    Third party modules causing blank screen
    9 Posts 4 Posters 5.8k Views 3 Watching
      PtrBld Module Developer
      Could you share your not working config and the error log with us?
        aubcar
        0_1463506896422_config.js
          aubcar @PtrBld
          @PtrBld I attached my config file, I’m not getting any errors, just a blank screen.
            Ok then try starting your mirror in server mode (‘node serveronly’ from your Mirror directory), goto your raspi´s ipaddr on port 8080 and check your browser console.
            • paviroP Offline
              paviro @aubcar
              @aubcar check your formating! You probably did something wrong adding the modules. You can check by using a javascript validator (Google it :))
              – The Doctor
                aubcar @paviro
                @paviro Seems to be formatted ok, only yells at me to use spaces not tabs haha. Might try a fresh install of rasbian+MM incase I messed something up along the way.
                paviroP 1 Reply Last reply Reply Quote 0
                • paviroP Offline
                  paviro @aubcar
                  @aubcar did you check your web inspector?
                  – The Doctor
                    sameershah23
                    I faced the issue when I was working under MagicMirror folder and then installing the 3rd party modules.
                    I corrected it by going into /MagicMirror/Modules folder and then installing the module using the git command.
                    Hope this helps
