    Monitor Overheated
    9 Posts 6 Posters 7.2k Views 5 Watching
      bibi @RHeniz
      @RHeniz hi! did you find any reliable “advanced” solution regarding this heat issue? like turn on the fan(s) as soon as the temp in the box reaches a certain level? i am a bit surprised that nobody talks about this topic… i am still building my mirror so didn’t faced the problem yet but i would have think that a source of heat (monitor/rasp) in a closed box would somehow produce heat and therefore evacuation of the heat would be needed (more then some holes…) If anybody would like to share their opinion, please feel freev:)
        RHeniz @bibi
        @bibi I haven’t replaced mine yet but I might try to find a way to turn the monitor off and on with a time or remote so it’s not always on.
          bibi @RHeniz
          @RHeniz ok let me know what you would find. i share my idea which is to use the usb port on my monitor to plug in 1 or 2 modified PC fans… i guess with a PIR sensor installed as well, the rasp will switch on/off the monitor when needed and therefore power monitor usb ports accordingly (i am not sure that’s gona work :)) Other opinion i have thought about is to plug into the gpio’s the fan and control the temp via a sensor, write the code to activate the fans accordingly to the temp value setup in the code… much more “complicated” way for a newbie as me but interesting one! (would be nice to get help on this from someone ;-))
          • K Offline
            Kathy120
            You can follow the following steps to prevent monitor overheating.
            1. Clean the inside of the computer to get rid of dust particles which may heat up the monitor.
            2. Avoid hot devices near your computer .
            3. In case of overheating, shut down your computer and let it cool down.
            • cowboysdudeC Offline
              Make sure you have top vent holes… heat rises… let it!
              The other thing you could do is to use modules like MMM-ModuleScheduler to turn off modules and/or mirror when you don’t need it on like all day when you’re at work/school…
              That’s what I do and have had no issues… :)
