    Creating Custom Voice Commands for Hello-Lucy...?
    30 Posts 4 Posters 9.0k Views 4 Watching
      sdetweil @Doctor0ctoroc
      @Doctor0ctoroc the tool uses a compiler of sorts to build the dictionary and language model
      this is an unlimited vocabulary voice reco engine.
      you can make is a limited vocabulary type by changing the dictionary
      see the lmtool info
      http://www.speech.cs.cmu.edu/tools/FAQ.html
      Doctor0ctorocD 1 Reply Last reply Reply Quote 0
      • Doctor0ctorocD Offline
        Doctor0ctoroc @sdetweil
        @sdetweil Okay cool - so it does seem like the tool generates pronunciations (strings of phonetic symbols) based on a dictionary of actual words but can also create pronunciations for new words (like proper names, eg Jarvis) so long as they are not too complicated (or over 35 characters) - however, it seems that it is less reliable to create pronunciations based on uncommon words than it is to create pronunciations for existing words. And the tool is also used to create complete sets of words to be referenced locally, if I’m not mistaken. This would mean that I can theoretically create a text file including all of the new words I want to add and upload it to both the lmtool and lextool, then I would add the output content to the .lm and .dic files included with Hello-Lucy. I think…
        I may just create copies of all the related files in Hello-Lucy and do some experimenting with the option to revert back to the copied files.
          @Doctor0ctoroc yep, you got it
            @sdetweil said in Creating Custom Voice Commands for Hello-Lucy...?:
            Yes! So now that I got a handle on that, I need to figure out how the .js and .json files utilize the local sphinx library.
            @Mykle1 - can you lend a hand here? From the looks of it, I believe that the words.json and sentences.json files contain a reference list of all of the words and phrases used in the checkCommands.json file, and they’re referenced by the node_helper.js and Hello-Lucy.js files to implement the hide/show commands, yes? Something like that? A basic hierarchy should suffice to point me int he right direction.
              @Doctor0ctoroc its builds the library from the sentences and words files…
              then calls lmtool to generate the lm & dic files
                @sdetweil So are the .lm and .dic files generated in real time? Like, does whatever is added to the words.json and sentences.json files propagate into the .lm and .dic files or are you saying that both the words and sentences files are the basis for generating the .lm and .dic files through the sphinx tool?
                  @Doctor0ctoroc on module startup
                    @Doctor0ctoroc module sends a message to node_helper “START”
                    and then u can read the code in node_helper
                      @sdetweil Ah, that’s fantastic. That would explain why when I changed “Hello Lucy” to “Hey Jarvis” in the Hello-Lucy.js and config file, it was added to the .dic and .lm file…I thought it was included in there from the get go (assuming the code was written to include an alternative, ‘familiar’ AI name that users might want) but all this time, it was my change of the code that put it in there - and it totally works when I say “Hey Jarvis” instead of “Hello Lucy”!
                      So there’s no need to even edit the .lm or .dic files directly then?
                      S Mykle1M 3 Replies Last reply Reply Quote 0
                        @Doctor0ctoroc no, they are generated each time the module starts
