    MMM-awesome-alexa
    241 Posts 43 Posters 452.1k Views 47 Watching
      sdetweil @uok825
      @uok825
      try this , see who is listening on 8080
      netstat -ltnp | grep -w ':8080'
      U 1 Reply Last reply Reply Quote 0
      • U
        uok825 @sdetweil
        Nothing
          sdetweil @uok825
          @uok825 ok, then
          change the port value in config.js to 8090
          • U
            uok825 @sdetweil
            @sdetweil Problem fixed, now try alexa
              sdetweil @uok825
              @uok825 do you have a web server running on that system?
              • U
                uok825 @sdetweil
                @sdetweil No i don’t have, i install fresh raspian
                  sdetweil @uok825
                  @uok825 show results of ps -ef
                  without MM running
                  • U
                    uok825 @sdetweil
                    @sdetweil said in MMM-awesome-alexa:
                    without MM running
                    root        19     2  0 Haz26 ?        00:00:00 [kworker/u3:0-hci0]
                    root        20     2  0 Haz26 ?        00:00:00 [xprtiod]
                    root        23     2  0 Haz26 ?        00:01:40 [kswapd0]
                    root        24     2  0 Haz26 ?        00:00:00 [nfsiod]
                    root        35     2  0 Haz26 ?        00:00:00 [kthrotld]
                    root        36     2  0 Haz26 ?        00:00:00 [iscsi_eh]
                    root        37     2  0 Haz26 ?        00:00:00 [dwc_otg]
                    root        38     2  0 Haz26 ?        00:00:00 [DWC Notificatio]
                    root        39     2  0 Haz26 ?        00:00:00 [vchiq-slot/0]
                    root        40     2  0 Haz26 ?        00:00:00 [vchiq-recy/0]
                    root        41     2  0 Haz26 ?        00:00:00 [vchiq-sync/0]
                    root        42     2  0 Haz26 ?        00:00:00 [vchiq-keep/0]
                    root        43     2  0 Haz26 ?        00:00:00 [SMIO]
                    root        44     2  0 Haz26 ?        00:00:48 [irq/86-mmc1]
                    root        47     2  0 Haz26 ?        00:00:00 [mmc_complete]
                    root        50     2  0 Haz26 ?        00:00:02 [jbd2/mmcblk0p2-]
                    root        51     2  0 Haz26 ?        00:00:00 [ext4-rsv-conver]
                    root        52     2  0 Haz26 ?        00:00:00 [ipv6_addrconf]
                    root        86     1  0 Haz26 ?        00:00:02 /lib/systemd/systemd-journald
                    root       108     1  0 Haz26 ?        00:00:01 /lib/systemd/systemd-udevd
                    root       122     2  0 Haz26 ?        00:00:00 [SMIO]
                    root       128     2  0 Haz26 ?        00:00:00 [mmal-vchiq]
                    root       129     2  0 Haz26 ?        00:00:00 [mmal-vchiq]
                    root       132     2  0 Haz26 ?        00:00:00 [mmal-vchiq]
                    root       159     2  0 Haz26 ?        00:00:00 [cfg80211]
                    root       162     2  0 Haz26 ?        00:00:00 [brcmf_wq/mmc1:0]
                    root       163     2  0 Haz26 ?        00:00:11 [brcmf_wdog/mmc1]
                    systemd+   217     1  0 Haz26 ?        00:00:01 /lib/systemd/systemd-timesyncd
                    root       246     1  0 Haz26 ?        00:00:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
                    root       247     1  0 Haz26 ?        00:00:00 /usr/sbin/cron -f
                    nobody     248     1  0 Haz26 ?        00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                    root       250     1  0 Haz26 ?        00:00:01 /usr/lib/udisks2/udisksd
                    avahi      252     1  0 Haz26 ?        00:00:01 avahi-daemon: running [raspberrypi.local]
                    root       253     1  0 Haz26 ?        00:00:20 /usr/sbin/rngd -r /dev/hwrng
                    root       261     1  0 Haz26 ?        00:00:00 /lib/systemd/systemd-logind
                    avahi      266   252  0 Haz26 ?        00:00:00 avahi-daemon: chroot helper
                    root       271     1  0 Haz26 ?        00:00:00 /usr/sbin/rsyslogd -n -iNONE
                    message+   277     1  0 Haz26 ?        00:00:02 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                    root       310     1  0 Haz26 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
                    root       330     1  0 Haz26 ?        00:00:00 /sbin/dhcpcd -q -b
                    root       343     1  0 Haz26 ?        00:00:01 /usr/lib/policykit-1/polkitd --no-debug
                    root       353     1  0 Haz26 ?        00:00:00 /usr/bin/vncserver-x11-serviced -fg
                    root       354   353  5 Haz26 ?        00:13:58 /usr/bin/vncserver-x11-core -service
                    root       368     1  0 Haz26 ?        00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:68:21:40
                    root       369     2  0 Haz26 ?        00:00:00 [kworker/u3:2-hci0]
                    root       372     1  0 Haz26 ?        00:00:04 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
                    root       374     1  0 Haz26 ?        00:00:00 /usr/sbin/sshd -D
                    root       378     1  0 Haz26 ?        00:00:00 /usr/sbin/lightdm
                    root       398     1  0 Haz26 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
                    root       404     1  0 Haz26 ?        00:00:00 /usr/bin/bluealsa
                    root       414     2  0 Haz26 ?        00:00:00 [krfcommd]
                    root       421   378  2 Haz26 tty7     00:06:23 /usr/lib/xorg/Xorg -s 0 -dpms :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
                    root       422     1  0 Haz26 tty1     00:00:00 /bin/login -f
                    root       424     1  0 Haz26 ?        00:02:01 /usr/bin/vncagent service 14
                    root       480   378  0 Haz26 ?        00:00:00 lightdm --session-child 14 17
                    pi         492     1  0 Haz26 ?        00:00:00 /lib/systemd/systemd --user
                    pi         495   492  0 Haz26 ?        00:00:00 (sd-pam)
                    pi         506   480  0 Haz26 ?        00:00:03 /usr/bin/lxsession -s LXDE-pi -e LXDE
                    pi         518   422  0 Haz26 tty1     00:00:00 -bash
                    pi         519   492  0 Haz26 ?        00:00:01 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                    pi         557   506  0 Haz26 ?        00:00:00 /usr/bin/ssh-agent x-session-manager
                    pi         568   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfsd
                    pi         573   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
                    pi         575     1  0 Haz26 ?        00:00:33 PM2 v4.4.0: God Daemon (/home/pi/.pm2)
                    pi         580     1  0 Haz26 ?        00:00:02 /usr/bin/vncserverui service 15
                    pi         606   506  0 Haz26 ?        00:00:06 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
                    pi         607   506  0 Haz26 ?        00:00:00 lxpolkit
                    pi         608   506  0 Haz26 ?        00:01:03 lxpanel --profile LXDE-pi
                    pi         610   506  0 Haz26 ?        00:00:13 pcmanfm --desktop --profile LXDE-pi
                    pi         619   580  0 Haz26 ?        00:00:00 /usr/bin/vncserverui -statusicon 5
                    pi         621     1  0 Haz26 ?        00:00:00 /usr/bin/ssh-agent -s
                    pi         692     1  0 Haz26 ?        00:00:00 /usr/lib/menu-cache/menu-cached /run/user/1000/menu-cached-:0
                    pi         696   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
                    pi         703   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
                    pi         707   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
                    pi         712   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
                    pi         716   492  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
                    pi         817   568  0 Haz26 ?        00:00:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
                    root      1191   374  0 Haz26 ?        00:00:00 sshd: pi [priv]
                    pi        1201  1191  0 Haz26 ?        00:00:01 sshd: pi@notty
                    pi        1203  1201  0 Haz26 ?        00:00:00 /usr/lib/openssh/sftp-server
                    root      1205   374  0 Haz26 ?        00:00:00 sshd: pi [priv]
                    pi        1215  1205  0 Haz26 ?        00:00:00 sshd: pi@notty
                    pi        1217  1215  0 Haz26 ?        00:00:00 -bash
                    pi        1307     1  0 Haz26 ?        00:00:00 /bin/bash ./run-start.sh
                    pi        1308  1307  1 Haz26 ?        00:04:24 node serveronly
                    pi        1319     1  0 Haz26 ?        00:00:00 tee
                    pi        2011   608  0 Haz26 ?        00:02:05 lxterminal
                    pi        2028  2011  0 Haz26 pts/0    00:00:01 bash
                    root      2317   374  0 Haz26 ?        00:00:00 sshd: pi [priv]
                    pi        2560  2317  0 Haz26 ?        00:00:00 sshd: pi@notty
                    pi        2562  2560  0 Haz26 ?        00:00:00 /usr/lib/openssh/sftp-server
                    root     18999     2  0 01:17 ?        00:00:07 [kworker/u2:0-cfg80211]
                    root     19458     2  0 01:35 ?        00:00:07 [kworker/u2:1-events_unbound]
                    root     20569     2  0 01:49 ?        00:00:14 [kworker/0:2H-mmc_complete]
                    root     21338     2  0 01:57 ?        00:00:00 [kworker/0:2-memcg_kmem_cache]
                    root     21633     2  0 02:02 ?        00:00:00 [kworker/0:1-events]
                    root     21649     2  0 02:05 ?        00:00:05 [kworker/0:1H-events_highpri]
                    root     22089     2  0 02:08 ?        00:00:00 [kworker/0:0-events]
                    root     22217     2  2 02:10 ?        00:00:06 [kworker/0:0H-mmc_complete]
                    root     22495     2  0 02:12 ?        00:00:00 [kworker/0:3-events]
                    root     22526     2  0 02:14 ?        00:00:00 [kworker/u2:2-events_unbound]
                    pi       22533  2028  0 02:15 pts/0    00:00:00 ps -ef
                      sdetweil @uok825
                      @uok825 said in MMM-awesome-alexa:
                      somebody has the server running
                      if u are using my install script, it starts serveronly and then connects chromium over that
                      as there is no electron browser for pi0. (but only on pi 0/armv6l devices)
                      show package.json
                      “start” line
                      • U
                        uok825 @sdetweil
                        @sdetweil I used yourse
                          sdetweil @uok825
                          @uok825 yep, so server is running on port 8080…
                          sudo kill -9 1308
                          but pm2 stop
                          should have stopped that, does on my pi0
                          • U
                            uok825 @sdetweil
                            What is that error?
                              sdetweil @uok825
                              @uok825 no idea… not my module… his code is impossible to understand, typescript compiled to js, then minified…
                              • U
                                uok825 @sdetweil
                                @sdetweil I killed -9 1308, what is next? changing port to 8080 again?
                                  sdetweil @uok825
                                  @uok825 yeh i guess… then npm start to verify runs, then ctrl-c and make sure it stops (ps -ef | grep node
                                  the pm2 start and pm2 stop
                                  • U
                                    uok825 @sdetweil
                                    @sdetweil sure, i doing. I need to fix this alexa problem
                                    • N
                                      nkchokshi
                                      Anyone can help me please how do i get an authentication number for Alexa? I have tried to add
                                      https://192.168.0.10:1234
                                      https://192.168.0.10:3000/authresponse
                                      https://magic-mirror-avs.github.io/Alexa-Web-Helper/authresponse
                                      none of these pages are giving me code after when i click agree, to consent screen. i just end up with
                                      Amazon Error page with no number on address bar. Screenshot 2020-07-28 at 12.20.46 PM.png
                                      We’re sorry!
                                      An error occurred when we tried to process your request. Rest assured, we’re already working on the problem and expect to resolve it shortly.
                                        sdetweil @nkchokshi
                                        @nkchokshi which return url did I specify in Amazon, and u MUST use that one
                                        u want one that will be on the local. machine. so, localhost:7777 might be good
                                        • G
                                          Ghost2000
                                          I have the same problem with the token can someone help me.
                                          Will the module be updated again? or is there a new module?
                                            sdetweil @Ghost2000
                                            @Ghost2000 hasn’t been updated in 17 months, 3 years before that. so, not likely to get update.
                                            they are very picky about what they allow for auth callback urls. http://localhost:someportnumber >1000
                                            they will pop up a screen to request logon and authorize this app to access your account, u click approve, and then the page appears with the error at the top using your auth URL and the code.
                                            I know this works, cause I do it in another application
                                            G 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
