    MMM-GooglePhotos
    294 Posts 56 Posters 409.6k Views 59 Watching
      dumitrudany
      I’m using this module. Thank you for developing it. Everything seems to work normal except that it’s not scanning for new added or deleted photo from the albums.
      I’m using the node serveronly command to start the MagicMirror2 without no errors reporting. I couldn’t figured with npm start dev. I have activated the debug, and only once it’s scanning the album.
      Is this config parameter still working: scanInterval: 1000*60*10,?
      As for me it isn’t and I saw it’s not described in readme doc. Or is there any other way to let the module scan automatically for new added photos?
      I only found the way of refreshing the browsing page, which works but it’s not what I need.
      Thanks!
      This is my config:
      			  module: "MMM-GooglePhotos",
      			  position: "fullscreen_below",
      					albums: ["TESTARE"],
      					updateInterval: 100 * 60, // minimum 10 seconds.
      					scanInterval: 1000*60, //10 minutes
      					sort: "new", // "old", "random"
      					uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
      					condition: {
      						fromDate: null, // Or "2018-03", RFC ... format available
      						toDate: null, // Or "2019-12-25",
      						minWidth: null, // Or 400
      						maxWidth: null, // Or 8000
      						minHeight: null, // Or 400
      						maxHeight: null, // Or 8000
      						minWHRatio: null,
      						maxWHRatio: null,
      						// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   < 1 : Portraited Photo, > 1 : Landscaped Photo)
      					showWidth: 1080, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
      					showHeight: 1920,
      					//timeFormat: "YYYY/MM/DD HH:mm", // Or `relative` can be used.
      ? 1 Reply Last reply
        A Former User @dumitrudany
        @dumitrudany
        Not possible immediately as you wish. There is no way to detect whether you add/modify photos or not. Maybe frequent scanning would get a similar result, but it will consume and waste too many API quota. I can’t recommend it at all.
        • G
          gonzonia @Guest
          @Sean Thanks. I think if you can gracefully handle the bad connection (no matter where it’s from) and reconnect once the connection works again, the image being stuck won’t be an issue. Right now once the connection breaks the module can’t recover.
          G 1 Reply Last reply
          • G
            gonzonia @gonzonia
            @Sean I’ve been looking into this, because I’m really don’t think it’s my network (no other module has this issue and there’s no similar problems anywhere else on the network). The first error doesn’t seem to be fatal, but the second is.
            These are the errors I’m seeing in my Out.log
            [2020-04-27 17:33:15.365] [LOG]    2020-04-27T17:33:15 <log> [GPHOTOS:CORE] Error: socket hang up (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
            and
            [2020-04-27 18:51:15.155] [LOG]    2020-04-27T18:51:15 <log> [GPHOTOS:CORE] Error: Client network socket disconnected before secure TLS connectionwas established (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
            I came across this issue on gitub related to Google APIs. https://github.com/googleapis/nodejs-bigquery/issues/624
            Not sure it’s related.
            In Error.log I see
            2020-04-27 17:33:15.356] [ERROR]  2020-04-27T17:33:15 <error> Error: socket hang up
                at connResetException (internal/errors.js:559:14)
                at TLSSocket.socketOnEnd (_http_client.js:436:23)
                at TLSSocket.emit (events.js:205:15)
                at endReadableNT (_stream_readable.js:1154:12)
                at processTicksAndRejections (internal/process/task_queues.js:84:9) {
              code: 'ECONNRESET'
            } (/home/pi/MagicMirror/js/app.js:40 process.<anonymous>)
            [2020-04-27 17:33:15.361] [ERROR]  2020-04-27T17:33:15 <error> Error: socket hang up
              code: 'ECONNRESET'
            [2020-04-27 17:33:15.367] [ERROR]  2020-04-27T17:33:15 <error> (node:17589) UnhandledPromiseRejectionWarning: Error: socket hang up
                at processTicksAndRejections (internal/process/task_queues.js:84:9) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
            [2020-04-27 17:33:15.368] [ERROR]  2020-04-27T17:33:15 <error> (node:17589) UnhandledPromiseRejectionWarning: Error: socket hang up
            [2020-04-27 17:33:15.369] [ERROR]  2020-04-27T17:33:15 <error> (node:17589) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
            [2020-04-27 17:33:15.370] [ERROR]  2020-04-27T17:33:15 <error> (node:17589) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
            [2020-04-27 17:33:15.371] [ERROR]  2020-04-27T17:33:15 <error> (node:17589) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
            and
            [2020-04-27 18:51:15.161] [ERROR]  2020-04-27T18:51:15 <error> (node:17589) UnhandledPromiseRejectionWarning: Error: Client network socket disconnected before secure TLS connection was established
                at TLSSocket.onConnectEnd (_tls_wrap.js:1355:19)
                at Object.onceWrapper (events.js:288:20)
            [2020-04-27 18:51:15.164] [ERROR]  2020-04-27T18:51:15 <error> (node:17589) UnhandledPromiseRejectionWarning: Error: Client network socket disconnected before secure TLS connection was established
            [2020-04-27 18:51:15.166] [ERROR]  2020-04-27T18:51:15 <error> (node:17589) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
            [2020-04-27 18:51:15.168] [ERROR]  2020-04-27T18:51:15 <error> (node:17589) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
              bhepler Module Developer @zolabus
              @zolabus - That is merely a warning, not an error. That won’t be the source of the problem.
                sdetweil @bhepler
                @bhepler Unhandled promise rejection.
                I disagree… that means the code didn’t anticipate the error, and was waiting for the good completion which will never come…
                gotta have a .catch() on every .then()
                B 1 Reply Last reply
                  A Former User
                  Unhandled promise rejection is not the reason of this symptom, rather result.
                  Anyway,
                  I think Client network socket disconnected before secure TLS connection was established is not coming from program logic. It probably might be caused from unstable network status. (Especially handling TLS connection).
                  There is no one reason of that issue, so it has no simple solution to diagnose or solve.
                  I can’t represent this symptom, so hard to find the solution at this moment.
                  @gonzonia
                  For me;
                  When I force to break the connection then reconnect again, the module works again without issue. This module just loads an image from external google URL on each update schedule. So, if network is ok, image should be loaded and displayed. I suspect your router or proxy setting is interfering TLS connection between Google Server. but not sure.
                  Anyway, at this moment hard to find reason why yours are not working.
                  G 2 Replies Last reply
                  • G
                    gonzonia @Guest
                    @Sean I appreciate you trying. I’ll see if I can figure out more detail. It’s weird because it’ll work fine sometimes for days and then all of a sudden I can’t get it to do more than 1 or 2 photos before it stops. Nothing else on the pi has that issue, newsfeeds still update, weather updates, CalendarExt2 updates.
                    I’m going to circumvent the pihole I have set up and point to GoogleDNS and see if that helps.
                    I wasn’t seeing anything from the MagicMirror in the query logs for the pihole which was in itself odd.
                      bhepler Module Developer @sdetweil
                      @sdetweil - I was replying to the warning about the buffer package being deprecated.
                        sdetweil @bhepler
                        @bhepler ah. never mind!
                        • G
                          gonzonia @Guest
                          @Sean I’ve got a theory. I don’t know enough about how it’s all working to be sure, but I’m testing it a little. I noticed in the logs that the error seemed to coincide with something the CalendarExt2 module was doing. Since they’re both connecting to Google, I thought, perhaps there’s something happening there. I’ve disabled the CalendarExt2 module and haven’t had a problem. I’m going to see how it all runs for today and then turn the module back on to see if the problem returns.
                            A Former User @gonzonia
                            @gonzonia
                            It makes some sense. By racing to use the same connection, there could be some conflicts. Hmmmm…
                            • G
                              gonzonia @Guest
                              @Sean Sadly, it doesn’t look like that’s it. Everything ran great for 12 hours, than quit again. Restarted this morning and it lasted an hour or two. The problem always appears arround indexing.
                              [2020-04-30 08:56:17.785] [LOG]    2020-04-30T08:56:17 <log> [GPHOTOS] Start Album scanning (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:44 Class.log)
                              [2020-04-30 08:56:17.789] [LOG]    2020-04-30T08:56:17 <log> [GPHOTOS:AUTH] Token is alive. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:20 Auth.log)
                              [2020-04-30 08:56:17.791] [LOG]    2020-04-30T08:56:17 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                              REPEATS....
                              [2020-04-30 08:56:55.332] [LOG]    2020-04-30T08:56:55 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                              [2020-04-30 08:57:17.685] [LOG]    2020-04-30T08:57:17 <log> [GPHOTOS:CORE] Error: Client network socket disconnected before secure TLS connection was established (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                              [2020-04-30 08:57:18.712] [LOG]    2020-04-30T08:57:18 <log> [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/XXXXXX (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:44 Class.log)
                              [2020-04-30 08:59:18.130] [LOG]    2020-04-30T08:59:18 <log> [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/XXXXXXXX(/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:44 Class.log)
                              I’m determined to figure this out though.
                                sdetweil @gonzonia
                                @gonzonia
                                correct, the code then fails, the module sends the helper a message
                                      case 'IMAGE_LOAD_FAIL':
                                        this.log("Image loading fails. Check your network.:", payload)
                                        break
                                and the helper logs it, but never does anything after that
                                so, now the module is waiting for another image,
                                      case 'UPLOAD':
                                        this.upload(payload)
                                        break
                                but the helper doesn’t know
                                  A Former User @sdetweil
                                  Nothing can be dine after image loading fails. Even connected again, couldn’t be recognized. It is just kind logging.
                                  I’m not sure what could be possible to do for this kind of network issue by module itself.
                                  • RoggerFabriR
                                    RoggerFabri
                                    Hi @Sean , thanks a lot for your time and effort on creating this module, I was searching for something similar for a long time already. From time to time, I’m getting several Forbidden 403 responses from the requests to load new pictures, this gives the impression that the pictures are stuck. Do you have an idea of what might be causing that?
                                    ? B 2 Replies Last reply
                                      A Former User @RoggerFabri
                                      @RoggerFabri
                                      All those kinds of errors (403, 500, …) means network/server errors. Nothing could do in client(module) itself. Only thing would be just waiting(stuck) problem solved by network/server.
                                        bhepler Module Developer @RoggerFabri
                                        @RoggerFabri - I don’t know if this is relevant, but I know Amazon AWS bulk storage returns 403 errors if you get the URL wrong. I’m not sure if their security model is so granular that files have to be authorized independently or if the wrong URL attempts to serve up the directory index and that file is locked out. And I have no idea if Google uses the same technique.
                                        Either way, I would check the request to make sure it is pointing to a valid asset.
                                        • G
                                          gonzonia @Guest
                                          @Sean 403 is a “forbidden” status. Is it possible to catch that status being returned and then go back to refreshing the token and starting the process over from there?
                                            @gonzonia
                                            There could be possibility “dead url after it’s lifetime”(60 minutes) but to avoid it, photos working urls would be rescanned and refreshed per 50mins.
                                            Of course, if there be network error to prevent resurrection, it will not work. That is not the token issue.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
