    Monitor says "NO SIGNAL"
    14 Posts 4 Posters 4.2k Views 4 Watching
      sdetweil @Ameyalgudkar
      @Ameyalgudkar if u turn the monitor off and then back on, does it work after disconnecting from the pi?
      some monitors remember signal at disconnect.
        Ameyalgudkar @sdetweil
        @sdetweil yes, it works without any problem if it’s connected to the pi. Only does not display anything saying (no signal) when I connect the same HDMI to a laptop out port.
          @Ameyalgudkar no, you missed my question
          working on pi,
          unplug from pi
          plug onto laptop, fails
          unplug from laptop
          power monitor off
          plug on to laptop
          turn monitor on
          does it work??
          unplug from pi
          turn monitor off
          plug onto laptop
          turn monitor on
          does it work
            @sdetweil unplug from laptop
            power monitor off
            plug on to laptop [NO IT DOES NOT]
            turn monitor on
            does it work??
            unplug from pi
            turn monitor off
            plug onto laptop NO
            turn monitor on
            does it work
            in simple term, display only works if the hdmi is connected to pi and getting input from pi.
              @Ameyalgudkar the monitor NEVER works on laptop??
                @sdetweil nope.
                But it used to before I installed magic mirror and some modules.
                  @Ameyalgudkar if u unplug monitor from power, does it reset?
                    @sdetweil it does not reset I don’t think it does. because I tried the method you mentioned but it didn’t work.
                      @Ameyalgudkar wow… never ever seen that before… in 40+ years
                        @sdetweil haha yeah even I am not sure what did I do wrong or where. because the monitor used to work fine everything was working well, but this just happened suddenly. Maybe I will just use this monitor on RPI from now on.
                        Also, I am using it with a DVI to HDMI cable and to micro HDMI. could it be due to any of those reasons?
                        and I tried removing the DVI and inserting it back as well but that did not work as well.
