    Customized frames for MM
    6 Posts 5 Posters 1.5k Views 5 Watching
      sdetweil @adrian.k
      @adrian-k are there any wood working groups near you? that might make one for you? or metal working, or…
      A 1 Reply Last reply Reply Quote 1
      • bheplerB Offline
        bhepler Module Developer
        You may have luck checking with the local school shop class and/or technical college. People learning how to use the tools can easily make the frame for a monitor. I’m not familiar with Norway’s educational system, but someone has to make furniture and they have to learn somewhere. Find them.
          adrian.k @sdetweil
          @sdetweil said in Customized frames for MM:
          @bhepler said in Customized frames for MM:
          Thank for both of your suggestions! Local schools are closed until the end of summer atm, but if I cant find someone to help me out with it I might try there when they open.
          I checked out with a local company that could make one for me, but the best price that I got was 430 USD, and thats way to much imo.
          • karsten13K Offline
            karsten13
            I’m using a standard photo aluminium frame for my mirror. The monitor covers only the bottom half of the mirror. The problem is that this construction needs to be placed on a board or something else, the monitor inside the frame is to heavy for the frame.
            alt text
            • thgmirrorT Offline
              thgmirror
              another idea may be to look at a kitchen-store. Maybe they have a used kitchen-unit with a glas-window you can take as a front-frame. The frame behind is much easier to built because you need no miter. Just buy the wood for the back-frame in a hardware-store, ask them to cut it into pieces. Paint it as you like, should not be so expensive.
