    Monitor says "NO SIGNAL"
    14 Posts 4 Posters 4.2k Views 4 Watching
      sdetweil @Ameyalgudkar
      @Ameyalgudkar no, you missed my question
      working on pi,
      unplug from pi
      plug onto laptop, fails
      unplug from laptop
      power monitor off
      plug on to laptop
      turn monitor on
      does it work??
      unplug from pi
      turn monitor off
      plug onto laptop
      turn monitor on
      does it work
        Ameyalgudkar @sdetweil
        @sdetweil unplug from laptop
        power monitor off
        plug on to laptop [NO IT DOES NOT]
        turn monitor on
        does it work??
        unplug from pi
        turn monitor off
        plug onto laptop NO
        turn monitor on
        does it work
        in simple term, display only works if the hdmi is connected to pi and getting input from pi.
          @Ameyalgudkar the monitor NEVER works on laptop??
            @sdetweil nope.
            But it used to before I installed magic mirror and some modules.
              @Ameyalgudkar if u unplug monitor from power, does it reset?
                @sdetweil it does not reset I don’t think it does. because I tried the method you mentioned but it didn’t work.
                  @Ameyalgudkar wow… never ever seen that before… in 40+ years
                    @sdetweil haha yeah even I am not sure what did I do wrong or where. because the monitor used to work fine everything was working well, but this just happened suddenly. Maybe I will just use this monitor on RPI from now on.
                    Also, I am using it with a DVI to HDMI cable and to micro HDMI. could it be due to any of those reasons?
                    and I tried removing the DVI and inserting it back as well but that did not work as well.
                      @Ameyalgudkar hm… i use dvi/hdmi adapter on one monitor, but again, never seen monitor locked to one system, or signal.
                      now… I HAVE seen one system locked to specific config…
                      I have to power off/on my pi4 if I want the second display to work… only recognized at power on…
                        @sdetweil well, thank you for the time I appreciate it. and hope you find a solution in future for this.
