    MMM-awesome-alexa
    241 Posts 43 Posters 461.0k Views 47 Watching
    • U
      uok825 @sdetweil
      @sdetweil i “pm2 stop all”
        sdetweil @uok825
        @uok825 pm2 status please
        U 2 Replies Last reply
        • U
          uok825 @sdetweil
          @sdetweil Wait flushing
          • U
            uok825 @sdetweil
            @sdetweil 0|MagicMir | [2020-06-27 01:24:01.211] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: Europe is not defined
            0|MagicMir | at Object. (/home/pi/MagicMirror/config/config.js:126:15)
            0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:778:30)
            0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
            0|MagicMir | at Module.load (internal/modules/cjs/loader.js:653:32)
            0|MagicMir | at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:585:3)
            0|MagicMir | at Module.require (internal/modules/cjs/loader.js:692:17)
            0|MagicMir | at require (internal/modules/cjs/helpers.js:25:18)
            0|MagicMir | at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
            0|MagicMir | at App.start (/home/pi/MagicMirror/js/app.js:210:3)
            0|MagicMir | [2020-06-27 01:24:03.383] [ERROR] { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
            0|MagicMir | at Server.setupListenHandle [as _listen2] (net.js:1280:14)
            0|MagicMir | at listenInCluster (net.js:1328:12)
            0|MagicMir | at GetAddrInfoReqWrap.doListen [as callback] (net.js:1461:7)
            0|MagicMir | at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
            0|MagicMir | code: ‘EADDRINUSE’,
            0|MagicMir | errno: ‘EADDRINUSE’,
            0|MagicMir | syscall: ‘listen’,
            0|MagicMir | address: ‘127.0.0.1’,
            0|MagicMir | port: 8080 }
            /home/pi/.pm2/logs/MagicMirror-out.log last 200 lines:
            0|MagicMir |
            0|MagicMir | > magicmirror@2.11.0 start /home/pi/MagicMirror
            0|MagicMir | > ./run-start.sh $1
            0|MagicMir |
            0|MagicMir | [2020-06-27 01:24:01.042] [LOG] Starting MagicMirror: v2.11.0
            0|MagicMir | [2020-06-27 01:24:01.170] [LOG] Loading config …
            0|MagicMir | [2020-06-27 01:24:01.223] [LOG] Loading module helpers …
            0|MagicMir | [2020-06-27 01:24:01.652] [LOG] Initializing new module helper …
            0|MagicMir | [2020-06-27 01:24:01.664] [LOG] Module helper loaded: updatenotification
            0|MagicMir | [2020-06-27 01:24:01.679] [LOG] No helper found for module: helloworld.
            0|MagicMir | [2020-06-27 01:24:01.691] [LOG] All module helpers loaded.
            0|MagicMir | [2020-06-27 01:24:02.810] [LOG] Starting server on port 8080 …
            0|MagicMir | [2020-06-27 01:24:02.948] [LOG] Server started …
            0|MagicMir | [2020-06-27 01:24:02.960] [LOG] Connecting socket for: updatenotification
            0|MagicMir | [2020-06-27 01:24:02.973] [LOG] Sockets connected & modules started …
            0|MagicMir | [2020-06-27 01:24:02.984] [LOG]
            0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
            0|MagicMir | Starting chromium browser now, have patience, it takes a minute
            0|MagicMir | [2020-06-27 01:24:03.350] [LOG] Whoops! There was an uncaught exception…
            0|MagicMir | [2020-06-27 01:24:03.495] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|MagicMir | [2020-06-27 01:24:03.513] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              sdetweil @uok825
              @uok825
              so, u gotta fix this, PM2 keeps restarting…
              i don’t want you to use pm2 to test
              do
              pm2 stop  all
              then
              npm run config:check
              find and fix error
              if no error, then
              npm start
              verify working
              ctrl-c to exit MM
              then pm2 start
              U 1 Reply Last reply
              • U
                uok825 @sdetweil
                @sdetweil config is running correct but
                It causes by Screencast maybe?
                My config
                  sdetweil @uok825
                  @uok825 you still have something running using port 8080…
                  disable the modules one by one
                  add
                    module: name,
                    disabled: true,             // < --- add this
                  i don’t know anything about the modules themselves…
                  • U
                    uok825 @sdetweil
                    @sdetweil Maybe screencast?
                    • U
                      uok825 @sdetweil
                      @sdetweil Disabled all but nothing change
                        sdetweil @uok825
                        @uok825
                        try this , see who is listening on 8080
                        netstat -ltnp | grep -w ':8080'
                        • U
                          uok825 @sdetweil
                          Nothing
                            sdetweil @uok825
                            @uok825 ok, then
                            change the port value in config.js to 8090
                            • U
                              uok825 @sdetweil
                              @sdetweil Problem fixed, now try alexa
                                sdetweil @uok825
                                @uok825 do you have a web server running on that system?
                                • U
                                  uok825 @sdetweil
                                  @sdetweil No i don’t have, i install fresh raspian
                                    sdetweil @uok825
                                    @uok825 show results of ps -ef
                                    without MM running
                                    • U
                                      uok825 @sdetweil
                                      @sdetweil said in MMM-awesome-alexa:
                                      without MM running
                                      root        19     2  0 Haz26 ?        00:00:00 [kworker/u3:0-hci0]
                                      root        20     2  0 Haz26 ?        00:00:00 [xprtiod]
                                      root        23     2  0 Haz26 ?        00:01:40 [kswapd0]
                                      root        24     2  0 Haz26 ?        00:00:00 [nfsiod]
                                      root        35     2  0 Haz26 ?        00:00:00 [kthrotld]
                                      root        36     2  0 Haz26 ?        00:00:00 [iscsi_eh]
                                      root        37     2  0 Haz26 ?        00:00:00 [dwc_otg]
                                      root        38     2  0 Haz26 ?        00:00:00 [DWC Notificatio]
                                      root        39     2  0 Haz26 ?        00:00:00 [vchiq-slot/0]
                                      root        40     2  0 Haz26 ?        00:00:00 [vchiq-recy/0]
                                      root        41     2  0 Haz26 ?        00:00:00 [vchiq-sync/0]
                                      root        42     2  0 Haz26 ?        00:00:00 [vchiq-keep/0]
                                      root        43     2  0 Haz26 ?        00:00:00 [SMIO]
                                      root        44     2  0 Haz26 ?        00:00:48 [irq/86-mmc1]
                                      root        47     2  0 Haz26 ?        00:00:00 [mmc_complete]
                                      root        50     2  0 Haz26 ?        00:00:02 [jbd2/mmcblk0p2-]
                                      root        51     2  0 Haz26 ?        00:00:00 [ext4-rsv-conver]
                                      root        52     2  0 Haz26 ?        00:00:00 [ipv6_addrconf]
                                      root        86     1  0 Haz26 ?        00:00:02 /lib/systemd/systemd-journald
                                      root       108     1  0 Haz26 ?        00:00:01 /lib/systemd/systemd-udevd
                                      root       122     2  0 Haz26 ?        00:00:00 [SMIO]
                                      root       128     2  0 Haz26 ?        00:00:00 [mmal-vchiq]
                                      root       129     2  0 Haz26 ?        00:00:00 [mmal-vchiq]
                                      root       132     2  0 Haz26 ?        00:00:00 [mmal-vchiq]
                                      root       159     2  0 Haz26 ?        00:00:00 [cfg80211]
                                      root       162     2  0 Haz26 ?        00:00:00 [brcmf_wq/mmc1:0]
                                      root       163     2  0 Haz26 ?        00:00:11 [brcmf_wdog/mmc1]
                                      systemd+   217     1  0 Haz26 ?        00:00:01 /lib/systemd/systemd-timesyncd
                                      root       246     1  0 Haz26 ?        00:00:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
                                      root       247     1  0 Haz26 ?        00:00:00 /usr/sbin/cron -f
                                      nobody     248     1  0 Haz26 ?        00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                                      root       250     1  0 Haz26 ?        00:00:01 /usr/lib/udisks2/udisksd
                                      avahi      252     1  0 Haz26 ?        00:00:01 avahi-daemon: running [raspberrypi.local]
                                      root       253     1  0 Haz26 ?        00:00:20 /usr/sbin/rngd -r /dev/hwrng
                                      root       261     1  0 Haz26 ?        00:00:00 /lib/systemd/systemd-logind
                                      avahi      266   252  0 Haz26 ?        00:00:00 avahi-daemon: chroot helper
                                      root       271     1  0 Haz26 ?        00:00:00 /usr/sbin/rsyslogd -n -iNONE
                                      message+   277     1  0 Haz26 ?        00:00:02 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                      root       310     1  0 Haz26 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
                                      root       330     1  0 Haz26 ?        00:00:00 /sbin/dhcpcd -q -b
                                      root       343     1  0 Haz26 ?        00:00:01 /usr/lib/policykit-1/polkitd --no-debug
                                      root       353     1  0 Haz26 ?        00:00:00 /usr/bin/vncserver-x11-serviced -fg
                                      root       354   353  5 Haz26 ?        00:13:58 /usr/bin/vncserver-x11-core -service
                                      root       368     1  0 Haz26 ?        00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:68:21:40
                                      root       369     2  0 Haz26 ?        00:00:00 [kworker/u3:2-hci0]
                                      root       372     1  0 Haz26 ?        00:00:04 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
                                      root       374     1  0 Haz26 ?        00:00:00 /usr/sbin/sshd -D
                                      root       378     1  0 Haz26 ?        00:00:00 /usr/sbin/lightdm
                                      root       398     1  0 Haz26 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
                                      root       404     1  0 Haz26 ?        00:00:00 /usr/bin/bluealsa
                                      root       414     2  0 Haz26 ?        00:00:00 [krfcommd]
                                      root       421   378  2 Haz26 tty7     00:06:23 /usr/lib/xorg/Xorg -s 0 -dpms :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
                                      root       422     1  0 Haz26 tty1     00:00:00 /bin/login -f
                                      root       424     1  0 Haz26 ?        00:02:01 /usr/bin/vncagent service 14
                                      root       480   378  0 Haz26 ?        00:00:00 lightdm --session-child 14 17
                                      pi         492     1  0 Haz26 ?        00:00:00 /lib/systemd/systemd --user
                                      pi         495   492  0 Haz26 ?        00:00:00 (sd-pam)
                                      pi         506   480  0 Haz26 ?        00:00:03 /usr/bin/lxsession -s LXDE-pi -e LXDE
                                      pi         518   422  0 Haz26 tty1     00:00:00 -bash
                                      pi         519   492  0 Haz26 ?        00:00:01 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                      pi         557   506  0 Haz26 ?        00:00:00 /usr/bin/ssh-agent x-session-manager
                                      pi         568   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfsd
                                      pi         573   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
                                      pi         575     1  0 Haz26 ?        00:00:33 PM2 v4.4.0: God Daemon (/home/pi/.pm2)
                                      pi         580     1  0 Haz26 ?        00:00:02 /usr/bin/vncserverui service 15
                                      pi         606   506  0 Haz26 ?        00:00:06 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
                                      pi         607   506  0 Haz26 ?        00:00:00 lxpolkit
                                      pi         608   506  0 Haz26 ?        00:01:03 lxpanel --profile LXDE-pi
                                      pi         610   506  0 Haz26 ?        00:00:13 pcmanfm --desktop --profile LXDE-pi
                                      pi         619   580  0 Haz26 ?        00:00:00 /usr/bin/vncserverui -statusicon 5
                                      pi         621     1  0 Haz26 ?        00:00:00 /usr/bin/ssh-agent -s
                                      pi         692     1  0 Haz26 ?        00:00:00 /usr/lib/menu-cache/menu-cached /run/user/1000/menu-cached-:0
                                      pi         696   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
                                      pi         703   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
                                      pi         707   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
                                      pi         712   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
                                      pi         716   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
                                      pi         817   568  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
                                      root      1191   374  0 Haz26 ?        00:00:00 sshd: pi [priv]
                                      pi        1201  1191  0 Haz26 ?        00:00:01 sshd: pi@notty
                                      pi        1203  1201  0 Haz26 ?        00:00:00 /usr/lib/openssh/sftp-server
                                      root      1205   374  0 Haz26 ?        00:00:00 sshd: pi [priv]
                                      pi        1215  1205  0 Haz26 ?        00:00:00 sshd: pi@notty
                                      pi        1217  1215  0 Haz26 ?        00:00:00 -bash
                                      pi        1307     1  0 Haz26 ?        00:00:00 /bin/bash ./run-start.sh
                                      pi        1308  1307  1 Haz26 ?        00:04:24 node serveronly
                                      pi        1319     1  0 Haz26 ?        00:00:00 tee
                                      pi        2011   608  0 Haz26 ?        00:02:05 lxterminal
                                      pi        2028  2011  0 Haz26 pts/0    00:00:01 bash
                                      root      2317   374  0 Haz26 ?        00:00:00 sshd: pi [priv]
                                      pi        2560  2317  0 Haz26 ?        00:00:00 sshd: pi@notty
                                      pi        2562  2560  0 Haz26 ?        00:00:00 /usr/lib/openssh/sftp-server
                                      root     18999     2  0 01:17 ?        00:00:07 [kworker/u2:0-cfg80211]
                                      root     19458     2  0 01:35 ?        00:00:07 [kworker/u2:1-events_unbound]
                                      root     20569     2  0 01:49 ?        00:00:14 [kworker/0:2H-mmc_complete]
                                      root     21338     2  0 01:57 ?        00:00:00 [kworker/0:2-memcg_kmem_cache]
                                      root     21633     2  0 02:02 ?        00:00:00 [kworker/0:1-events]
                                      root     21649     2  0 02:05 ?        00:00:05 [kworker/0:1H-events_highpri]
                                      root     22089     2  0 02:08 ?        00:00:00 [kworker/0:0-events]
                                      root     22217     2  2 02:10 ?        00:00:06 [kworker/0:0H-mmc_complete]
                                      root     22495     2  0 02:12 ?        00:00:00 [kworker/0:3-events]
                                      root     22526     2  0 02:14 ?        00:00:00 [kworker/u2:2-events_unbound]
                                      pi       22533  2028  0 02:15 pts/0    00:00:00 ps -ef
                                        sdetweil @uok825
                                        @uok825 said in MMM-awesome-alexa:
                                        somebody has the server running
                                        if u are using my install script, it starts serveronly and then connects chromium over that
                                        as there is no electron browser for pi0. (but only on pi 0/armv6l devices)
                                        show package.json
                                        “start” line
                                        • U
                                          uok825 @sdetweil
                                          @sdetweil I used yourse
                                            sdetweil @uok825
                                            @uok825 yep, so server is running on port 8080…
                                            sudo kill -9 1308
                                            but pm2 stop
                                            should have stopped that, does on my pi0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
