    Earth globe
    18 Posts 5 Posters 16.7k Views 7 Watching
    • LukeCodewalkerL Offline
      LukeCodewalker Module Developer @gizzmo
      @gizzmo this is also very interesting. It’s from the Himawari-8 satellite and almost live. there you could have very easily four different styles and you don’t need an api-key. I think your suggestions would be very complex to implement. What do you think about these pictures?
        So I made a small test here:
        [card:LukeSkywalker92/MMM-Globe]
        so I could easily make the image update every x minutes and make configs for image-size and image-style just by changing the image-path.
          bibi @LukeCodewalker
          @LukeCodewalker wow that’s great! i will test it tonight :) noob question : is it ok to git clone your files anywhere or it should be located in MM modules folder?
          LukeCodewalkerL 1 Reply Last reply Reply Quote 0
            LukeCodewalker Module Developer @bibi
            @bibi I think you have to clone it to the modules folder. otherwise MagicMirror won’t find it. Just do it the normal way.
              small preview =)
              I’ll have to write a readme, then I’m done.
              If you want to use a custom picture you just have to put your link in the config file and the module automatically uses this image.
                So here it is =)
                https://forum.magicmirror.builders/topic/986/mmm-globe
                  @LukeCodewalker wow! you made a great job here! thx alot for your time/work/involvment!
                    alexyak @bibi
                    @bibi this code utilizes WebGL which brings RPI to its knees. You can run the MM on a different more powerful hardware, though. As for the module, I have got a POC working on my dev box with a sample data.
                    • cowboysdudeC Offline
                      Yes I am also leaning heavy on creating a bigger mirror running on a much more powerful board.
                      Can’t decide if I want to use a mini pc or itx board…
                        bibi @alexyak
                        @alexyak which is your dev box if i may ask?
