    Earth globe
    18 Posts 5 Posters 16.8k Views 7 Watching
    • LukeCodewalkerL Offline
      LukeCodewalker Module Developer @bibi
      hi @bibi,
      that should be no problem. I think it would be interesting to use NASA’s EPIC (Earth Polychromatic Imaging Camera) API. There you would get two day old pictures of the globe. Here’s an example image:
      alt text
      You can also view the images here.
      So if you would like to do that I can help you.
      Displaying only an static image would not be very interesting for me.
      greets Luke
        bibi @LukeCodewalker
        hi @LukeCodewalker,
        thx for your feedback and help, it’s much appriciated :) i agree with the static image and your idea with Nasa is interesting. what i had in mind when i open this post was regarding this here what is your opinion about it?
        greetings
        • G Offline
          gizzmo
          I like the idea of having some sort of dynamic data representation of earth, but im not a big fan of the nasa data.
          I like this model beter … Link
          LukeCodewalkerL 1 Reply Last reply Reply Quote 1
            LukeCodewalker Module Developer @gizzmo
            @gizzmo this is also very interesting. It’s from the Himawari-8 satellite and almost live. there you could have very easily four different styles and you don’t need an api-key. I think your suggestions would be very complex to implement. What do you think about these pictures?
              So I made a small test here:
              [card:LukeSkywalker92/MMM-Globe]
              so I could easily make the image update every x minutes and make configs for image-size and image-style just by changing the image-path.
                @LukeCodewalker wow that’s great! i will test it tonight :) noob question : is it ok to git clone your files anywhere or it should be located in MM modules folder?
                LukeCodewalkerL 1 Reply Last reply Reply Quote 0
                  @bibi I think you have to clone it to the modules folder. otherwise MagicMirror won’t find it. Just do it the normal way.
                    small preview =)
                    I’ll have to write a readme, then I’m done.
                    If you want to use a custom picture you just have to put your link in the config file and the module automatically uses this image.
                      So here it is =)
                      https://forum.magicmirror.builders/topic/986/mmm-globe
                        @LukeCodewalker wow! you made a great job here! thx alot for your time/work/involvment!
