    SSH Tutorial
    15 Posts 6 Posters 7.4k Views 6 Watching
      blacter
      Thanks. I now can see the MM on my terminal. From there, how do I modify the config.js file?
      • lavolp3L Offline
        lavolp3 Module Developer @blacter
        @blacter @sdetweil FYI: you can auto-enable ssh on a raspberry pi when setting it up by putting a blank file with the name “ssh” (no extension) into the boot partition.
        When you start the pi, it will find and remove the file and enable ssh.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @blacter
          @blacter
          also, you are supposed to be able to have a ‘disk view’ over the remote ssh disk with
          https://osxfuse.github.io/
          I can’t get it to work on catalina 15.5 at the moment
            sdetweil @lavolp3
            @lavolp3 yeh, tricky crap… just click the buttons (unless u are making 100 of these disks)
            • lavolp3L Offline
              @sdetweil said in SSH Tutorial:
              it is the best way to run a pi headlessly. I never use the GUI.
                sdetweil @lavolp3
                @lavolp3 i don’t use the gui either after initial setup…
                but u can’t run headless AND have MM on it… (unless in serveronly mode)
                use ssh ans sftp file system over…
                winscp and bitvise clients…
                • lavolp3L Offline
                  yeah you got me it’s not really headless.
                  I set up the pi on my laptop, start it and install the mirror via ssh already. So I don’t have to attach a keyboard to the pi.
                    sdetweil @lavolp3
                    @lavolp3 absolutely!.. I only use the actual pi keyboard/mouse when absolutely neccessary… got one of the little combo keyboard/mouse things. but still a pain
                      blacter
                      Okay, I’m connected to the MagicMirror on my Mac’s terminal. Is there a way I can now open the config.js file in a text editor on my Mac?
                        sdetweil @blacter
                        @blacter if u install those other components then you open a sshfs session to have a file browser over the pi disk, then yes,
                        short of that u have to use the editor ON the pi… text mode
