    MMM-Hotword
    60 Posts 20 Posters 36.1k Views 17 Watching
      A Former User @berne
      @berne The easiest way is, reinstall freshly.
        berne @berne
        @berne i iam happy using the old one, know how hard it was to get i all set up. a qick questien… how do i change the screen size on the MM? i just geting it in the middel and not full scale
        • T
          t.architecture99
          ? 1 Reply Last reply
            A Former User @t.architecture99
            @t-architecture99
            icons: { //https://iconify.design/icon-sets/
                  waiting: "uil-comment-message",
                  detected: "uil-comment-exclamation",
                  finished: "uil-comment-dots",
              Mrtrol2013
              Does this module support Russian?
                A Former User
                i think yes, MMM-Hotword should be supported
                C 1 Reply Last reply
                  cheun @Guest
                  Hello everybody,
                  Today I tried to install MMM-Hotword from https://github.com/eouia/MMM-Hotword.git but I get à 404 error.
                  It seems the page has been moved or disabled.
                  If so, could someone send me the contents of the git?
                  Thank you in advance for your help!
                    A Former User
                    hummm, yes I have disabled it.
                    but why do you want to use it ?
                      cheun @Guest
                      @Bugsounet Hello,
                      I just wanted to use this module to custom my magic mirror hotword détection.
                      Sorry for my numb question but why disable this fantastic module? Or is there a new one updated?
                      Thank you so much
                      • H
                        hayman
                        @berne said in MMM-Hotword:
                        hello ,im trying to update the MMM-Hotword but keep asking the user&pw of the site after entering them i get wrong psww …?
                        is there any other wat to update it …?
                        thanks
                          A Former User
                          @cheun: give me a good example of use ? (If you don’t use an assistant)
                          @hayman : It seems you are using an assistant so … It’s not needed. You can use ONLY one detector at once
                            sdetweil @hayman
                            @hayman those are YOUR user Id and password on GitHub, right?
                              cheun @Guest
                              @Bugsounet
                              Thank you for your answer.
                              I only want to make a smart mirror with a Google assistant (MMM-AssistantMk2) with a custom hotword.
                              I followed this tutorial :
                              https://github.com/makepluscode/rpi-tutorial-advanced/tree/master/008-raspbian-magicmirror-google-assistant-latest
                              I followed it except I’m running on Buster (vs Stretch in the tuto).
                              I guess things have changed since the year of publication of this tutorial.
                              Hope I answerd your question.
                                A Former User
                                humm yes but … outdated installation sources and will never work
                                I have deprecied MMM-AssistantMk2 too (and it use embed detector)
                                so MMM-Hotword not needed
                                  cheun @Guest
                                  @Bugsounet
                                  Ok,thank you.
                                  So which module(s) do you suggest to make work a Google assistant ?
                                    A Former User
                                    i code this : MMM-GoogleAssistant and MMM-Assistant2Display (extension and addons) there
                                      cheun @Guest
                                      @Bugsounet
                                      thank you very much for putting me on the right way!
                                      last question: is it possible to change language of the assistant to an other (french for exemple)
                                        A Former User
                                        sure ;)
                                        Note: et heuresement car je suis français !
                                          cheun
                                          Ok merci bien ! ( je me disais bien, ton pseudo sonne bon la France! ) ;-)
                                          • F
                                            fabjuju
                                            • 3 / 3
