    MM cant boot, wont boot!
    40 Posts 5 Posters 13.4k Views 5 Watching
    • N Offline
      nicoz
      Complete noob here so please word your responses for 10 year olds :-)
      Recently my MagicMirror has been booting to a black sceen. A literal black screen, and the only way to remove it is to minimize the window.
      I think the problem started when i tried to update the program. I have tried since to update and think i have succeeded however now it seems not not boot at all. Even manually via SSH
      My pi just boots to the standard UI.
      Any Ideas???
        sdetweil @nicoz
        @nicoz if u updated, (git pull) did u npm install after?
        also, sometimes existing modules need to have their stuff refreshed after the base refreshes
        (all leading to black screen)
        I have a script for future updates that figures this all out…
        in the short term, make sure you did
        npm install
        then check each module folder, and if there is an package.json file, also do the
        npm install
        for each such folder
        then restart mm
        • BKeyportB Offline
          BKeyport Module Developer
          One other thing you can do is run “npm run config:check” in the magicmirror root directory (~/MagicMirror) - it’ll run through and see if there’s anything that’s slightly out of wack to blank the mirror but not out of wack enough to throw an error. It’s saved me lots of headaches several times.
          • N Offline
            nicoz
            npm install seemed to work in that i dont get a black screen anymore.
            npm start will start the mirror but for some reason it wont stay open. i come back to the mirror and i am back at the Rasbian Home screen?
            i also tried config:check but i dont really know what im looking at
              sdetweil @nicoz
              @nicoz when u do npm start is shows messages to the screen…
              can you do
              npm start > somefile 2>&1
              and when it ends, look at somefile
                Cyric @BKeyport
                @BKeyport said in MM cant boot, wont boot!:
                I am having this same issue. I ran the update and everything was fine except my calendar and the 2 day weather thing, which looks like a known bug. I rebooted and am only getting a black screen with the mouse cursor. I did some digging and ran the npm install on the main magic mirror directory, and the directories for the modules i’m using, and it’s still not working. I tried to do the npm run config:check and it came back with an error saying " > magicmirror@2.11.0 config:check /home/pi/MagicMirror
                node tests/configs/check_config.js
                internal/modules/cjs/loader.js:638
                throw err;
                Error: Cannot find module ‘/home/pi/MagicMirror/tests/configs/check_config.js’
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                at startup (internal/bootstrap/node.js:283:19)
                at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.11.0 config:check: node tests/configs/check_config.js
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.11.0 config:check script.
                npm ERR! /home/pi/.npm/_logs/2020-07-02T20_48_03_566Z-debug.log"
                  sdetweil @Cyric
                  @Cyric u ran the update? how?
                  S C 2 Replies Last reply Reply Quote 0
                    @sdetweil can u open the developers window, ctrl-shift-i, select the tab labeled console, and scroll up to see any errors
                      Cyric @sdetweil
                      @sdetweil I did git pull in the ~/MagicMirror parent directory. That gave me a few errors about changes, so i just did git pull --hard. Then I did npm install. For the other modules, i just did git pull and npm install.
                        Cyric
                        @sdetweil Im sorry, where do i do this at?
                        • 1 / 4
