    Newbie - Build Smart Mirror
    14 Posts 7 Posters 8.4k Views 7 Watching
    • X
      xxLulaBelle
      I am a complete newbie to Raspberry Pi and Magic Mirror. I have decided to build a Smart Mirror and just lookingi for any tips or advice on what to do or not to do. I have ordered the Raspberry Pi 4 Starter Kit. Is touch screen better or not for this? Any advice is much appreciated :)
      Thanks, Lula
      • BKeyportB
        BKeyport Module Developer
        This is the fun part of the process. Figuring out what’s best to do for YOU.
        I Would:
        • Get a fan “hat” for your Pi.
        • Use heat sinks
        • If you use the HDMI outputs, use the one closest to the power plug.
        • Know your power supply is proper for the unit. (Bad power = bad experience).
        • Install using @sdetweil scripts. (See: https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods)
        I Wouldn’t:
        • Follow any old guides regarding magic mirror or follow guides not on the magicmirror.builders website - They may have bad information.
        • forget to specify your OS version when searching for help (major system breaking changes happen between releases, so always search for things like this “Static IP address using buster”)
        • ask questions before searching for an answer (We’ve been through it all).
        • be afraid to ask questions here - no question is stupid, just some are already answered.
        – Good luck, may your project be successful.
        Reply Quote 2
        • X
          xxLulaBelle
          Thank you so much for all that advice, I really appreciate it :)
            bhepler Module Developer
            More advice for you:
            • Whatever monitor you purchase/acquire, be sure the HDMI ports face down.
            • Use @sdetweil’s installation scripts when it comes to installing the Magic Mirror framework. (we’re both recommending this. That should be a hint)
            • No shame in doing the software part long before building the mirror part. If you’ve never run a table saw, this is a good way to get an early success in.
            • Mirror glass is better than mirror acrylic is better than mirror film on glass. With an accompanying difference in price. But it all works. Don’t get too hung up on the hardware aspect.
            • Do not power your Pi off of the monitor’s USB ports.
            FoziF 1 Reply Last reply
            Reply Quote 2
              pandeyprakhar00
              I made these tutorials for giving a head start, starting from scratch !
              https://www.youtube.com/playlist?list=PLBy3Sw0lBrNeihCn0fOr-m5RYJNb4w4IS
              It used @sdetweil installation scripts !
              Introduction to Raspberry pi : https://youtu.be/wqKCPbu7V7Y
              Setting up MM Hardware : https://youtu.be/BZ_JVD9ReMk
              Installing MM & introduction to MM - Modules : https://youtu.be/PHpth_KQHcE
              Configuring Calendar & Weather Modules : https://youtu.be/ce6O2aGB9tY
              Hope it helps !
              D 1 Reply Last reply
              • BKeyportB
                I forgot one:
                Don’t freak out about the “Mirror” in the name. It don’t have to be a mirror. Much creativity is coming from not even bothering to do a mirror - My setup, for instance, is filling a former passthrough in my office… It’ll be a monitor covered with clear material, then wrapped with a face wood and framed to look decent.
                • FoziF
                  Fozi Project Sponsor @bhepler
                  @bhepler the First 5 commandments…couldn‘t have phrased them better😃🤙🏻
                    djdocta @pandeyprakhar00
                    @pandeyprakhar00 said in Newbie - Build Smart Mirror:
                    Hope it helps !
                    Please note that your API key is visible in below video :
                    https://www.youtube.com/watch?v=ce6O2aGB9tY&list=PLBy3Sw0lBrNeihCn0fOr-m5RYJNb4w4IS&index=5&t=0s
                    It shouldn’t be a big deal but as you tried to hide it, you may reconsider a re-upload of the video :-)
                    P 1 Reply Last reply
                      pandeyprakhar00 @djdocta
                      @djdocta Damm ! It always happens with me… i think i should stop hiding the API’s & Passwords :-P
                      • X
                        xxLulaBelle
                        Thank you all very much for the advice and tips, I have learned some new things already. One last question I hope, regarding the monitor, I read somewhere about using a touch screen monitor, is it better to use touch screen or no?
                        D S B FoziF 4 Replies Last reply
                          djdocta @xxLulaBelle
                          @xxLulaBelle If you need a two way mirror, PM me, I have one to sell. :-)
                            sdetweil @xxLulaBelle
                            @xxLulaBelle none of my mirrors have any function requiring/or leveraging touch directly
                              bhepler Module Developer @xxLulaBelle
                              @xxLulaBelle - None of my mirrors have touch capability. Personally, I don’t understand why people want it. It will collect fingerprints and smears. But several people have built it and they seem happy with it.
                              A touchscreen monitor will work if you’re not building a mirror but instead are building a display with the framework. The reason is that the glass/acrylic that provides the mirror finish will interfere with the touch signals. In order to get touch capability, you’ll want a touch overlay that you can place on top of the mirror (with a regular monitor behind it).
                              • FoziF
                                Fozi Project Sponsor @xxLulaBelle
                                @xxLulaBelle alternatively you could use a gesture sensor and run it with the MMM-GroveGestures module. I have one to swipe pages and to start/stop a news podcast with MMM-Podcast2. Works great!
