Show two weather and forecast modules on the same screen
9 Posts 4 Posters 5.7k Views 5 Watching
  • F Offline
    frog
    As I want to see two different locations, I tried to run the currentWeather and weatherForecast modules twice in the config.js, but I don’t get the second one. I guess I’m not doing it right.
    Can anyone give me advice on how to do this?
    Regards
    B 1 Reply Last reply Nov 5, 2016, 1:49 AM Reply Quote 0
      bhepler Module Developer @frog
      @frog I just whipped one up and it wasn’t a problem. A couple things to check:
      • Make sure that you’re configuring the entire module twice.
      • Make sure that you put each instance of the module in a different location (top_left, bottom_left, etc.)
        Here’s an example with the calendar module:
            module: 'calendar',
            header: 'US Holidays',
            fetchInterval: 3600000,
            position: 'top_left',
                  fade: false,
                  calendars: [ {
                        symbol: 'calendar-check-o ',
                        url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics',
            module: 'calendar',
            header: 'Movie Releases',
            position: 'bottom_left',
                  fade: false,
                  calendars: [ {
                        symbol: 'imdb',
                        url: 'https://www.google.com/calendar/ical/pfutdblf1gi8jmfsvroh76f6jg%40group.calendar.google.com/public/basic.ics'
      • F Offline
        frog
        I tried just duplicating the module in config.js, but it didn’t work. Maybe it’s different for the weather modules. I’ll try again.
        B 1 Reply Last reply Nov 5, 2016, 1:57 AM Reply Quote 0
          @frog Don’t forget to put each copy of the module in a different location!
          F 1 Reply Last reply Nov 5, 2016, 12:17 PM Reply Quote 0
          • F Offline
            frog @bhepler
            @bhepler My bad, just re-entered the info in config.js and it works! thanks.
              A Former User
              What’s the movie module?
              F 1 Reply Last reply Nov 17, 2016, 3:40 PM Reply Quote 0
              • F Offline
                frog @Guest
                @wjdw87 it’s not a module, it’s a calendar. Address is in the config above
                  A Former User
                  Much obliged, the wife sends a e-kiss (she is the movie hound).
                  Thanks!
                    canadrian
                    I see a rectangle character in front of the movie title, what can be? Thank you.
