    Config for a simple clean montly calendar
    25 Posts 8 Posters 28.2k Views 9 Watching
      mlcampbe @Clubjack
      @Clubjack
      On the right-hand side I am using the modules all in the top-right region:
      default clock
      MMM-DarkSkyForecast
      default calendar
      MMM-SimpleLogo (used to display a static image that is my calendar color legend)
      The main calendar is using MMM-CalendarExt2 in the top-left region with 7 different google/icloud calendar URLs defined in the “calendars” section of the module. The rest of the MMM-CalendarExt2 config in the config.js is for the view/scene and I am using this:
      views: [
                  mode: "week",
                  slotCount: "7",
                  maxItems: "1000",
                  hideOverflow: false,
                  slotMaxHeight: "95px",
                  monthFormat: "MMMM YYYY",
                  calendars: []
              scenes: [
      All of the formatting is done within the custom.css file which is heavily customized like this:
      body {
              background-size: cover;
              margin: 20px;
              height: calc(100% - 40px);
              width: calc(100% - 40px);
      .xsmall {
              font-size: 17px;
      .region.top.right {
              width: 23%;
      .region.top.left {
              width: 77%;
      .calendar .time {
              padding-left: 20px;
              color: #FFF;
              font-weight: normal;
      .MMM-DarkSkyForecast .module-content {
              width: unset;
      .CX2 {
              --font-size: 14px;
      .CX2 .event {
              padding: 0px;
      .CX2 .weekSlot .timelineSleeve {
              height: calc(var(--font-size) + 5px);
      .CX2 .weeksmark {
              display:none;
      .CX2 .event.passed::before {
              background: none;
      .CX2 .cellSlot.weekday_6 .slotSubTitle {
              color: #F66;
      .CX2 .cellSlot.weekday_7 .slotSubTitle {
              color: #F66;
      .CX2 .cellSlot .slotTitle, .CX2 .cellSlot .slotSubTitle, .CX2 .cellSlot .slotAltTitle {
              font-size: 20px;
              color: #FFF;
      .CX2 .today .slotHeader {
              background: rgba(64,64,64,0.8);
              color: #000;
      .CX2 .today .slotHeader .slotTitle {
              color: #FFF;
      .CX2 .today .slotContent {
              background: #eeeeee69;
              #border: 1px solid white;
      .CX2 .me, .me.event.fullday {
              border-radius: 5px;
              background-color: #83CCD5;
              color: #000;
      .CX2 .wife, .wife.event.fullday {
              border-radius: 5px;
              background-color: #EB738B;
              color: #000;
      .CX2 .social, .social.event.fullday {
              border-radius: 5px;
              background-color: #D59C73;
              color: #000;
      .CX2 .piano, .piano.event.fullday {
              border-radius: 5px;
              background-color: #B4CC5A;
              color: #000;
      .CX2 .birthday, .birthday.event.fullday {
              border-radius: 5px;
              background-color: #F0E68C;
              color: #000;
      .CX2 .college, .college.event.fullday {
              border-radius: 5px;
              background-color: #A473AC;
              color: #000;
      .CX2 .holiday, .holiday.event.fullday {
              border-radius: 5px;
              background-color: #7B9CCC;
              color: #000;
      .CX2 .slot > .slotContent {
              background-image: none;
      .CX2 .monthViewTitle {
              text-align: left;
      .CX2 .eventTitle {
      C C 3 Replies Last reply
      Reply Quote 3
        Clubjack @mlcampbe
        @mlcampbe
        Thank You for that.
        I never worked with custom.css before.
        Is there an tutorial for custom.css, to understand all whats inside?
        S M 3 Replies Last reply
          sdetweil @Clubjack
          @Clubjack said in Config for a simple clean montly calendar:
          nothing inside, until you add it…
          it overrides (or adds to) the main.css so you can customize the styles of elements
          never modify the main.css
            mlcampbe @Clubjack
            @Clubjack
            In my case it was mostly trial and error. I am not a css guru by any stretch of the imagination. You might want to take a look at https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works which has some tips.
            Reply Quote 2
              cyberphox @mlcampbe
              @mlcampbe What is the size of your logo you are using? Can I see that part of your config as well maybe? Thanks!
                mlcampbe
                By logo do you mean the legend that is below the calendar event details on the right-hand side of the screen? If so then that is using the MMM-SimpleLogo module with the below config and an image that is 294x135 pixels.
                  module: "MMM-SimpleLogo",
                  disabled: false,
                    position: "right",
                    text: "",
                    width: "250px"
                Note that the width: 250px is used so that it will be centered within the right-hand “column”.
                C 1 Reply Last reply
                  cyberphox @mlcampbe
                  @mlcampbe that’s exactly the info i was looking for! thanks!
                    sdetweil @Clubjack
                    @Clubjack style sheets cascade. newer can replace/override prior classes and styles…
                    so MM does this
                    main.css (1st)
                    modules adding their own style sheets (thru the getStyles() method response if used)
                    custom.css (last)
                    so, anything that happened BEFORE custom.css is loaded can be changed with entries in custom.css
                    custom.css is empty by default
                      Plainbroke 0 @mlcampbe
                      @mlcampbe
                      I know this is an old post, but I need some help setting up a full screen calendar.
                      Can you send me your config.Js and custom.css or however you made that calendar you show above. I have been waiting for someone to come up with that exact calendar…
                      Did you use the default calendar or something else…? I could combine my 3 different calendars into one… Saving realestate.
                      Jeff Burdick aka Plainbroke
                      M 1 Reply Last reply
                        mlcampbe @Plainbroke 0
                        @Plainbroke-0
                        Take a look at https://forum.magicmirror.builders/topic/11001/config-for-a-simple-clean-montly-calendar/8 as it has the css and necessary config needed.
                        • Piranha1605P
                          Piranha1605
                          Here is a sample for you.
                           * module.width_height
                           .module.MMM-CalendarExt2 {
                            height: 600px;
                           * module.color_border_shadow
                            background-color:#2a313b;
                            border-radius:8px;
                            padding:8px;
                            box-shadow: 0 4px 8px 0 rgba(0, 0, 0, 1), 0 8px 20px 0 rgba(0, 0, 0, 0.19);
                           * MMM-CalendarExt2.
                          .CX2 .slot .event{
                          	background: #1f242c;
                          .CX2 .agenda .eventSub {
                          	display:none;
                          .CX2 .slot .slotHeader{
                            border: 1px solid black;
                            color: white;
                          .CX2 .today .slotHeader * {
                          	color: white;
                           .CX2 .event.fullday {
                            border-radius:0px;
                          .CX2 .event[data-calendar-name="Google"] {
                            color: white;
                            min-height:80px;
                          .CX2 .event[data-calendar-name="Karate"] {
                            color: white;
                            min-height:80px;
                          .CX2 .event[data-calendar-name="Abfall"] {
                            color: white;
                            min-height:80px;
                          .CX2 .event[data-calendar-name="Arbeit"] {
                            color: white;
                            min-height:80px;
                          .CX2 .event[data-calendar-name="Feiertage"] {
                            color: white;
                            min-height:80px;
                           * Iconsize.
                          .CX2 .event .eventIcon {
                            min-width: calc(var(--font-size) * 2,5);
                            min-height: calc(var(--font-size) * 2,5);
                            margin-right:5px;
                            float:left;
                          .CX2 .period .eventIcon {
                            margin-right:5px;
                            float:left;
                          .CX2 .weekSlot .eventIcon {
                            min-width: var(--font-size);
                            min-height: var(--font-size);
                            margin-right:3px;
                            display:block;
                            padding-bottom:3px;
                          T 1 Reply Last reply
                          • Piranha1605P
                            Piranha1605
                            @Piranha1605 said in Config for a simple clean montly calendar:
                            .CX2 .event[data-calendar-name=“Google”]
                            Enter the name of your calendar here
                              Clubjack @mlcampbe
                              @mlcampbe
                              Hey. Last days i created my calendar with your helpfull custom.css.
                              Do You know the Code for changing the height of the Event-Bar?
                              I need it a little bit smaller.
                              Thank You.
                                mlcampbe @Clubjack
                                @Clubjack
                                I am not quite sure what you mean by the Event-Bar. Is that the height of a row or title size or what exactly are you talking about? I no longer use the calendar as my needs were only for about 1 years time but might be able to help if you can tell me exactly what part you need to modify.
                                  Clubjack @mlcampbe
                                  @mlcampbe
                                  Thank You. But i found it myself. 👍🏼
                                  But i have another queetion.
                                  I use the calendar in week-View.
                                  The Today-Header has an other Color. Thats good.
                                  But is it possible to change the background-Color of the Today Slot too?
                                  So it is easier to see the actual day.
                                    mlcampbe
                                    I believe one of these should probably work:
                                    color: #000;
                                    color: #FFF;
                                      Clubjack @mlcampbe
                                      @mlcampbe
                                      Thanks a lot.
                                      The last Code was the right. 👍🏼👍🏼👍🏼👍🏼
                                      • T
                                        TJSartain @Piranha1605
                                        @Piranha1605 Very nice. What does the config look like?
                                        • H
                                          HansDampf
                                          is there any suggestion fpr CalendarExt3?
                                          https://github.com/MMRIZE/MMM-CalendarExt3
