    Third party modules causing blank screen
    9 Posts 4 Posters 6.4k Views 3 Watching
      aubcar
      Hey guys, quick question
      Has anyone had a problem editing their config.js files for the third party modules? I had my mirror working great with the default modules but wanted to add airquality and traffic. I downloaded the modules just fine but when I edit my config file to include them it boots up as a blank screen, removal of the few lines of code for the respective modules and it goes back to normal working order. Thanks for the help!
      paviroP 1 Reply Last reply Reply Quote 0
        PtrBld Module Developer
        Could you share your not working config and the error log with us?
          aubcar
          0_1463506896422_config.js
            aubcar @PtrBld
            @PtrBld I attached my config file, I’m not getting any errors, just a blank screen.
              Ok then try starting your mirror in server mode (‘node serveronly’ from your Mirror directory), goto your raspi´s ipaddr on port 8080 and check your browser console.
              • paviroP Offline
                paviro @aubcar
                @aubcar check your formating! You probably did something wrong adding the modules. You can check by using a javascript validator (Google it :))
                – The Doctor
                  aubcar @paviro
                  @paviro Seems to be formatted ok, only yells at me to use spaces not tabs haha. Might try a fresh install of rasbian+MM incase I messed something up along the way.
                  • paviroP Offline
                    paviro @aubcar
                    @aubcar did you check your web inspector?
                    – The Doctor
                      sameershah23
                      I faced the issue when I was working under MagicMirror folder and then installing the 3rd party modules.
                      I corrected it by going into /MagicMirror/Modules folder and then installing the module using the git command.
                      Hope this helps
