    MM cant boot, wont boot!
    40 Posts 5 Posters 17.0k Views 5 Watching
    • N Offline
      nicoz
      npm install seemed to work in that i dont get a black screen anymore.
      npm start will start the mirror but for some reason it wont stay open. i come back to the mirror and i am back at the Rasbian Home screen?
      i also tried config:check but i dont really know what im looking at
        sdetweil @nicoz
        @nicoz when u do npm start is shows messages to the screen…
        can you do
        npm start > somefile 2>&1
        and when it ends, look at somefile
          Cyric @BKeyport
          @BKeyport said in MM cant boot, wont boot!:
          One other thing you can do is run “npm run config:check” in the magicmirror root directory (~/MagicMirror) - it’ll run through and see if there’s anything that’s slightly out of wack to blank the mirror but not out of wack enough to throw an error. It’s saved me lots of headaches several times.
          I am having this same issue. I ran the update and everything was fine except my calendar and the 2 day weather thing, which looks like a known bug. I rebooted and am only getting a black screen with the mouse cursor. I did some digging and ran the npm install on the main magic mirror directory, and the directories for the modules i’m using, and it’s still not working. I tried to do the npm run config:check and it came back with an error saying " > magicmirror@2.11.0 config:check /home/pi/MagicMirror
          node tests/configs/check_config.js
          internal/modules/cjs/loader.js:638
          throw err;
          Error: Cannot find module ‘/home/pi/MagicMirror/tests/configs/check_config.js’
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.11.0 config:check: node tests/configs/check_config.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.11.0 config:check script.
          npm ERR! /home/pi/.npm/_logs/2020-07-02T20_48_03_566Z-debug.log"
            sdetweil @Cyric
            @Cyric u ran the update? how?
            S C 2 Replies Last reply Reply Quote 0
              @sdetweil can u open the developers window, ctrl-shift-i, select the tab labeled console, and scroll up to see any errors
                Cyric @sdetweil
                @sdetweil I did git pull in the ~/MagicMirror parent directory. That gave me a few errors about changes, so i just did git pull --hard. Then I did npm install. For the other modules, i just did git pull and npm install.
                  Cyric
                  @sdetweil Im sorry, where do i do this at?
                    sdetweil @Cyric
                    @Cyric on the mirror black screen
                      Cyric @sdetweil
                      @sdetweil when I go into the developer console, it says " devtools was disconnected from the page. Once the page is reloaded, devtools will automatically reconnect."
                      If I x out of that and go to console, it’s empty.
                        Cyric
                        More troubleshooting: I deleted the config.js and it loaded and said I needed to load a config.js file. I loaded the sample one, and it went back ot being a black screen.
                        • 1 / 4
