    SSH Tutorial
    15 Posts 6 Posters 8.7k Views 6 Watching
      blacter
      Is there a tutorial somewhere that explains how to set up SSH so I can control/modify my MM from my Mac? Thanks.
      S lavolp3L 3 Replies Last reply Reply Quote 0
        sdetweil @blacter
        @blacter open the preferences/Raspberry PI configuration/interfaces tab on the pi top. left menu.
        check the ssh box,
        save and extra and restart your pi
          blacter
          Thanks. I now can see the MM on my terminal. From there, how do I modify the config.js file?
          • lavolp3L
            lavolp3 Module Developer @blacter
            @blacter @sdetweil FYI: you can auto-enable ssh on a raspberry pi when setting it up by putting a blank file with the name “ssh” (no extension) into the boot partition.
            When you start the pi, it will find and remove the file and enable ssh.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              sdetweil @blacter
              @blacter
              also, you are supposed to be able to have a ‘disk view’ over the remote ssh disk with
              https://osxfuse.github.io/
              I can’t get it to work on catalina 15.5 at the moment
                sdetweil @lavolp3
                @lavolp3 yeh, tricky crap… just click the buttons (unless u are making 100 of these disks)
                • lavolp3L
                  @sdetweil said in SSH Tutorial:
                  it is the best way to run a pi headlessly. I never use the GUI.
                    sdetweil @lavolp3
                    @lavolp3 i don’t use the gui either after initial setup…
                    but u can’t run headless AND have MM on it… (unless in serveronly mode)
                    use ssh ans sftp file system over…
                    winscp and bitvise clients…
                    • lavolp3L
                      yeah you got me it’s not really headless.
                      I set up the pi on my laptop, start it and install the mirror via ssh already. So I don’t have to attach a keyboard to the pi.
                        sdetweil @lavolp3
                        @lavolp3 absolutely!.. I only use the actual pi keyboard/mouse when absolutely neccessary… got one of the little combo keyboard/mouse things. but still a pain
                          blacter
                          Okay, I’m connected to the MagicMirror on my Mac’s terminal. Is there a way I can now open the config.js file in a text editor on my Mac?
                            sdetweil @blacter
                            @blacter if u install those other components then you open a sshfs session to have a file browser over the pi disk, then yes,
                            short of that u have to use the editor ON the pi… text mode
                              sojourner
                              @blacter If you have interest/time … the VS Code editor runs on macOS and has a nice ‘remote ssh’ functionality to edit files remotely. While it has a lot of “programmer” functions, it’s not a bad editor to help anyone. (And this, from a guy who prefers a command line.)
                                RoddyJoff @sojourner
                                @sojourner Thanks for suggesting this, I am now using it and it makes remote code editing a breeze.
                                For those wishing to use it, after installing VS Code read this article to enable remote editing.
                                [https://petri.com/how-to-edit-linux-files-remotely-in-windows-using-visual-studio-code](link url)
                                Thanks again.
                                • BKeyportB
                                  BKeyport Module Developer
                                  There’s also lots of other ways to get remote access to the Pi so you can edit with normal editors and save there.
                                  SAMBA (easy, IMO), or other tools to create a share… Just search and ye shall find.
