    MMM-awesome-alexa
    241 Posts 43 Posters 440.6k Views 47 Watching
      sdetweil @uok825
      @uok825 said in MMM-awesome-alexa:
      pi 1217 1215 0 Haz26 ? 00:00:00 -bash
      pi 1307 1 0 Haz26 ? 00:00:00 /bin/bash ./run-start.sh
      pi 1308 1307 1 Haz26 ? 00:04:24 node serveronly
      somebody has the server running
      if u are using my install script, it starts serveronly and then connects chromium over that
      as there is no electron browser for pi0. (but only on pi 0/armv6l devices)
      show package.json
      “start” line
      U 1 Reply Last reply Reply Quote 0
      • U Offline
        uok825 @sdetweil
        @sdetweil I used yourse
          sdetweil @uok825
          @uok825 yep, so server is running on port 8080…
          sudo kill -9 1308
          but pm2 stop
          should have stopped that, does on my pi0
          • U Offline
            uok825 @sdetweil
            What is that error?
              sdetweil @uok825
              @uok825 no idea… not my module… his code is impossible to understand, typescript compiled to js, then minified…
              • U Offline
                uok825 @sdetweil
                @sdetweil I killed -9 1308, what is next? changing port to 8080 again?
                  sdetweil @uok825
                  @uok825 yeh i guess… then npm start to verify runs, then ctrl-c and make sure it stops (ps -ef | grep node
                  the pm2 start and pm2 stop
                  • U Offline
                    uok825 @sdetweil
                    @sdetweil sure, i doing. I need to fix this alexa problem
                    • N Offline
                      nkchokshi
                      Anyone can help me please how do i get an authentication number for Alexa? I have tried to add
                      https://192.168.0.10:1234
                      https://192.168.0.10:3000/authresponse
                      https://magic-mirror-avs.github.io/Alexa-Web-Helper/authresponse
                      none of these pages are giving me code after when i click agree, to consent screen. i just end up with
                      Amazon Error page with no number on address bar. Screenshot 2020-07-28 at 12.20.46 PM.png
                      We’re sorry!
                      An error occurred when we tried to process your request. Rest assured, we’re already working on the problem and expect to resolve it shortly.
                        sdetweil @nkchokshi
                        @nkchokshi which return url did I specify in Amazon, and u MUST use that one
                        u want one that will be on the local. machine. so, localhost:7777 might be good
                        • G Offline
                          Ghost2000
                          I have the same problem with the token can someone help me.
                          Will the module be updated again? or is there a new module?
                            sdetweil @Ghost2000
                            @Ghost2000 hasn’t been updated in 17 months, 3 years before that. so, not likely to get update.
                            they are very picky about what they allow for auth callback urls. http://localhost:someportnumber >1000
                            they will pop up a screen to request logon and authorize this app to access your account, u click approve, and then the page appears with the error at the top using your auth URL and the code.
                            I know this works, cause I do it in another application
                            G 2 Replies Last reply Reply Quote 0
                            • G Offline
                              Ghost2000
                              • G Offline
                                Ghost2000 @sdetweil
                                @sdetweil said in MMM-awesome-alexa:
                                http://localhost:3000/ or http://localhost:3000/authresponse
                                • G Offline
                                  Ghost2000 @sdetweil
                                  http://localhost:3000/authresponse = It does not work
                                  http://localhost:3000/ = It does not work
                                  Invalid. Please enter your Redirect URI.
                                    sdetweil @Ghost2000
                                    @Ghost2000 yes, looking at the code now…
                                    • G Offline
                                      Ghost2000
                                        sdetweil @Ghost2000
                                        @Ghost2000 yeh, some bug in their helper code… suddenly
                                        edit the config_helper.js
                                        change this line to return true;
                                                        return true; // "Invalid. Please enter your Redirect URI.";
                                        using your return url in my avs config and on the helper
                                        must copy ALL of the url from helper (2 lines) to the browser address field
                                        hit enter
                                        then sign in
                                        then click allow,
                                        apparently I have something running at port 3000
                                        but
                                        code is there
                                          @Ghost2000 and it worked
                                          • G Offline
                                            Ghost2000 @sdetweil
                                            @sdetweil NO
                                            const chalk = require("chalk");
                                            const clear = require("clear");
                                            const figlet = require("figlet");
                                            const inquirer = require("inquirer");
                                            const request = require("request-promise");
                                            const CLI = require("clui");
                                            const spinner = new CLI.Spinner("Getting response from Amazon...");
                                            const questions = [
                                                    type: "input",
                                                    message: "Enter your Client ID from Alexa Voice Service (AVS):",
                                                    validate: value => {
                                                        if (value.length) {
                                                            return true;
                                                        } else {
                                                            return "Please enter your Client ID.";
                                                    type: "input",
                                                    message: "Enter your Client Secret from Alexa Voice Service (AVS):",
                                                    validate: function(value) {
                                                        if (value.length) {
                                                            return true;
                                                        } else {
                                                            return "Please enter your Client Secret.";
                                                    type: "input",
                                                    message: "Enter your Product ID from Alexa Voice Service (AVS):",
                                                        if (value.length) {
                                                            return true;
                                                        } else {
                                                            return "Please enter your Product ID.";
                                                    type: "input",
                                                    message: "Enter your Redirect URI (allowed return URL) from Alexa Voice Service (AVS):",
                                                        const pattern = new RegExp(
                                                            "^(https?:\\/\\/)?" + // protocol
                                                            "((([a-z\\d]([a-z\\d-]*[a-z\\d])*)\\.)+[a-z]{2,}|" + // domain name
                                                            "((\\d{1,3}\\.){3}\\d{1,3}))" + // OR ip (v4) address
                                                            "(\\:\\d+)?(\\/[-a-z\\d%_.~+]*)*" + // port and path
                                                            "(\\?[;&a-z\\d%_.~+=-]*)?" + // query string
        "(\\#[-a-z\\d_]*)?$",
                                                            "i", // fragment locator
                                                        if (!!pattern.test(value)) {
                                                            return true;
                                                        } else {
                                                            return "Invalid. Please enter your Redirect URI.";
                                            const authCodeQuestion = [
                                                    type: "input",
                                                    message: "Enter your Authorization code (from previous step):",
                                                        if (value.length) {
                                                            return true;
                                                        } else {
                                                            return "Please enter your Authorization Code.";
                                            const continueQuestion = [
                                                    type: "confirm",
                                                    message: "Do you wish to continue to generate the MagicMirror config?",
                                                    default: true,
                                            const configQuestions = [
                                                    type: "list",
                                                    message: "What do you want your Wake Word to be? (The phrase used to activate this module)",
                                                    choices: ["Alexa", "Smart Mirror", "Snowboy"],
                                                    type: "confirm",
                                                    message: "Do you want to use lite mode?",
                                                    default: false,
                                                    type: "confirm",
                                                    message: "Do you want to use visulization?",
                                                    default: true,
                                            const generateQuery = params =>
                                                Object.keys(params)
                                                    .map(key => key + "=" + params[key])
                                                    .join("&");
                                            clear();
                                            console.log(chalk.yellow(figlet.textSync("Awesome Alexa", { horizontalLayout: "full" })));
                                            console.log(chalk.underline("Welcome to the Config Helper tool!"));
                                            console.log("This tool will help you get the Refresh Token needed to run MMM-awesome-alexa.");
                                            console.log(
                                                "It will optionally generate your config for you, if you wish. If not, you can still create it manually after.",
                                            console.log("Go to https://developer.amazon.com/alexa/console/avs/products to get the details.\n");
                                            const run = async () => {
                                                const output = await inquirer.prompt(questions);
                                                const scopeData = {
                                                    "alexa:all": {
                                                        productID: output.productId,
                                                        productInstanceAttributes: {
                                                            deviceSerialNumber: 123, // Can be anything
                                                const queryParams = generateQuery({
                                                    client_id: output.clientId,
                                                    scope: "alexa:all",
                                                    scope_data: JSON.stringify(scopeData),
                                                    response_type: "code",
                                                    redirect_uri: output.redirectUri,
                                                console.log(
                                                    chalk.blue("Hooray! Link is generated. Part 1 is done. Please go on the link below.\n"),
                                                console.log(
                                                    chalk.yellow("Please be aware that at the end,"),
                                                    chalk.bgRed("THERE WILL BE AN ERROR!"),
                                                    chalk.green("This is normal.\n"),
                                                console.log(`https://www.amazon.com/ap/oa?${queryParams}`);
                                                console.log("\n^^^ Copy and paste the above in your Browser ^^^, follow the instructions.");
                                                console.log(
                                                    "The authorization code you want is in the address bar in the final screen: https://imgur.com/a/6DbYlKA",
                                                const authOutput = await inquirer.prompt(authCodeQuestion);
                                                spinner.start();
                                                const amazonTokenReponse = await request.post("https://api.amazon.com/auth/o2/token", {
                                                    form: {
                                                        grant_type: "authorization_code",
                                                        code: authOutput.authCode,
                                                        client_secret: output.clientSecret,
                                                    json: true,
                                                spinner.stop();
                                                console.log(
                                                    chalk.bgGreen(
                                                        "\nComplete! Your refresh token should be in the Amazon response below. If not raise an issue:\n",
                                                console.dir(amazonTokenReponse, { colors: true });
                                                const continueOutput = await inquirer.prompt(continueQuestion);
                                                if (!continueOutput.continue) {
                                                    process.exit();
                                                const configOutput = await inquirer.prompt(configQuestions);
                                                console.log(chalk.green("\nCongrats! Here is the full config:\n"));
                                                console.dir(
                                                        module: "MMM-awesome-alexa",
                                                        position: "bottom_bar",
                                                            wakeWord: configOutput.wakeWord,
                                                            clientId: output.clientId,
                                                            clientSecret: output.clientSecret,
                                                            deviceId: output.productId,
                                                            refreshToken: amazonTokenReponse.refresh_token,
                                                            lite: configOutput.liteMode,
                                                            isSpeechVisualizationEnabled: configOutput.useVisualization,
                                                    { colors: true },
                                            run();
                                            Have You Teamview ? You can help :D
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
