    MMM-Spotify
    249 Posts 51 Posters 330.6k Views 54 Watching
      mmmmh Project Sponsor @Guest
      @Sean I hacked together a simple bash script (dnssaver.sh) that fetches IPs and stores them in the hosts file. If I call it with ‘api.spotify.com’ as argument and put it in my crontab it should take a load of the dns server. I’ll keep an eye on it.
      • Cr4z33C Offline
        Cr4z33
        @Bugsounet either I am doing something wrong or there’s a bug.
        I added onStart: null, in the module config, but the big Spotify logo keeps displaying all the time.
          [[global:former-user]]
          if Soptify logo not hidden after start, it’s means :
          token missing or token error
          you should have in console something like that :
          [SPOTIFY:ERROR] USERNAME: [your username]
          [SPOTIFY:ERROR] Token Error ! ./[token name].json
          if you have set a token … verify the exact name
          and report it to your account username specified in spotify.config.json -> “TOKEN” field
            when ok It display :
            • default style
            • mini style
            • when bottom_bar position is set
              @mmmmh :
              now idleInterval is set to 30000 (scan is Spotify is playing every 30 sec)
              if playing : updateInterval is set by default to 1000 (1sec)
              Attention it’s means that with idleInterval : when Spotify is playing to take 30 sec to display it in mirror !by default !
                @Bugsounet Thanks. Do I understand this correctly. As long as the module is idle it will only check for updates every 30 seconds and when it is active (music is being played) it updates every second?
                  Right,
                  I hope this suits you, because it starts to take head ;)
                    sbonn13
                    Somehow the authorization process does not work.
                    ...node first auth.js
                    [SPOTIFY] Initialized
                    Browser opened and the log in was succesful as well as accepting the app, but then instead of creating the token.js I receive an error:
                    [SPOTIFY] Error in authentication flow!
                    [SPOTIFY] ERROR: undefined
                    [SPOTIFY] Authorization process finished!
                    In spotify I can see that I have the mirror app available in approved apps, but there is not token in the modules folder. Therefore the connection does not work.
                    Does anybody have an idea?
                      sdetweil @sbonn13
                      @sbonn13 there will be a message popup on the browser with a code (press the copy icon)
                      then return to the terminal window and paste the code in at the little app prompt, and hit enter
                      (make sure u don’t hit enter on that window before the browser opens, as the little app will take you enter key as the ‘token’ and not wait)
                      you run the node auth… app
                      and see
                      Opening OAuth URL. Return here with your code.
                      Paste your code:
                      then the browser opens, you pick your userid, then it asks for allow, then presents this screen
                      where u need to copy that and then return to app
                        sbonn13 @sdetweil
                        Thanks unfortunately probably I do it completely wrong, I do not get it. Is there any instruction? OAuth was working fine for google services, but not with this Spotify solution :-(
                        My procedure:
                        1.) node first_auth.js as described in MMM-Spotify instruction.
                        -> [SPOTIFY] Initialized appeared in terminal window
                        2.) Browser opens with Spotify login, after having entered, spotify requesting access
                        -> No code yet, no additional terminal window, also no change in existing terminal window
                        3.) Click on accept access in browser (spotify)
                        -> callback localhost:8888 appeared in domain and shows ?code=**** in parameter.
                        But in the meantime the mentioned error has appeared immediately in the terminal window. No time or place to paste the code somewhere else. Where shall I put this code and at what point in the procedure?
                          sdetweil @sbonn13
                          @sbonn13 said in MMM-Spotify:
                          what does ‘appeared in domain’ mean?? sorry
                            sbonn13 @sdetweil
                            Following address is opened in browser: https://accounts.spotify.com/de/authorize?response_type=code&client_id=XXXXX&scope=user…
                            -> Press Agree button in Browser in order to agree access to spotify
                            Afterwards address in browser is changed to:
                            http://localhost:8888/callback?code=XXXXX&state=XXXXX…
                            I assume the code (anonymized XXXXX) in this address is the relevant one. But how to proceed with that? Because at the time I have received this code I already have the errors in my terminal window.
                              sdetweil @sbonn13
                              @sbonn13 i do not know … @Bugsounet will have to help here
                                I’m going to inspect the first_auth script. there is too much problem, I think.
                                a little patience within a few days this should be fixed
                                  ChanceTime
                                  hi @Bugsounet ! I’m working on my first smart mirror and was very happy to just get mmm-GoogleAssistant up and running! It’s able to do normal searches and that kind of thing, so I just tried to install MMM-Spotify.
                                  Unfortunately, MMM-GoogleAssistant doesn’t seem to be recognizing the commands, and I don’t see any changes on the screen when I try to use the commands for it (for example, “Michael Jackson on Spotify”).
                                  The code I used in the .config is below. Did I miss something?
                                  Thanks!!
                                  		  module: "MMM-GoogleAssistant",
                                  		  position: "fullscreen_above",
                                  		    debug: false,
                                  		    assistantConfig: {
                                  		      lang: "en-US",
                                  		      projectId: "magic-mirror-79d8d", // Required to use gaction.
                                  		      modelId: "", // (OPTIONAL for gaction)
                                  		      instanceId: "", // (OPTIONAL for gaction)
                                  		      latitude: 45.255299,
                                  		      longitude: -75.729048,
                                  		    responseConfig: {
                                  		      useScreenOutput: true,
                                  		      screenOutputCSS: "screen_output.css",
                                  		      screenOutputTimer: 5000,
                                  		      activateDelay: 250,
                                  		      useAudioOutput: true,
                                  		      useChime: true,
                                  		      newChime: false
                                  		    micConfig: { // put there configuration generated by auto-installer
                                  		      recorder: "arecord",
                                  		      device: "plughw:2",
                                  		    customActionConfig: {
                                  		      autoMakeAction: false,
                                  		      autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                                  		      actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                                  		    snowboy: {
                                  		      audioGain: 2.0,
                                  		      Frontend: true,
                                  		      Model: "jarvis",
                                  		      Sensitivity: null
                                  		    A2DServer: {
                                  		      useA2D: false,
                                  		      stopCommand: "stop"
                                  		    recipes: [ "with-MMM-TelegramBot.js", "with-MMM-Spotify" ]
                                  			module: "MMM-Spotify",
                                  			position: "bottom_left",
                                  				 style: "mini", // "default" or "mini" available
                                  				 control: "hidden", //"default", "hidden" available
                                  				 updateInterval: 1000,
                                  				 onStart: null, // disable onStart feature with `null`
                                  				 allowDevices: [], //If you want to limit devices to display info, use this.
                                  				 // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                                    natively, MMM-Spotify and MMM-GoogleAssistant can’t read directly music on Spotify.
                                    MMM-Spotify can display only what you are listening on a device
                                    and you can change music ONLY with a premium account with vocal request
                                    if you want listening music on your mirror you have to install Raspotify or librespot on your mirror (but needed again a premium spotify account)
                                    After, A2D is coded to read +/- native google response without Spotify recipe
                                      ChanceTime
                                      aaaah, okay, thanks so much!
                                        socosurf
                                        Does anyone know how I can adjust this module so that the album art is to the left and all the info is to the right of the album art? I basically am running this solo in magic mirror with a dedicated display to show what song is playing in my apartment but right now the album art and text doesn’t utilize all the real-estate of the screen since it’s centered and stacked.
                                        Can this be altered to have the album art to the left and all the text stacked to the right?
                                          dcimag
                                          Hi. I was wondering if someone could tell me what I need to edit in the MMM-Spotify module to make Spotify fully function and what I have to do to have it appear on my screen. I have all the details of the MMM-Spotify folder listed under my Music folder on my raspberry pi 4. I dont need to type out the coding. Again just asking what I need to edit of the coding. Already have all the code. Other than all the coding that is in the MMM-Spotify.js document. What do I need to puth for AUTH_DOMAIN: AUTH_PATH: AUTH PORT: SCOPE: and TOKEN.
                                            I really don’t understand, what do you want to do with this modules…
                                            MMM-Spotify works
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
