    Earth globe
    18 Posts 5 Posters 17.0k Views 7 Watching
      bibi
      hi! would anybody be interrsted to devlop/help to have a globe showing on the mirror??? something like : 0_1478995270976_Capture d’écran 2016-11-13 à 01.00.54.png
      LukeCodewalkerL 1 Reply Last reply Reply Quote 1
      • LukeCodewalkerL Offline
        LukeCodewalker Module Developer @bibi
        hi @bibi,
        that should be no problem. I think it would be interesting to use NASA’s EPIC (Earth Polychromatic Imaging Camera) API. There you would get two day old pictures of the globe. Here’s an example image:
        alt text
        You can also view the images here.
        So if you would like to do that I can help you.
        Displaying only an static image would not be very interesting for me.
        greets Luke
          bibi @LukeCodewalker
          hi @LukeCodewalker,
          thx for your feedback and help, it’s much appriciated :) i agree with the static image and your idea with Nasa is interesting. what i had in mind when i open this post was regarding this here what is your opinion about it?
          greetings
          • G Offline
            gizzmo
            I like the idea of having some sort of dynamic data representation of earth, but im not a big fan of the nasa data.
            I like this model beter … Link
              LukeCodewalker Module Developer @gizzmo
              @gizzmo this is also very interesting. It’s from the Himawari-8 satellite and almost live. there you could have very easily four different styles and you don’t need an api-key. I think your suggestions would be very complex to implement. What do you think about these pictures?
                So I made a small test here:
                [card:LukeSkywalker92/MMM-Globe]
                so I could easily make the image update every x minutes and make configs for image-size and image-style just by changing the image-path.
                  @LukeCodewalker wow that’s great! i will test it tonight :) noob question : is it ok to git clone your files anywhere or it should be located in MM modules folder?
                  LukeCodewalkerL 1 Reply Last reply Reply Quote 0
                    @bibi I think you have to clone it to the modules folder. otherwise MagicMirror won’t find it. Just do it the normal way.
                      small preview =)
                      I’ll have to write a readme, then I’m done.
                      If you want to use a custom picture you just have to put your link in the config file and the module automatically uses this image.
                        So here it is =)
                        https://forum.magicmirror.builders/topic/986/mmm-globe
                          @LukeCodewalker wow! you made a great job here! thx alot for your time/work/involvment!
                            alexyak @bibi
                            @bibi this code utilizes WebGL which brings RPI to its knees. You can run the MM on a different more powerful hardware, though. As for the module, I have got a POC working on my dev box with a sample data.
                            • cowboysdudeC Offline
                              Yes I am also leaning heavy on creating a bigger mirror running on a much more powerful board.
                              Can’t decide if I want to use a mini pc or itx board…
                                bibi @alexyak
                                @alexyak which is your dev box if i may ask?
                                  alexyak @bibi
                                  @bibi Macbook Pro
                                    alexyak
                                    Small correction about WebGL on RPI - the chromium/hardware will not even run. You will an error message that it’s not supported.
                                      alexyak
                                      Here’s how the module based on WebGL looks like on my dev box:
                                      https://www.youtube.com/watch?v=1L9yofDD-Ic&feature=youtu.be
                                      It displays twitter stream of the tweets that have location. Red lines signify the negative sentiment and green positive. White is neutral.
                                      B 1 Reply Last reply Reply Quote 3
                                        bibi @alexyak
                                        @alexyak Very nice job! it’s exactly what I had in mind when I open this topic. Sad that can’t be run on RPI…
