    Works with Node Serveronly but not npm start MM
    24 Posts 4 Posters 5.7k Views 4 Watching
      sdetweil @JohnBachini
      @JohnBachini said in Works with Node Serveronly but not npm start MM:
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
      ok, need to get forceful…
      cd /home/pi/MagicMirror/modules/MMM-synology-ds
      rm -rf node_modules
      rm package-lock.json
      npm install
        JohnBachini @sdetweil
        Still no joy :-(
        pi@MagicMirror:~ $ cd MagicMirror//modules/MMM-synology-ds/
        pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm -rf node_modules
        pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ rm package-lock.json
        pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm install
        > mmmagic@0.5.3 install /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
        > node-gyp rebuild
        make: Entering directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/apprentice.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/apptype.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/ascmagic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf_time.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/compress.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/der.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/encoding.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/fsmagic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/funcs.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/is_tar.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/magic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/print.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/readcdf.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/readelf.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/softmagic.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/fmtcheck.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcat.o
          CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcpy.o
          AR(target) Release/obj.target/deps/libmagic/magic.a
          COPY Release/magic.a
          CXX(target) Release/obj.target/magic/src/binding.o
        In file included from ../src/binding.cc:3:
        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>&)’:
        ../src/binding.cc:184:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                          (uv_after_work_cb)Magic::DetectAfter);
        ../src/binding.cc: In static member function ‘static void Magic::Detect(const Nan::FunctionCallbackInfo<v8::Value>&)’:
        ../src/binding.cc:217:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        In file included from ../src/binding.cc:1:
        ../src/binding.cc: At global scope:
        /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/binding.cc:415:3: note: in expansion of macro ‘NODE_MODULE’
           NODE_MODULE(magic, init);
        In file included from /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:63,
        /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
        /home/pi/.cache/node-gyp/10.20.0/include/node/node_object_wrap.h:84:78:   required from here
        /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                        reinterpret_cast<Callback>(callback), type);
        /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
        ../../nan/nan_object_wrap.h:65:61:   required from here
        /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
          SOLINK_MODULE(target) Release/obj.target/magic.node
          COPY Release/magic.node
        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
        npm notice created a lockfile as package-lock.json. You should commit this file.
        added 12 packages from 23 contributors and audited 12 packages in 21.888s
        found 0 vulnerabilities
        pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ ^C
        pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ cd ..
        pi@MagicMirror:~/MagicMirror/modules $ cd ..
        pi@MagicMirror:~/MagicMirror $ npm start mm
        > magicmirror@2.11.0 start /home/pi/MagicMirror
        > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "mm"
        [2020-04-27 19:59:42.738] [LOG]    Starting MagicMirror: v2.11.0
        [2020-04-27 19:59:42.745] [LOG]    Loading config ...
        [2020-04-27 19:59:42.751] [LOG]    Loading module helpers ...
        [2020-04-27 19:59:42.754] [LOG]    No helper found for module: MMM-Logging.
        [2020-04-27 19:59:42.757] [LOG]    No helper found for module: alert.
        [2020-04-27 19:59:42.798] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:42.799] [LOG]    Module helper loaded: updatenotification
        [2020-04-27 19:59:42.800] [LOG]    No helper found for module: clock.
        [2020-04-27 19:59:42.800] [LOG]    No helper found for module: MMM-OpenmapWeather.
        [2020-04-27 19:59:42.801] [LOG]    No helper found for module: weatherforecast.
        [2020-04-27 19:59:43.153] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:43.154] [LOG]    Module helper loaded: MMM-Tools
        [2020-04-27 19:59:43.155] [LOG]    No helper found for module: MMM-PlexNowPlaying.
        [2020-04-27 19:59:43.157] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:43.157] [LOG]    Module helper loaded: mmm-hue-lights
        [2020-04-27 19:59:43.159] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:43.160] [LOG]    Module helper loaded: MMM-homeassistant-sensors
        [2020-04-27 19:59:43.350] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:43.350] [LOG]    Module helper loaded: MMM-Hotword
        [2020-04-27 19:59:44.479] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.480] [LOG]    Module helper loaded: MMM-AssistantMk2
        [2020-04-27 19:59:44.481] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.482] [LOG]    Module helper loaded: MMM-Assistant2Display
        [2020-04-27 19:59:44.896] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.897] [LOG]    Module helper loaded: MMM-Parcel
        [2020-04-27 19:59:44.980] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
        was compiled against a different Node.js version using
        the module (for instance, using `npm rebuild` or `npm install`).
        [2020-04-27 19:59:44.981] [LOG]    Loading module helpers ...
        [2020-04-27 19:59:44.981] [LOG]    No helper found for module: MMM-Logging.
        [2020-04-27 19:59:44.982] [LOG]    No helper found for module: alert.
        [2020-04-27 19:59:44.983] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.983] [LOG]    Module helper loaded: updatenotification
        [2020-04-27 19:59:44.983] [LOG]    No helper found for module: clock.
        [2020-04-27 19:59:44.984] [LOG]    No helper found for module: MMM-OpenmapWeather.
        [2020-04-27 19:59:44.985] [LOG]    No helper found for module: weatherforecast.
        [2020-04-27 19:59:44.985] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.985] [LOG]    Module helper loaded: MMM-Tools
        [2020-04-27 19:59:44.986] [LOG]    No helper found for module: MMM-PlexNowPlaying.
        [2020-04-27 19:59:44.986] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: mmm-hue-lights
        [2020-04-27 19:59:44.987] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.987] [LOG]    Module helper loaded: MMM-homeassistant-sensors
        [2020-04-27 19:59:44.988] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.988] [LOG]    Module helper loaded: MMM-Hotword
        [2020-04-27 19:59:44.989] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.989] [LOG]    Module helper loaded: MMM-AssistantMk2
        [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Assistant2Display
        [2020-04-27 19:59:44.990] [LOG]    Initializing new module helper ...
        [2020-04-27 19:59:44.990] [LOG]    Module helper loaded: MMM-Parcel
        [2020-04-27 19:59:44.997] [ERROR]  App threw an error during load
        [2020-04-27 19:59:44.998] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
            at process.func (electron/js2c/asar.js:138:31)
            at process.func [as dlopen] (electron/js2c/asar.js:138:31)
            at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
            at Object.func (electron/js2c/asar.js:138:31)
            at Object.func [as .node] (electron/js2c/asar.js:138:31)
            at Module.load (internal/modules/cjs/loader.js:645:32)
            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/lib/index.js:1:13)
        [2020-04-27 19:59:45.000] [LOG]    Whoops! There was an uncaught exception...
        [2020-04-27 19:59:45.000] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
        [2020-04-27 19:59:45.004] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-04-27 19:59:45.004] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-04-27 19:59:45.109] [LOG]    Launching application.
          @JohnBachini yeh, looks like they have embedded a version of node in their package… don’t know how to fix that
            oh ok, never mind, thanks for trying to help. :thumbs_up:
            just one question for my own peace of mind and try not get too technical, why does it work in servernode, what’s the difference ?
            Thanks again.
              @JohnBachini servermode doesn’t load the modulename.js file, which is what drags in the rest of the stuff…
              if u run servermode and then open a browser to the server ip, it will fail the same way
                But it doesnt ,it works fine if i servermode and then connect via browser, no errors console at all and the module works as it connect to synology and reports as expected.
                Very strange.
                  @JohnBachini is the browser ON the same system?
                  how about opening chromium-browser on the same server to the server
                  electron is all javascript…
                    Just tried it and it works in chromium on server !?
                      @JohnBachini different version of javascript inside chromium…
                        oh i see… Thanks again.
                          bhepler Module Developer
                          Please use the markdown features of the forum when posting code and/or error messages.
                          • lavolp3L Offline
                            lavolp3 Module Developer @bhepler
                            @bhepler Added code tags for better readability
                            How to troubleshoot modules
                            MMM-soccer v2, MMM-AVStock
                              try this
                              cd ~/MagicMirror/modules/MMM-synology-ds
                              npm install mmmagic
                                Tried , unfortunately doesn’t seem to have made any difference.
                                pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm install mmmagic
                                > node-gyp rebuild
                                ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>& ’:
                                /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callbac ’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                + mmmagic@0.5.3
                                updated 1 package and audited 14 packages in 18.498s
                                pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ cd …
                                pi@MagicMirror:~/MagicMirror/modules $ cd …
                                [2020-04-28 14:26:28.842] [LOG]    Starting MagicMirror: v2.11.0
                                [2020-04-28 14:26:28.849] [LOG]    Loading config ...
                                [2020-04-28 14:26:28.855] [LOG]    Loading module helpers ...
                                [2020-04-28 14:26:28.857] [LOG]    No helper found for module: MMM-Logging.
                                [2020-04-28 14:26:28.860] [LOG]    No helper found for module: alert.
                                [2020-04-28 14:26:28.895] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:28.896] [LOG]    Module helper loaded: updatenotification
                                [2020-04-28 14:26:28.896] [LOG]    No helper found for module: clock.
                                [2020-04-28 14:26:28.897] [LOG]    No helper found for module: MMM-OpenmapWeather.
                                [2020-04-28 14:26:28.898] [LOG]    No helper found for module: weatherforecast.
                                [2020-04-28 14:26:29.198] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:29.199] [LOG]    Module helper loaded: MMM-Tools
                                [2020-04-28 14:26:29.200] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                                [2020-04-28 14:26:29.202] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:29.202] [LOG]    Module helper loaded: mmm-hue-lights
                                [2020-04-28 14:26:29.204] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:29.205] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                [2020-04-28 14:26:29.360] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:29.361] [LOG]    Module helper loaded: MMM-Hotword
                                [2020-04-28 14:26:30.447] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.447] [LOG]    Module helper loaded: MMM-AssistantMk2
                                [2020-04-28 14:26:30.449] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.449] [LOG]    Module helper loaded: MMM-Assistant2Display
                                [2020-04-28 14:26:30.836] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.836] [LOG]    Module helper loaded: MMM-Parcel
                                [2020-04-28 14:26:30.909] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                [2020-04-28 14:26:30.910] [LOG]    Loading module helpers ...
                                [2020-04-28 14:26:30.911] [LOG]    No helper found for module: MMM-Logging.
                                [2020-04-28 14:26:30.911] [LOG]    No helper found for module: alert.
                                [2020-04-28 14:26:30.912] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.912] [LOG]    Module helper loaded: updatenotification
                                [2020-04-28 14:26:30.912] [LOG]    No helper found for module: clock.
                                [2020-04-28 14:26:30.913] [LOG]    No helper found for module: MMM-OpenmapWeather.
                                [2020-04-28 14:26:30.913] [LOG]    No helper found for module: weatherforecast.
                                [2020-04-28 14:26:30.914] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.914] [LOG]    Module helper loaded: MMM-Tools
                                [2020-04-28 14:26:30.915] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                                [2020-04-28 14:26:30.915] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.915] [LOG]    Module helper loaded: mmm-hue-lights
                                [2020-04-28 14:26:30.916] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.916] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                [2020-04-28 14:26:30.916] [LOG]    Module helper loaded: MMM-Hotword
                                [2020-04-28 14:26:30.917] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.917] [LOG]    Module helper loaded: MMM-AssistantMk2
                                [2020-04-28 14:26:30.918] [LOG]    Initializing new module helper ...
                                [2020-04-28 14:26:30.918] [LOG]    Module helper loaded: MMM-Assistant2Display
                                [2020-04-28 14:26:30.918] [LOG]    Module helper loaded: MMM-Parcel
                                [2020-04-28 14:26:30.924] [ERROR]  App threw an error during load
                                [2020-04-28 14:26:30.925] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                [2020-04-28 14:26:30.926] [LOG]    Whoops! There was an uncaught exception...
                                [2020-04-28 14:26:30.926] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                [2020-04-28 14:26:30.930] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [2020-04-28 14:26:30.930] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                [2020-04-28 14:26:31.008] [LOG]    Launching application.
                                ^C[2020-04-28 14:26:54.721] [LOG]    Shutting down server...
                                [2020-04-28 14:26:54.725] [LOG]    Stopping module helper: updatenotification
                                [2020-04-28 14:26:54.726] [LOG]    Stopping module helper: MMM-Tools
                                [2020-04-28 14:26:54.726] [LOG]    Stopping module helper: mmm-hue-lights
                                [2020-04-28 14:26:54.727] [LOG]    Stopping module helper: MMM-homeassistant-sensors
                                [2020-04-28 14:26:54.728] [LOG]    Stopping module helper: MMM-Hotword
                                [2020-04-28 14:26:54.728] [LOG]    Stopping module helper: MMM-AssistantMk2
                                [2020-04-28 14:26:54.729] [LOG]    Stopping module helper: MMM-Assistant2Display
                                [2020-04-28 14:26:54.730] [LOG]    Stopping module helper: MMM-Parcel
                                [2020-04-28 14:26:54.730] [LOG]    Stopping module helper: updatenotification
                                [2020-04-28 14:26:54.731] [LOG]    Stopping module helper: MMM-Tools
                                [2020-04-28 14:26:54.731] [LOG]    Stopping module helper: mmm-hue-lights
                                [2020-04-28 14:26:54.732] [LOG]    Stopping module helper: MMM-homeassistant-sensors
                                [2020-04-28 14:26:54.733] [LOG]    Stopping module helper: MMM-Hotword
                                [2020-04-28 14:26:54.733] [LOG]    Stopping module helper: MMM-AssistantMk2
                                [2020-04-28 14:26:54.734] [LOG]    Stopping module helper: MMM-Assistant2Display
                                [2020-04-28 14:26:54.734] [LOG]    Stopping module helper: MMM-Parcel
                                  @JohnBachini what a pain
                                  try this
                                  cd ~/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
                                  # force rebuild to the version of node electron is running
                                  ~/MagicMirror/node_modules/.bin/electron-rebuild
                                  try again
                                  J 1 Reply Last reply Reply Quote 2
                                    Wow… you got it working… thanks a lot for that.!! :thumbs_up:
                                    Think there were a few people who couldn’t get this module working so hopefully this will of solved it for them as well.
                                      @JohnBachini thanks for the feedback… looks like you gotta go ALL the way into the failing folder. sheesh…
                                        I updated the two issues in this module on github that reference this problem with the fix instructions here
                                        so eventually the google search will link them together
                                          I bet you thought you’d heard the last of this, so you know how you managed to get it all working. Well the problem now is the complete opposite. In that now it doesn’t work node servermode. ?
                                          I thought i was going mad and must have been running it incorrectly :thinking_face:
                                          Any ideas ?
                                          pi@MagicMirror:~/MagicMirror $ node serveronly
                                          [2020-04-29 14:24:42.858] [LOG]    Starting MagicMirror: v2.11.0
                                          [2020-04-29 14:24:42.868] [LOG]    Loading config ...
                                          [2020-04-29 14:24:42.873] [LOG]    Loading module helpers ...
                                          [2020-04-29 14:24:42.874] [LOG]    No helper found for module: MMM-Logging.
                                          [2020-04-29 14:24:42.875] [LOG]    No helper found for module: alert.
                                          [2020-04-29 14:24:42.911] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:42.912] [LOG]    Module helper loaded: updatenotification
                                          [2020-04-29 14:24:42.912] [LOG]    No helper found for module: clock.
                                          [2020-04-29 14:24:42.913] [LOG]    No helper found for module: MMM-OpenmapWeather.
                                          [2020-04-29 14:24:42.913] [LOG]    No helper found for module: weatherforecast.
                                          [2020-04-29 14:24:43.238] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:43.238] [LOG]    Module helper loaded: MMM-Tools
                                          [2020-04-29 14:24:43.239] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                                          [2020-04-29 14:24:43.240] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:43.241] [LOG]    Module helper loaded: mmm-hue-lights
                                          [2020-04-29 14:24:43.243] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:43.243] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                          [2020-04-29 14:24:43.366] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:43.367] [LOG]    Module helper loaded: MMM-Hotword
                                          [2020-04-29 14:24:44.467] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.468] [LOG]    Module helper loaded: MMM-AssistantMk2
                                          [2020-04-29 14:24:44.470] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.470] [LOG]    Module helper loaded: MMM-Assistant2Display
                                          [2020-04-29 14:24:44.849] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.850] [LOG]    Module helper loaded: MMM-Parcel
                                          [2020-04-29 14:24:44.899] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                          NODE_MODULE_VERSION 73. This version of Node.js requires
                                          NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                                          [2020-04-29 14:24:44.900] [LOG]    Loading module helpers ...
                                          [2020-04-29 14:24:44.901] [LOG]    No helper found for module: MMM-Logging.
                                          [2020-04-29 14:24:44.902] [LOG]    No helper found for module: alert.
                                          [2020-04-29 14:24:44.902] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.903] [LOG]    Module helper loaded: updatenotification
                                          [2020-04-29 14:24:44.903] [LOG]    No helper found for module: clock.
                                          [2020-04-29 14:24:44.904] [LOG]    No helper found for module: MMM-OpenmapWeather.
                                          [2020-04-29 14:24:44.904] [LOG]    No helper found for module: weatherforecast.
                                          [2020-04-29 14:24:44.905] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.906] [LOG]    Module helper loaded: MMM-Tools
                                          [2020-04-29 14:24:44.906] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                                          [2020-04-29 14:24:44.907] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.907] [LOG]    Module helper loaded: mmm-hue-lights
                                          [2020-04-29 14:24:44.908] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.908] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                          [2020-04-29 14:24:44.909] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.910] [LOG]    Module helper loaded: MMM-Hotword
                                          [2020-04-29 14:24:44.910] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.911] [LOG]    Module helper loaded: MMM-AssistantMk2
                                          [2020-04-29 14:24:44.911] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.912] [LOG]    Module helper loaded: MMM-Assistant2Display
                                          [2020-04-29 14:24:44.912] [LOG]    Initializing new module helper ...
                                          [2020-04-29 14:24:44.913] [LOG]    Module helper loaded: MMM-Parcel
                                          [2020-04-29 14:24:44.920] [LOG]    Whoops! There was an uncaught exception...
                                          [2020-04-29 14:24:44.920] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                              at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                                              at Module.require (internal/modules/cjs/loader.js:692:17)
                                              at require (internal/modules/cjs/helpers.js:25:18)
                                          [2020-04-29 14:24:44.924] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [2020-04-29 14:24:44.925] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
