantMk2
                                    [2020-04-28 14:26:54.729] [LOG]    Stopping module helper: MMM-Assistant2Display
                                    [2020-04-28 14:26:54.730] [LOG]    Stopping module helper: MMM-Parcel
                                    [2020-04-28 14:26:54.730] [LOG]    Stopping module helper: updatenotification
                                    [2020-04-28 14:26:54.731] [LOG]    Stopping module helper: MMM-Tools
                                    [2020-04-28 14:26:54.731] [LOG]    Stopping module helper: mmm-hue-lights
                                    [2020-04-28 14:26:54.732] [LOG]    Stopping module helper: MMM-homeassistant-sensors
                                    [2020-04-28 14:26:54.733] [LOG]    Stopping module helper: MMM-Hotword
                                    [2020-04-28 14:26:54.733] [LOG]    Stopping module helper: MMM-AssistantMk2
                                    [2020-04-28 14:26:54.734] [LOG]    Stopping module helper: MMM-Assistant2Display
                                    [2020-04-28 14:26:54.734] [LOG]    Stopping module helper: MMM-Parcel
                                      @JohnBachini what a pain
                                      try this
                                      cd ~/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
                                      # force rebuild to the version of node electron is running
                                      ~/MagicMirror/node_modules/.bin/electron-rebuild
                                      try again
                                      J 1 Reply Last reply Reply Quote 2
                                        Wow… you got it working… thanks a lot for that.!! :thumbs_up:
                                        Think there were a few people who couldn’t get this module working so hopefully this will of solved it for them as well.
                                          @JohnBachini thanks for the feedback… looks like you gotta go ALL the way into the failing folder. sheesh…
                                            I updated the two issues in this module on github that reference this problem with the fix instructions here
                                            so eventually the google search will link them together
